[petsc-users] On the edge of 2^31 unknowns
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Mon Nov 16 14:43:26 CST 2015
On 16/11/15 03:22 PM, Barry Smith wrote:
>    Out goal is that if something won't fit in a 32 bit int we use a 64 bit integer when possible or at least produce a very useful error message instead of the horrible malloc error you get.  The more crashes you can give us the quicker we can fix these errors.
understood.
On the next try, if you have released a fix, let's say in 3.6.3, I will
first launch the computation with 32bit indices.  If it fails, I will
send you the error but.... I will have on hand a 64bit indices version
of everything, compiled and ready to be launched just in case of error.
  Doing so I will not loose my special cluster allocation...
anyway, thanks a lot for your help! :)
Eric
