[petsc-users] GAMG and zero pivots follow up
Mark Adams mfadams at lbl.gov
Mon Nov 16 11:31:25 CST 2015
On Fri, Nov 13, 2015 at 2:48 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 13, 2015 at 12:28 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>> > Something very strange is happening here. CG should converge
>> monotonically,
>> > but above it does not. What could be happening?
>> Are you use -ksp_norm_type natural?  CG is not monotone in other norms.
> Yikes! I did not check that. Why do we have PRECONDITIONED as the default
> for CG?
The two norm of the residual (ie, natural, right?) is not monotone either
in CG.
>    Matt
> Also, if boundary conditions are enforced using a nonsymmetric
>> formulation (for example), then you can get lack of monotonicity with CG
>> that may not be catastrophic.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151116/4c9c9552/attachment.html>
