[petsc-users] DM structures of PetscInt
TAY wee-beng zonexo at gmail.com
Mon Nov 9 08:33:39 CST 2015
On 9/11/2015 2:08 AM, Barry Smith wrote:
>> On Nov 8, 2015, at 7:37 AM, Wee Beng Tay <zonexo at gmail.com> wrote:
>> Sent using CloudMagic Email
>> On Sun, Nov 08, 2015 at 7:41 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sat, Nov 7, 2015 at 11:27 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I need to use DM structures of type PETScInt.
>> I tried to use:
>> DM da_cu_types
>> Vec cu_types_local,cu_types_global
>> PetscInt,pointer :: cu_types_array(:,:,:)
>> Is this allowed? The cu_types_array is to be of integer type. Because I got into problems compiling.
>> We do not support integer Vecs. You should use IS. What are you trying to do?
>> Matt
>> Hi,
>> I've a cfd code and I need to separate cells inside or outside a body. I denote the inside /boundary /outside cells as type =2/1/0. I've a subroutine which determines the type in parallel and hence I need a Vec with integer type.
>     The simplest thing is just to use a real value of 2. 1. or 0.  Memoywise it is not a big deal since you will have dozens of vectors plus memory heavy matrix so you won't even notice this extra memory.
Ya, thought that this is simpler. It's working now. Thanks.
>> Based on my description, can I use Is? Is there an example I can follow?
>> Thanks
>> Thank you.
>> Yours sincerely,
>> TAY wee-beng
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
