[petsc-users] Using PFFT within PETSc
Giuseppe Pitton gpitton at sissa.it
Mon Nov 23 01:31:25 CST 2015
Dear users and developers,
I am trying to interface PETSc with the parallel fast Fourier transform
library PFFT
(https://www-user.tu-chemnitz.de/~potts/workgroup/pippig/software.php.en),
based in turn on FFTW. My plan is to build a spectral differentiation
code, and in the attached files you can see a simple example.
The code works correctly in serial, but in parallel there are some
problems regarding the output of the results, I think due to some
differences in the way PETSc and PFFT store data, but I'm not sure if
this is really the issue.
In the attached code, the number of processors used should be specified
at compile time in the variable "ncpus". As long as ncpus = 1,
everything works fine, but if ncpus = 2 or an higher power of 2, the
code terminates correctly but the results show some artifacts, as you
can see from the generated hdf5 file, named "output-pfft.h5".
In the makefile the variables PFFTINC, PFFTLIB, FFTWINC and FFTWLIB
should be set correctly.
Thank you,
Giuseppe
PFFTINC		 = /scratch/opt/pfft-dev/include
FFTWINC		 = /scratch/opt/fftw-3.3.4/include
PFFTLIB		 = /scratch/opt/pfft-dev/lib
FFTWLIB		 = /scratch/opt/fftw-3.3.4/lib
CFLAGS	         =-std=c99 -I${PFFTINC} -I${FFTWINC} -L${PFFTLIB} -L${FFTWLIB}
CLEANFILES       = output-pfft.h5 test-pfft
NP               = 1
include ${PETSC_DIR}lib/petsc/conf/variables
include ${PETSC_DIR}lib/petsc/conf/rules
test-pfft: test-pfft.o  chkopts
	-${CLINKER} -o test-pfft test-pfft.o -lm -lpfft -lfftw3 -lfftw3_mpi ${PETSC_LIB}
	${RM} test-pfft.o
include ${PETSC_DIR}lib/petsc/conf/test
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151123/0df3a441/attachment.c>
