[petsc-users] Use of DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
Tue Nov 10 06:47:37 CST 2015
On Tue, Nov 10, 2015 at 6:30 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 10/11/2015 8:27 PM, Matthew Knepley wrote:
> On Tue, Nov 10, 2015 at 3:27 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> Inside my subroutine, I need to access the DA variable cu_types_array
>> frequently.
>> So I need to call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90 before
>> and after frequently.
>> Is this necessary? Can I call DMDAVecGetArrayF90 at the start and only
>> call DMDAVecRestoreArrayF90 towards the end, where I don't need to modify
>> the values of cu_types_array anymore?
>> Will this cause memory corruption?
> You cannot use any other vector operations before you have called Restore.
> Hi,
> What do you mean by vector operations? I will just be doing some maths
> operation to change the values in cu_types_array. Is that fine?
While you have the array, no other operation can change the values.
   Matt
> Also, must the array be restored using DMDAVecRestoreArrayF90 before
>> calling DMLocalToLocalBegin,DMLocalToLocalEnd?
> Yes.
>   Matt
>> Thank you.
>> Yours sincerely,
>> TAY wee-beng
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151110/05b7f18a/attachment.html>
