[petsc-users] On the edge of 2^31 unknowns
Mon Nov 16 15:31:07 CST 2015
  ah yes, and we have a bunch of those 2's running around
> On Nov 16, 2015, at 2:53 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> Out goal is that if something won't fit in a 32 bit int we use a 64
>>>> bit integer when possible or at least produce a very useful error
>>>> message instead of the horrible malloc error you get.  The more
>>>> crashes you can give us the quicker we can fix these errors.
>>> This feels like something that we should be able to find with static
>>> analysis, though I don't know how since many of the problems are a
>>> consequence of unsuffixed numeric literals having type "int".
>>> What if we compiled for an I16LP32 architecture (emulator) so we could
>>> find these problems at small scale?
>>  Or defined PetscInt to be short for test runs?
> Wouldn't help in this particular case because the numeric literal "2"
> has type int causing the rest of the arithmetic to be done with that
> type.
