[petsc-users] GAMG and zero pivots follow up
David Knezevic david.knezevic at akselos.com
Tue Nov 10 21:28:10 CST 2015
On Tue, Nov 10, 2015 at 10:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Nov 10, 2015 at 9:21 PM, David Knezevic <
> david.knezevic at akselos.com> wrote:
>> On Tue, Nov 10, 2015 at 10:00 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Nov 10, 2015 at 8:39 PM, David Knezevic <
>>>> I'm looking into using GAMG, so I wanted to start with a simple 3D
>>>> elasticity problem. When I first tried this, I got the following "zero
>>>> pivot" error:
>>>> [0]PETSC ERROR: Zero pivot in LU factorization:
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
>>>> [0]PETSC ERROR: Zero pivot, row 3
>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.6.1, Jul, 22, 2015
>>>> [0]PETSC ERROR:
>>>> /home/dknez/akselos-dev/scrbe/build/bin/fe_solver-opt_real on a
>>>> arch-linux2-c-opt named david-Lenovo by dknez Tue Nov 10 21:26:39 2015
>>>> [0]PETSC ERROR: Configure options --with-shared-libraries=1
>>>> --with-debugging=0 --download-suitesparse --download-parmetis
>>>> --download-blacs
>>>> --with-blas-lapack-dir=/opt/intel/system_studio_2015.2.050/mkl
>>>> --CXXFLAGS=-Wl,--no-as-needed --download-scalapack --download-mumps
>>>> --download-metis --download-superlu_dist
>>>> --prefix=/home/dknez/software/libmesh_install/opt_real/petsc
>>>> --download-hypre --download-ml
>>>> [0]PETSC ERROR: #1 PetscKernel_A_gets_inverse_A_5() line 48 in
>>>> /home/dknez/software/petsc-3.6.1/src/mat/impls/baij/seq/dgefa5.c
>>>> [0]PETSC ERROR: #2 MatSOR_SeqAIJ_Inode() line 2808 in
>>>> /home/dknez/software/petsc-3.6.1/src/mat/impls/aij/seq/inode.c
>>>> [0]PETSC ERROR: #3 MatSOR() line 3697 in
>>>> /home/dknez/software/petsc-3.6.1/src/mat/interface/matrix.c
>>>> [0]PETSC ERROR: #4 PCApply_SOR() line 37 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/pc/impls/sor/sor.c
>>>> [0]PETSC ERROR: #5 PCApply() line 482 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/pc/interface/precon.c
>>>> [0]PETSC ERROR: #6 KSP_PCApply() line 242 in
>>>> /home/dknez/software/petsc-3.6.1/include/petsc/private/kspimpl.h
>>>> [0]PETSC ERROR: #7 KSPInitialResidual() line 63 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/interface/itres.c
>>>> [0]PETSC ERROR: #8 KSPSolve_GMRES() line 235 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/impls/gmres/gmres.c
>>>> [0]PETSC ERROR: #9 KSPSolve() line 604 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/interface/itfunc.c
>>>> [0]PETSC ERROR: #10 KSPSolve_Chebyshev() line 381 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/impls/cheby/cheby.c
>>>> [0]PETSC ERROR: #11 KSPSolve() line 604 in
>>>> [0]PETSC ERROR: #12 PCMGMCycle_Private() line 19 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/pc/impls/mg/mg.c
>>>> [0]PETSC ERROR: #13 PCMGMCycle_Private() line 48 in
>>>> [0]PETSC ERROR: #14 PCApply_MG() line 338 in
>>>> [0]PETSC ERROR: #15 PCApply() line 482 in
>>>> [0]PETSC ERROR: #16 KSP_PCApply() line 242 in
>>>> [0]PETSC ERROR: #17 KSPSolve_CG() line 139 in
>>>> /home/dknez/software/petsc-3.6.1/src/ksp/ksp/impls/cg/cg.c
>>>> [0]PETSC ERROR: #18 KSPSolve() line 604 in
>>>> I saw that there was a thread about this in September (subject: "gamg
>>>> and zero pivots"), and that the fix is to use "-mg_levels_pc_type
>>>> jacobi." When I do that, the solve succeeds (I pasted the -ksp_view at the
>>>> end of this email).
>>>> So I have two questions about this:
>>>> 1. Is it surprising that I hit this issue for a 3D elasticity problem?
>>>> Note that matrix assembly was done in libMesh, I can look into the
>>>> structure of the assembled matrix more carefully, if needed. Also, note
>>>> that I can solve this problem with direct solvers just fine.
>>> Yes, this seems like a bug, but it could be some strange BC thing I do
>>> not understand.
>> OK, I can look into the matrix in more detail. I agree that it should
>> have a non-zero diagonal, so I'll have a look at what's happening with that.
>>> Naively, the elastic element matrix has a nonzero diagonal. I see that
>>> you are doing LU
>>> of size 5. That seems strange for 3D elasticity. Am I missing something?
>>> I would expect
>>> block size 3.
>> I'm not sure what is causing the LU of size 5. Is there a setting to
>> control that?
>> Regarding the block size: I set the vector and matrix block size to 3
>> via VecSetBlockSize and MatSetBlockSize. I also
>> used MatNullSpaceCreateRigidBody on a vector with block size of 3, and set
>> the matrix's near nullspace using that.
> Can you run this same example with -mat_no_inode? I think it may be a
> strange blocking that is causing this.
That works. The -ksp_view output is below.
David
KSP Object: 1 MPI processes
  type: cg
  maximum iterations=5000
  tolerances:  relative=1e-12, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=5 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
      GAMG specific options
        Threshold for dropping small values from graph 0
        AGG specific options
          Symmetric graph false
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     1 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     1 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 1
        Local solve is same for all blocks, in the following KSP and PC
objects:
        KSP Object:        (mg_coarse_sub_)         1 MPI processes
          type: preonly
        PC Object:        (mg_coarse_sub_)         1 MPI processes
          type: lu
            LU: out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
            matrix ordering: nd
            factor fill ratio given 5, needed 1
              Factored matrix follows:
                Mat Object:                 1 MPI processes
                  type: seqaij
                  rows=30, cols=30, bs=6
                  package used to perform factorization: petsc
                  total: nonzeros=540, allocated nonzeros=540
                  total number of mallocs used during MatSetValues calls =0
                    not using I-node routines
          linear system matrix = precond matrix:
            type: seqaij
        type: seqaij
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = -1.79769e+307, max = -inf
        Chebyshev: eigenvalues estimated using gmres with translations  [0
0.1; 0 1.1]
        KSP Object:        (mg_levels_1_esteig_)         1 MPI processes
          type: gmres
          maximum iterations=10, initial guess is zero
      maximum iterations=2
    PC Object:    (mg_levels_1_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1,
omega = 1
        type: seqaij
        rows=72, cols=72, bs=6
        total: nonzeros=1728, allocated nonzeros=1728
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     1 MPI processes
      type: chebyshev
0.1; 0 1.1]
        KSP Object:        (mg_levels_2_esteig_)         1 MPI processes
          type: gmres
    PC Object:    (mg_levels_2_)     1 MPI processes
      type: sor
omega = 1
        type: seqaij
        rows=174, cols=174, bs=6
        total: nonzeros=5796, allocated nonzeros=5796
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (mg_levels_3_)     1 MPI processes
      type: chebyshev
0.1; 0 1.1]
        KSP Object:        (mg_levels_3_esteig_)         1 MPI processes
          type: gmres
    PC Object:    (mg_levels_3_)     1 MPI processes
      type: sor
omega = 1
        type: seqaij
        rows=828, cols=828, bs=6
        total: nonzeros=44496, allocated nonzeros=44496
  Down solver (pre-smoother) on level 4 -------------------------------
    KSP Object:    (mg_levels_4_)     1 MPI processes
      type: chebyshev
        Chebyshev: eigenvalue estimates:  min = 0.0998367, max = 1.0982
0.1; 0 1.1]
        KSP Object:        (mg_levels_4_esteig_)         1 MPI processes
          type: gmres
    PC Object:    (mg_levels_4_)     1 MPI processes
      type: sor
omega = 1
      Mat Object:      ()       1 MPI processes
        type: seqaij
        rows=2676, cols=2676, bs=3
        total: nonzeros=94014, allocated nonzeros=94014
          has attached near null space
    type: seqaij
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151110/bd147e7c/attachment-0001.html>
