[petsc-users] On the edge of 2^31 unknowns
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Mon Nov 16 09:38:02 CST 2015
we just tried this morning to solve a 1.7 billion dofs problem (on 1060
processors task)  .
Unfortunately, petsc-3.5.3 didn't succeed within a MatMatMult product
with the following backtrace:
[0]PETSC ERROR: Out of memory. This could be due to allocating
[0]PETSC ERROR: too large an object or bleeding by not properly
[0]PETSC ERROR: destroying unneeded objects.
[0]PETSC ERROR: Memory allocated 0 Memory used by process 4126371840
[0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[0]PETSC ERROR: Memory requested 18446744070461249536
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015
[0]PETSC ERROR: /rap/jsf-051-aa/ericc/GIREF/bin/probGD.opt on a
linux-gnu-intel named r101-n31 by
[0]PETSC ERROR: Configure options PETSC_ARCH=linux-gnu-intel CFLAGS="-O3
-xHost -mkl -fPIC -m64 -n
[0]PETSC ERROR: #1 PetscMallocAlign() line 46 in
/software6/src/petsc-3.5.3/src/sys/memory/mal.c
[0]PETSC ERROR: #2 PetscLLCondensedCreate_Scalable() line 1327 in
/software6/src/petsc-3.5.3/inclu
[0]PETSC ERROR: #3 MatMatMultSymbolic_MPIAIJ_MPIAIJ() line 741 in
/software6/src/petsc-3.5.3/src/m
[0]PETSC ERROR: #4 MatMatMult_MPIAIJ_MPIAIJ() line 33 in
/software6/src/petsc-3.5.3/src/mat/impls/
[0]PETSC ERROR: #5 MatMatMult() line 8713 in
/software6/src/petsc-3.5.3/src/mat/interface/matrix.c
The amount of memory requested is, apparently, an overflow of a PetscInt
which is a 32 bit signed int.
Bad user I am, I didn't expected that to solve a problem with less than
2^31 unknowns, it could be mandatory to compile petsc with 64bit indices...
Is compiling with "--with-64-bit-indices" the only solution to my problem?
Is it a known limitation/bug with a "Petsc-32bit-indices"?
Eric
