[petsc-users] Citation for hypre BoomerAMG
Wed Nov 18 15:03:46 CST 2015
> On Nov 18, 2015, at 2:45 PM, Young, Matthew, Adam <may at bu.edu> wrote:
> When I run my code with -citations, it produces
> @manual{hypre-web-page,
>   title  = {{\sl hypre}: High Performance Preconditioners},
>   organization = {Lawrence Livermore National Laboratory},
>   note  = {\url{http://www.llnl.gov/CASC/hypre/}}
> for BoomerAMG. However, the result of \citep{hypre-web-page} is "[hyp]" in the text
   Is this ok? Or should it produce something different in the text? I think your bibliography style file uses some shortened form of the bibtex key for the this.
> and a bibliography entry with only "()" for the author. This seems incorrect. If this is the intended output, can you tell me what I'm doing wrong in LaTeX? The other references (two for PETSc and one for GMRES) are fine.
  Likely your bibliography style file  requires an author field and so is putting in () since this bibliography entry doesn't have an author entry.  You can try adding an author field manually and see if that improves things.
  hypre folks,
     We'd be happy to list some authors here (or not) just let us know what you prefer?
  Barry
> --Matt
> Matthew Young
> Graduate Student
> Boston University Dept. of Astronomy
