[petsc-users] adding mat rows
Carles Bona carlesbona at gmail.com
Fri Nov 20 05:43:59 CST 2015
Hello again,
MatMatMult not supported for B of type mpibaij (where A*B = C). Can A be of
type mpibaij? Will C be of type mpibaij if A is but B is not?
I see the limitation to aij/dense is mentioned in the documentation in
matmatmultsymbolic and matmatmultnumeric, but not in matmatmult. Probably
they have the same limitation...
I guess I'm back to row-reading-adding.
Carles
2015-11-19 21:49 GMT+01:00 Jed Brown <jed at jedbrown.org>:
> Carles Bona <carlesbona at gmail.com> writes:
> > Sorry, yes, I meant losing less information than I would lose without
> > adding beforehand.
> That's not true either (as described).  You're replacing two equations
> with one equation, so no matter how you do it, you're opening a 1D
> space.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151120/97b95628/attachment.html>
