[petsc-users] Debugging failed solve (what's an acceptable upper bound to the condition number?)
Alex Lindsay adlinds3 at ncsu.edu
Fri Nov 20 12:40:31 CST 2015
Hello,
I have an application built on top of the Moose framework, and I'm
trying to debug a solve that is not converging. My linear solve
converges very nicely. However, my non-linear solve does not, and the
problem appears to be in the line search. Reading the PetSc FAQ, I see
that the most common cause of poor line searches are bad Jacobians.
However, I'm using a finite-differenced Jacobian; if I run
-snes_type=test, I get "norm of matrix ratios" < 1e-15. Thus in this
case the Jacobian should be accurate. I'm wondering then if my problem
might be these (taken from the FAQ page):
  * The matrix is very ill-conditioned. Check the condition number
    <http://www.mcs.anl.gov/petsc/documentation/faq.html#conditionnumber>.
      o Try to improve it by choosing the relative scaling of
        components/boundary conditions.
      o Try |-ksp_diagonal_scale -ksp_diagonal_scale_fix|.
      o Perhaps change the formulation of the problem to produce more
        friendly algebraic equations.
  * The matrix is nonlinear (e.g. evaluated using finite differencing of
    a nonlinear function). Try different differencing parameters,
    |./configure --with-precision=__float128 --download-f2cblaslapack|,
    check if it converges in "easier" parameter regimes.
I'm almost ashamed to share my condition number because I'm sure it must
be absurdly high. Without applying -ksp_diagonal_scale and
-ksp_diagonal_scale_fix, the condition number is around 1e25. When I do
apply those two parameters, the condition number is reduced to 1e17.
Even after scaling all my variable residuals so that they were all on
the order of unity (a suggestion on the Moose list), I still have a
condition number of 1e12. I have no experience with condition numbers,
but knowing that perfect condition number is unity, 1e12 seems
unacceptable. What's an acceptable upper limit on the condition number?
Is it problem dependent? Having already tried scaling the individual
variable residuals, I'm not exactly sure what my next method would be
for trying to reduce the condition number.
I definitely have a nonlinear problem. Could I be having problems
because I'm finite differencing non-linear residuals to form my
Jacobian? I can see about using a different differencing parameter. I'm
also going to consider trying quad precision. However, my hypothesis is
that my condition number is the fundamental problem. Is that a
reasonable hypothesis?
If it's useful, below is console output with -pc_type=svd
    Time Step  1, time = 1e-10
                     dt = 1e-10
         |residual|_2 of individual variables:
                    potential:    8.12402e+07
                    potentialliq: 0.000819748
                    em:           49.206
                    emliq:        3.08187e-11
                    Arp:          2375.94
      0 Nonlinear |R| = 8.124020e+07
           SVD: condition number 1.457087640207e+12, 0 of 851 singular
    values are (nearly) zero
           SVD: smallest singular values: 5.637144317564e-09
    9.345415388433e-08 4.106132915572e-05 1.017339655185e-04
    1.147649477723e-04
           SVD: largest singular values : 1.498505466947e+03
    1.577560767570e+03 1.719172328193e+03 2.344218235296e+03
    8.213813311188e+03
         0 KSP unpreconditioned resid norm 3.185019606208e+05 true resid
    norm 3.185019606208e+05 ||r(i)||/||b|| 1.000000000000e+00
         1 KSP unpreconditioned resid norm 6.382886902896e-07 true resid
    norm 6.382761808414e-07 ||r(i)||/||b|| 2.003994511046e-12
       Linear solve converged due to CONVERGED_RTOL iterations 1
           Line search: Using full step: fnorm 8.124020470169e+07 gnorm
    1.097605946684e+01
                    potential:    8.60047
                    potentialliq: 0.335436
                    em:           2.26472
                    emliq:        0.642578
                    Arp:          6.39151
      1 Nonlinear |R| = 1.097606e+01
           SVD: condition number 1.457473763066e+12, 0 of 851 singular
           SVD: smallest singular values: 5.637185516434e-09
    9.347128557672e-08 1.017339655587e-04 1.146760266781e-04
    4.064422034774e-04
           SVD: largest singular values : 1.498505466944e+03
    1.577544976882e+03 1.718956369043e+03 2.343692402876e+03
    8.216049987736e+03
         0 KSP unpreconditioned resid norm 2.653715381459e+01 true resid
    norm 2.653715381459e+01 ||r(i)||/||b|| 1.000000000000e+00
         1 KSP unpreconditioned resid norm 6.031179341420e-05 true resid
    norm 6.031183387732e-05 ||r(i)||/||b|| 2.272731819648e-06
           Line search: gnorm after quadratic fit 2.485190757827e+11
           Line search: Cubic step no good, shrinking lambda, current
    gnorm 2.632996340352e+10 lambda=5.0000000000000003e-02
    gnorm 4.290675557416e+09 lambda=2.5000000000000001e-02
    gnorm 4.332980055153e+08 lambda=1.2500000000000001e-02
    gnorm 1.677118626669e+07 lambda=6.2500000000000003e-03
    gnorm 1.024469780306e+05 lambda=3.1250000000000002e-03
    gnorm 7.011543252988e+03 lambda=1.5625000000000001e-03
    gnorm 1.750171277470e+03 lambda=7.8125000000000004e-04
    gnorm 3.486970625406e+02 lambda=3.4794637057251714e-04
    gnorm 7.830624839582e+01 lambda=1.5977866967992950e-04
    gnorm 2.147529381328e+01 lambda=6.8049915671999093e-05
    gnorm 1.138950943123e+01 lambda=1.7575203052774536e-05
           Line search: Cubically determined step, current gnorm
    1.095195976135e+01 lambda=1.7575203052774537e-06
                    potential:    8.59984
                    potentialliq: 0.395753
                    em:           2.26492
                    emliq:        0.642578
                    Arp:          6.34735
      2 Nonlinear |R| = 1.095196e+01
           SVD: condition number 1.457459214030e+12, 0 of 851 singular
           SVD: smallest singular values: 5.637295371943e-09
    9.347057884198e-08 1.017339655949e-04 1.146738253493e-04
    4.064421554132e-04
           SVD: largest singular values : 1.498505466946e+03
    1.577543742603e+03 1.718948052797e+03 2.343672206864e+03
    8.216128082047e+03
         0 KSP unpreconditioned resid norm 2.653244141805e+01 true resid
    norm 2.653244141805e+01 ||r(i)||/||b|| 1.000000000000e+00
         1 KSP unpreconditioned resid norm 4.480869560737e-05 true resid
    norm 4.480686665183e-05 ||r(i)||/||b|| 1.688757771886e-06
           Line search: gnorm after quadratic fit 2.481752147885e+11
    gnorm 2.631959989642e+10 lambda=5.0000000000000003e-02
    gnorm 4.289110800463e+09 lambda=2.5000000000000001e-02
    gnorm 4.332043942482e+08 lambda=1.2500000000000001e-02
    gnorm 1.677933337886e+07 lambda=6.2500000000000003e-03
    gnorm 1.027980597206e+05 lambda=3.1250000000000002e-03
    gnorm 7.054113639063e+03 lambda=1.5625000000000001e-03
    gnorm 1.771258630210e+03 lambda=7.8125000000000004e-04
    gnorm 3.517070127496e+02 lambda=3.4519087020105563e-04
    gnorm 7.844350966118e+01 lambda=1.5664532891249369e-04
    gnorm 2.114833995101e+01 lambda=6.5367917100814859e-05
    gnorm 1.144636844292e+01 lambda=1.6044984646715980e-05
    gnorm 1.095640770627e+01 lambda=1.6044984646715980e-06
    gnorm 1.095196729511e+01 lambda=1.6044984646715980e-07
    1.095195451041e+01 lambda=2.3994454223607641e-08
                    potential:    8.59983
                    potentialliq: 0.396107
                    em:           2.26492
                    emliq:        0.642578
                    Arp:          6.34733
      3 Nonlinear |R| = 1.095195e+01
           SVD: condition number 1.457474387942e+12, 0 of 851 singular
           SVD: smallest singular values: 5.637237413167e-09
    9.347057670885e-08 1.017339654798e-04 1.146737961973e-04
    4.064420550524e-04
    1.577543716995e+03 1.718947893048e+03 2.343671853830e+03
    8.216129148438e+03
         0 KSP unpreconditioned resid norm 2.653237816527e+01 true resid
    norm 2.653237816527e+01 ||r(i)||/||b|| 1.000000000000e+00
         1 KSP unpreconditioned resid norm 8.525213442515e-05 true resid
    norm 8.527696332776e-05 ||r(i)||/||b|| 3.214071607022e-06
           Line search: gnorm after quadratic fit 2.481576195523e+11
    gnorm 2.632005412624e+10 lambda=5.0000000000000003e-02
    gnorm 4.289212002697e+09 lambda=2.5000000000000001e-02
    gnorm 4.332196637845e+08 lambda=1.2500000000000001e-02
    gnorm 1.678040222943e+07 lambda=6.2500000000000003e-03
    gnorm 1.027868984884e+05 lambda=3.1250000000000002e-03
    gnorm 7.010733464460e+03 lambda=1.5625000000000001e-03
    gnorm 1.751519860441e+03 lambda=7.8125000000000004e-04
    gnorm 3.497889916171e+02 lambda=3.4753778542938795e-04
    gnorm 7.932631084466e+01 lambda=1.5879606741873878e-04
    gnorm 2.194608479634e+01 lambda=6.5716583192912669e-05
    gnorm 1.117190149691e+01 lambda=1.1541218569257328e-05
    1.093879875464e+01 lambda=1.1541218569257329e-06
                    potential:    8.59942
                    potentialliq: 0.403326
                    em:           2.26505
                    emliq:        0.714844
                    Arp:          6.3169
      4 Nonlinear |R| = 1.093880e+01
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151120/486f00a6/attachment.html>
