[petsc-users] [petsc-dev] [SLEPc] For users of PETSc master branch, API change
Leoni, Massimiliano Massimiliano.Leoni at Rolls-Royce.com
Mon Nov 9 08:23:31 CST 2015
Is there a branch in the SLEPc repo that supports this?
Massimiliano
> -----Original Message-----
> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-
> bounces at mcs.anl.gov] On Behalf Of Barry Smith
> Sent: 09 November 2015 00:21
> To: PETSc; petsc-dev
> Subject: [petsc-dev] For users of PETSc master branch, API change
>    For users of the PETSc master branch.
>    I have pushed into master some API changes for the PetscOptionsGetXXX()
> and related routines. The first argument is now a PetscOptions object, which
> is optional, if you pass a NULL in for the first argument (or a
> PETSC_NULL_OBJECT in Fortran) you will retain the same functionality as you
> had previously.
>    Barry
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
(c) 2015 Rolls-Royce plc
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
