[petsc-users] CG+GAMG convergence issues in GHEP Krylov-Schur for some MPI runs
Fri Nov 6 09:32:59 CST 2015
On Fri, Nov 6, 2015 at 9:29 AM, Denis Davydov <davydden at gmail.com> wrote:
> > On 6 Nov 2015, at 16:22, Matthew Knepley <knepley at gmail.com> wrote:
> > Is it possible that the matrix is rank deficient? Jacobi will just chug
> along and sometimes work, but
> > AMG will fail spectacularly in that case.
> It should not. It is just a mass (overlap) matrix coming from linear FEs
> with zero Dirichlet BC assembled in deal.II.
> Due to elimination of some algebraic constraints on DoFs there are lines
> with only diagonal element,
> but it should still be SPD.
> More interestingly is that it does not fail immediately (i.e. the first
> time it’s used in SLEPc solvers),
> but only on the 4th step. So 3 times SLEPc worked just fine to solve GHEP
> with Gamg and zero shift.
Then I think it is not doing what you suppose. I am not inclined to believe
that it behaves differently on the
same matrix.
   Matt
> Regards,
> Denis.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151106/de605a1f/attachment.html>
