[petsc-users] Compiling PETSc on Windows with Cygwin: errors with `win32fe cl`; okay to use `gcc`, `g++`, `gfortran` as compilers instead of `win32cf cl`?
Sat Nov 21 15:44:07 CST 2015
Linux with Anaconda Python should work. We've primarily used system
default python [on linux] - and that works.
Using Windows with cygwin compilers, python should be pretty close to
using linux.
Satish
On Sat, 21 Nov 2015, Brian Merchant wrote:
> Barry, Satish,
> Thank you for your time and explanations.
> Based on what you have explained, I think it will indeed be much easier for
> me to just build and use PETSc on my Linux system, since I don't build my
> own Python (I use whatever comes with the Anaconda Python distribution
> package). So, for me, it would be better to use PETSc with the Anaconda
> distribution for Unix-like systems.
> Thanks again,
> Brian
