[petsc-users] GAMG and zero pivots follow up
Fri Nov 13 08:45:24 CST 2015
On Thu, Nov 12, 2015 at 10:02 PM, David Knezevic <david.knezevic at akselos.com
> wrote:
> On Thu, Nov 12, 2015 at 9:58 AM, David Knezevic <
> david.knezevic at akselos.com> wrote:
>> On Thu, Nov 12, 2015 at 9:50 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Note, I suspect the zero pivot is coming from a coarse grid.  I don't
>>> know why no-inode fixed it.  N.B., this might not be deterministic.
>>> If you run with -info and grep on 'GAMG' you will see the block sizes.
>>> They should be 3 on the fine grid and the 6 on the coarse grids if you set
>>> everything up correctly.
>> OK, thanks for the info, I'll look into this further.
>> Though note that I got it to work now without needing no-inode now. The
>> change I made was to make sure that I matched the order of function calls
>> from the PETSc GAMG examples. The libMesh code I was using was doing things
>> somewhat out of order, apparently.
> As I mentioned above, GAMG seems to be working fine for me now. Thanks for
> the help on this.
> However, I wanted to ask about another 3D elasticity test case I ran in
> which GAMG didn't converge. The "-ksp_view -ksp_monitor" output is below.
> Any insights into what options I should set in order to get it to converge
> in this case would be appreciated. (By the way, ML worked in this case with
> the default options.)
> Thanks,
> David
>   0 KSP Residual norm 2.475892877233e-03
>   1 KSP Residual norm 6.181785698923e-05
>   2 KSP Residual norm 9.439050821656e-04
Something very strange is happening here. CG should converge monotonically,
but above it does not. What could be happening?
  a) We could have lost orthogonality
      This seems really unlikely in 2 iterates.
  b) The preconditioner could be nonlinear
     In order to test this, could you run with both GMRES and FGMRES? If
the convergence is different, then something is wrong
     with the preconditioner.
     I have looked below, and it seems like this should be linear. Mark,
could something be happening in GAMG?
Also, you should not be using CG/V-cycle. You should be using 1 iterate of
FMG, -pc_mg_type full.  I have just been going over
this in class. It is normal for people to solve way past discretization
error, but that does not make much sense. Its not hard to
get a sense of discretization error using a manufactured solution.
    Matt
> KSP Object: 8 MPI processes
>   type: cg
>   maximum iterations=5000
>   tolerances:  relative=1e-12, absolute=1e-50, divergence=10000
>   left preconditioning
>   using nonzero initial guess
>   using PRECONDITIONED norm type for convergence test
> PC Object: 8 MPI processes
>   type: gamg
>     MG: type is MULTIPLICATIVE, levels=5 cycles=v
>       Cycles per PCApply=1
>       Using Galerkin computed coarse grid matrices
>       GAMG specific options
>         Threshold for dropping small values from graph 0
>         AGG specific options
>           Symmetric graph false
>   Coarse grid solver -- level -------------------------------
>     KSP Object:    (mg_coarse_)     8 MPI processes
>       type: gmres
>         GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>         GMRES: happy breakdown tolerance 1e-30
>       maximum iterations=1, initial guess is zero
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>       using NONE norm type for convergence test
>     PC Object:    (mg_coarse_)     8 MPI processes
>       type: bjacobi
>         block Jacobi: number of blocks = 8
>         Local solve is same for all blocks, in the following KSP and PC
> objects:
>       KSP Object:      (mg_coarse_sub_)       1 MPI processes
>         type: preonly
>       PC Object:      (mg_coarse_sub_)       1 MPI processes
>         type: lu
>           LU: out-of-place factorization
>           tolerance for zero pivot 2.22045e-14
>           using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>           matrix ordering: nd
>           factor fill ratio given 5, needed 1
>             Factored matrix follows:
>               Mat Object:               1 MPI processes
>                 type: seqaij
>                 rows=6, cols=6, bs=6
>                 package used to perform factorization: petsc
>                 total: nonzeros=36, allocated nonzeros=36
>                 total number of mallocs used during MatSetValues calls =0
>                   using I-node routines: found 2 nodes, limit used is 5
>         linear system matrix = precond matrix:
>           type: seqaij
>       Mat Object:       8 MPI processes
>         type: mpiaij
>           using I-node (on process 0) routines: found 2 nodes, limit used
> is 5
>   Down solver (pre-smoother) on level 1 -------------------------------
>     KSP Object:    (mg_levels_1_)     8 MPI processes
>       type: chebyshev
>         Chebyshev: eigenvalue estimates:  min = 0.146922, max = 1.61615
>         Chebyshev: eigenvalues estimated using gmres with translations  [0
> 0.1; 0 1.1]
>         KSP Object:        (mg_levels_1_esteig_)         8 MPI processes
>           type: gmres
>           maximum iterations=10, initial guess is zero
>       maximum iterations=2
>     PC Object:    (mg_levels_1_)     8 MPI processes
>       type: sor
>         SOR: type = local_symmetric, iterations = 1, local iterations = 1,
> omega = 1
>         type: mpiaij
>         rows=162, cols=162, bs=6
>         total: nonzeros=26244, allocated nonzeros=26244
>           using I-node (on process 0) routines: found 5 nodes, limit used
> is 5
>   Up solver (post-smoother) same as down solver (pre-smoother)
>   Down solver (pre-smoother) on level 2 -------------------------------
>     KSP Object:    (mg_levels_2_)     8 MPI processes
>       type: chebyshev
>         Chebyshev: eigenvalue estimates:  min = 0.143941, max = 1.58335
> 0.1; 0 1.1]
>         KSP Object:        (mg_levels_2_esteig_)         8 MPI processes
>           type: gmres
>     PC Object:    (mg_levels_2_)     8 MPI processes
>       type: sor
> omega = 1
>         type: mpiaij
>         rows=4668, cols=4668, bs=6
>         total: nonzeros=3.00254e+06, allocated nonzeros=3.00254e+06
>           using I-node (on process 0) routines: found 158 nodes, limit
> used is 5
>   Down solver (pre-smoother) on level 3 -------------------------------
>     KSP Object:    (mg_levels_3_)     8 MPI processes
>       type: chebyshev
>         Chebyshev: eigenvalue estimates:  min = 0.128239, max = 1.41063
> 0.1; 0 1.1]
>         KSP Object:        (mg_levels_3_esteig_)         8 MPI processes
>           type: gmres
>     PC Object:    (mg_levels_3_)     8 MPI processes
>       type: sor
> omega = 1
>         type: mpiaij
>         rows=66390, cols=66390, bs=6
>         total: nonzeros=1.65982e+07, allocated nonzeros=1.65982e+07
>           using I-node (on process 0) routines: found 2668 nodes, limit
> used is 5
>   Down solver (pre-smoother) on level 4 -------------------------------
>     KSP Object:    (mg_levels_4_)     8 MPI processes
>       type: chebyshev
>         Chebyshev: eigenvalue estimates:  min = 0.1, max = 1.1
> 0.1; 0 1.1]
>         KSP Object:        (mg_levels_4_esteig_)         8 MPI processes
>           type: gmres
>     PC Object:    (mg_levels_4_)     8 MPI processes
>       type: sor
> omega = 1
>       Mat Object:      ()       8 MPI processes
>         type: mpiaij
>         rows=1532187, cols=1532187, bs=3
>         total: nonzeros=1.21304e+08, allocated nonzeros=1.21304e+08
>           has attached near null space
>           using I-node (on process 0) routines: found 66403 nodes, limit
> used is 5
>     type: mpiaij
>       using I-node (on process 0) routines: found 66403 nodes, limit used
> is 5
> Error, conv_flag < 0!
>> On Wed, Nov 11, 2015 at 1:36 PM, David Knezevic <
>>> On Wed, Nov 11, 2015 at 12:57 PM, David Knezevic <
>>>> On Wed, Nov 11, 2015 at 12:24 PM, David Knezevic <
>>>>> On Tue, Nov 10, 2015 at 10:28 PM, David Knezevic <
>>>>>> On Tue, Nov 10, 2015 at 10:24 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Tue, Nov 10, 2015 at 9:21 PM, David Knezevic <
>>>>>>>> On Tue, Nov 10, 2015 at 10:00 PM, Matthew Knepley <
>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>> On Tue, Nov 10, 2015 at 8:39 PM, David Knezevic <
>>>>>>>>>> I'm looking into using GAMG, so I wanted to start with a simple
>>>>>>>>>> 3D elasticity problem. When I first tried this, I got the following "zero
>>>>>>>>>> pivot" error:
>>>>>>>>>> [0]PETSC ERROR: Zero pivot in LU factorization:
>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
>>>>>>>>>> [0]PETSC ERROR: Zero pivot, row 3
>>>>>>>>>> [0]PETSC ERROR: See
>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>>>>> shooting.
>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.6.1, Jul, 22, 2015
>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>> /home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a
>>>>>>>>>> arch-linux2-c-opt named david-Lenovo by dknez Tue Nov 10 21:26:39 2015
>>>>>>>>>> [0]PETSC ERROR: Configure options --with-shared-libraries=1
>>>>>>>>>> --with-debugging=0 --download-suitesparse --download-parmetis
>>>>>>>>>> --download-blacs
>>>>>>>>>> --with-blas-lapack-dir=/opt/intel/system_studio_2015.2.050/mkl
>>>>>>>>>> --CXXFLAGS=-Wl,--no-as-needed --download-scalapack --download-mumps
>>>>>>>>>> --download-metis --download-superlu_dist
>>>>>>>>>> --prefix=/home/dknez/software/libmesh_install/opt_real/petsc
>>>>>>>>>> --download-hypre --download-ml
>>>>>>>>>> [0]PETSC ERROR: #1 PetscKernel_A_gets_inverse_A_5() line 48 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/mat/impls/baij/seq/dgefa5.c
>>>>>>>>>> [0]PETSC ERROR: #2 MatSOR_SeqAIJ_Inode() line 2808 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/mat/impls/aij/seq/inode.c
>>>>>>>>>> [0]PETSC ERROR: #3 MatSOR() line 3697 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/mat/interface/matrix.c
>>>>>>>>>> [0]PETSC ERROR: #4 PCApply_SOR() line 37 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/pc/impls/sor/sor.c
>>>>>>>>>> [0]PETSC ERROR: #5 PCApply() line 482 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/pc/interface/precon.c
>>>>>>>>>> [0]PETSC ERROR: #6 KSP_PCApply() line 242 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/include/petsc/private/kspimpl.h
>>>>>>>>>> [0]PETSC ERROR: #7 KSPInitialResidual() line 63 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/interface/itres.c
>>>>>>>>>> [0]PETSC ERROR: #8 KSPSolve_GMRES() line 235 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/impls/gmres/gmres.c
>>>>>>>>>> [0]PETSC ERROR: #9 KSPSolve() line 604 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>> [0]PETSC ERROR: #10 KSPSolve_Chebyshev() line 381 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/impls/cheby/cheby.c
>>>>>>>>>> [0]PETSC ERROR: #11 KSPSolve() line 604 in
>>>>>>>>>> [0]PETSC ERROR: #12 PCMGMCycle_Private() line 19 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/pc/impls/mg/mg.c
>>>>>>>>>> [0]PETSC ERROR: #13 PCMGMCycle_Private() line 48 in
>>>>>>>>>> [0]PETSC ERROR: #14 PCApply_MG() line 338 in
>>>>>>>>>> [0]PETSC ERROR: #15 PCApply() line 482 in
>>>>>>>>>> [0]PETSC ERROR: #16 KSP_PCApply() line 242 in
>>>>>>>>>> [0]PETSC ERROR: #17 KSPSolve_CG() line 139 in
>>>>>>>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/impls/cg/cg.c
>>>>>>>>>> [0]PETSC ERROR: #18 KSPSolve() line 604 in
>>>>>>>>>> I saw that there was a thread about this in September (subject:
>>>>>>>>>> "gamg and zero pivots"), and that the fix is to use "-mg_levels_pc_type
>>>>>>>>>> jacobi." When I do that, the solve succeeds (I pasted the -ksp_view at the
>>>>>>>>>> end of this email).
>>>>>>>>>> So I have two questions about this:
>>>>>>>>>> 1. Is it surprising that I hit this issue for a 3D elasticity
>>>>>>>>>> problem? Note that matrix assembly was done in libMesh, I can look into the
>>>>>>>>>> structure of the assembled matrix more carefully, if needed. Also, note
>>>>>>>>>> that I can solve this problem with direct solvers just fine.
>>>>>>>>> Yes, this seems like a bug, but it could be some strange BC thing
>>>>>>>>> I do not understand.
>>>>>>>> OK, I can look into the matrix in more detail. I agree that it
>>>>>>>> should have a non-zero diagonal, so I'll have a look at what's happening
>>>>>>>> with that.
>>>>>>>>> Naively, the elastic element matrix has a nonzero diagonal. I see
>>>>>>>>> that you are doing LU
>>>>>>>>> of size 5. That seems strange for 3D elasticity. Am I missing
>>>>>>>>> something? I would expect
>>>>>>>>> block size 3.
>>>>>>>> I'm not sure what is causing the LU of size 5. Is there a setting
>>>>>>>> to control that?
>>>>>>>> Regarding the block size: I set the vector and matrix block size to
>>>>>>>> 3 via VecSetBlockSize and MatSetBlockSize. I also
>>>>>>>> used MatNullSpaceCreateRigidBody on a vector with block size of 3, and set
>>>>>>>> the matrix's near nullspace using that.
>>>>>>> Can you run this same example with -mat_no_inode? I think it may be
>>>>>>> a strange blocking that is causing this.
>>>>>> That works. The -ksp_view output is below.
>>>>> I just wanted to follow up on this. I had a more careful look at the
>>>>> matrix, and confirmed that there are no zero entries on the diagonal (as
>>>>> expected for elasticity). The matrix is from one of libMesh's example
>>>>> problems: a simple cantilever model using HEX8 elements.
>>>>> Do you have any further thoughts about what might cause the "strange
>>>>> blocking" that you referred to? If there's something non-standard that
>>>>> libMesh is doing with the blocks, I'd be interested to look into that. I
>>>>> can send over the matrix if that would be helpful.
>>>>> Thanks,
>>>>> David
>>>> P.S. I was previously calling VecSetBlockSize and MatSetBlockSize to
>>>> set the block size to 3. When I don't do that, I no longer need to call
>>>> -mat_no_inodes. I've pasted the -ksp_view output below. Does it look like
>>>> that's working OK?
>>> Sorry for the multiple messages, but I think I found the issue. libMesh
>>> internally sets the block size to 1 earlier on (in PetscMatrix::init()). I
>>> guess it'll work fine if I get it to set the block size to 3 instead, so
>>> I'll look into that. (libMesh has an enable-blocked-storage configure
>>> option that should take care of this automatically.)
>>> David
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151113/de633547/attachment-0001.html>
