[petsc-users] PetscOptionsGetString Not Finding Option
Jared Crean jcrean01 at gmail.com
Tue Nov 3 21:50:40 CST 2015
     Hello Matt,
         There was a problem with the way I was doing the tests, not
with PetscOptionsGetString.  PetscOptionsGetString now behaves as
expected in all tests.  Sorry for the confusion.
         Jared Crean
On 11/03/2015 10:37 PM, Jared Crean wrote:
>     Hello Matt,
>         Ok, something weird is going on.  Some of my test cases are
> behaving strangely (the output of the test in my previous message is
> the expected behavior, but previously the test gave different
> results).  Let me figure out what is going on with the tests before
> proceeding.
>     Jared Crean
> On 11/03/2015 10:07 PM, Matthew Knepley wrote:
>> On Sat, Oct 31, 2015 at 7:52 PM, Jared Crean <jcrean01 at gmail.com
>> <mailto:jcrean01 at gmail.com>> wrote:
>>     Hello,
>>         I am trying to use PetscOptionsGetString to retrieve the
>>     value of an option in the options database, but the value
>>     returned in the last argument indicates the option was not
>>     found.   In the attached code (a modified version of ksp example
>>     2), the string "-ksp_pc_side" is passed in as the argument name.
>>     If I run the code as
>>         ./jc2 -pc_type ilu -ksp_pc_side right
>>         I get the output:
>>         option -ksp_pc_side was found
>> You gave the options and the program says it was found. What is the
>> problem here?
>>    Matt
>>     from line 71 of the file.  Petsc does not complain of unused
>>     options when the program finishes.  Am I using this function
>>     incorrectly?
>>         Jared Crean
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151103/d0c1de68/attachment-0001.html>
