[petsc-users] Parallel matrix-vector multiplication
Thu Nov 12 00:19:37 CST 2015
DMDAGetOwnershipRanges
> On Nov 11, 2015, at 10:47 PM, Gianluca Meneghello <gianmail at gmail.com> wrote:
> Hi,
> thanks for the very quick reply.
> One more question: is there a way to get the lx and ly from the first dm and use them (modified) for the second dm? DMDAGetInfo does not seem to provide this information.
> Thanks again for your help
> Gianluca
> On Wed, Nov 11, 2015 at 8:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   When you create the 2 DM you must be set the lx, ly arguments (the ones you set to 0) in your code carefully to insure that the vectors for the 2 DM you create have compatible layout to do the matrix vector product.
>    You can run a very small problem with 2 processors and printing out the vectors to see the layout to make sure you get it correct.
>    The 2 DM don't have any magically way of knowing that you created another DMDA and want it to be compatible automatically.
>   Barry
> DMDACreate2d(PETSC_COMM_WORLD , DM_BOUNDARY_GHOSTED , DM_BOUNDARY_GHOSTED , DMDA_STENCIL_BOX ,
>       Mx      , Nx      , PETSC_DECIDE , PETSC_DECIDE , 1 , 0 , 0 , 0 , &dax);
>   DMDACreate2d(PETSC_COMM_WORLD , DM_BOUNDARY_NONE    , DM_BOUNDARY_NONE    , DMDA_STENCIL_BOX ,
>       Mx-2*bs , Nx-2*bs , PETSC_DECIDE , PETSC_DECIDE , 1 , 0 , 0 , 0 , &daf);
> > On Nov 11, 2015, at 10:05 PM, Gianluca Meneghello <gianmail at gmail.com> wrote:
> > Hi,
> > I am trying to do something apparently really simple but with no success.
> > I need to perform a matrix-vector multiplication x = B f , where the length of x is bigger than the length of f (or viceversa). Thus, B cannot be created using DMCreateMatrix.
> > Both x and f are obtained from different DMs, the smaller covering only a subdomain of the larger. The application is to apply a control f to a system, e.g. \dot{x} = A x + B f.
> > The problem is, when running on more than one core, the vector x is not organized as I would expect (everything works fine on a single core).
> > I attach a short example where B is intended to map f to the interior of x.
> > mpirun -n 1 ./test -draw_pause -1     works fine while
> > mpirun -n 2 ./test -draw_pause -1     shows the problem
> > I have not found any example with non square matrices in the src folder, any help is very welcome.
> > Thanks for your time,
> > Gianluca
> > <test.cpp>
