[petsc-users] [issue1376] Citation for hypre BoomerAMG
Rob Falgout hypre Tracker hypre-support at llnl.gov
Wed Nov 18 18:28:03 CST 2015
Rob Falgout <rfalgout at llnl.gov> added the comment:
Hi Matt,
We have recently been using the web page as the reference for hypre, with no author list (the team and code are continually changing).  So, the bib entry looks fine.  To get rid of the error, try changing '@manual' to '@misc'.
Hope this helps.  Thanks for asking!
-Rob
> -----Original Message-----
> From: Young, Matthew, Adam hypre Tracker [mailto:hypre-
> support at llnl.gov]
> Sent: Wednesday, November 18, 2015 1:34 PM
> To: Li, Ruipeng; may at bu.edu; Osei-Kuffuor, Daniel; rfalgout at llnl.gov;
> Schroder, Jacob B.; tzanio at llnl.gov; umyang at llnl.gov; Wang, Lu
> Subject: [issue1376] [petsc-users] Citation for hypre BoomerAMG
> New submission from Young, Matthew, Adam <may at bu.edu>:
> Barry,
> You seem to be right that my style file was looking for an author; it seems to
> have also been looking for a year, hence the empty brackets. Unfortunately,
> adding an author and a year caused only those two fields to be printed in the
> bibliography (leaving out the rest of the info generated by -citation). I'm
> using agufull08.bst.
> I'll wait to see what the Hypre folks say. I just want to give them proper
> citation.
> --Matt
> Matthew Young
> Graduate Student
> Boston University Dept. of Astronomy
> From: Barry Smith [bsmith at mcs.anl.gov]
> Sent: Wednesday, November 18, 2015 4:03 PM
> To: Young, Matthew, Adam
> Cc: petsc-users at mcs.anl.gov; hypre-support at llnl.gov
> Subject: Re: [petsc-users] Citation for hypre BoomerAMG
> > On Nov 18, 2015, at 2:45 PM, Young, Matthew, Adam <may at bu.edu>
> wrote:
> > When I run my code with -citations, it produces
> > @manual{hypre-web-page,
> >   title  = {{\sl hypre}: High Performance Preconditioners},
> >   organization = {Lawrence Livermore National Laboratory},
> >   note  = {\url{http://www.llnl.gov/CASC/hypre/}}
> > for BoomerAMG. However, the result of \citep{hypre-web-page} is
> > "[hyp]" in the text
>    Is this ok? Or should it produce something different in the text? I think your
> bibliography style file uses some shortened form of the bibtex key for the
> this.
> > and a bibliography entry with only "()" for the author. This seems incorrect.
> If this is the intended output, can you tell me what I'm doing wrong in LaTeX?
> The other references (two for PETSc and one for GMRES) are fine.
>   Likely your bibliography style file  requires an author field and so is putting in
> () since this bibliography entry doesn't have an author entry.  You can try
> adding an author field manually and see if that improves things.
>   hypre folks,
>      We'd be happy to list some authors here (or not) just let us know what
> you prefer?
>   Barry
> > --Matt
> > Matthew Young
> > Graduate Student
> messages: 6809
> nosy: bsmith, li50, may, oseikuffuor1, petsc-users, rfalgout, schroder2,
> tzanio, ulrikey, wang84
> status: unread
> title: [petsc-users] Citation for hypre BoomerAMG
> ____________________________________________
> hypre Issue Tracker <hypre-support at llnl.gov>
> <http://tux339.llnl.gov/hypre/issue1376>
