[petsc-users] Use of DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90
TAY wee-beng zonexo at gmail.com
Tue Nov 10 03:27:21 CST 2015
Inside my subroutine, I need to access the DA variable cu_types_array
frequently.
So I need to call DMDAVecGetArrayF90 and DMDAVecRestoreArrayF90 before
and after frequently.
Is this necessary? Can I call DMDAVecGetArrayF90 at the start and only
call DMDAVecRestoreArrayF90 towards the end, where I don't need to
modify the values of cu_types_array anymore?
Will this cause memory corruption?
Also, must the array be restored using DMDAVecRestoreArrayF90 before
calling DMLocalToLocalBegin,DMLocalToLocalEnd?
Thank you.
Yours sincerely,
TAY wee-beng
