[petsc-users] Scaling with number of cores
TAY wee-beng zonexo at gmail.com
Tue Nov 3 09:16:23 CST 2015
On 3/11/2015 9:01 PM, Matthew Knepley wrote:
> On Tue, Nov 3, 2015 at 6:58 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     On 3/11/2015 8:52 PM, Matthew Knepley wrote:
>>     On Tue, Nov 3, 2015 at 6:49 AM, TAY wee-beng <zonexo at gmail.com
>>         Hi,
>>         I tried and have attached the log.
>>         Ya, my Poisson eqn has Neumann boundary condition. Do I need
>>         to specify some null space stuff?  Like KSPSetNullSpace or
>>         MatNullSpaceCreate?
>>     Yes, you need to attach the constant null space to the matrix.
>>       Thanks,
>>          Matt
>     Ok so can you point me to a suitable example so that I know which
>     one to use specifically?
> https://bitbucket.org/petsc/petsc/src/9ae8fd060698c4d6fc0d13188aca8a1828c138ab/src/snes/examples/tutorials/ex12.c?at=master&fileviewer=file-view-default#ex12.c-761
>   Matt
Oh ya,
How do I call:
call MatNullSpaceCreate(MPI_COMM_WORLD,PETSC_TRUE,0,NULL,nullsp,ierr)
But it says NULL is not defined. How do I define it?
Thanks
>     Thanks.
>>         Thank you
>>         Yours sincerely,
>>         TAY wee-beng
>>         On 3/11/2015 12:45 PM, Barry Smith wrote:
>>                 On Nov 2, 2015, at 10:37 PM, TAY
>>                 wee-beng<zonexo at gmail.com <mailto:zonexo at gmail.com>>
>>                 wrote:
>>                 Hi,
>>                 I tried :
>>                 1. -poisson_pc_gamg_agg_nsmooths 1 -poisson_pc_type gamg
>>                 2. -poisson_pc_type gamg
>>                 Run with -poisson_ksp_monitor_true_residual
>>             -poisson_ksp_monitor_converged_reason
>>             Does your poisson have Neumann boundary conditions? Do
>>             you have any zeros on the diagonal for the matrix (you
>>             shouldn't).
>>                There may be something wrong with your poisson
>>             discretization that was also messing up hypre
>>                 Both options give:
>>                     1      0.00150000      0.00000000     0.00000000
>>                 1.00000000  NaN             NaN             NaN
>>                 M Diverged but why?, time = 2
>>                 reason =           -9
>>                 How can I check what's wrong?
>>                 Thank you
>>                 Yours sincerely,
>>                 TAY wee-beng
>>                 On 3/11/2015 3:18 AM, Barry Smith wrote:
>>                         hypre is just not scaling well here. I do not
>>                     know why. Since hypre is a block box for us there
>>                     is no way to determine why the poor scaling.
>>                         If you make the same two runs with -pc_type
>>                     gamg there will be a lot more information in the
>>                     log summary about in what routines it is scaling
>>                     well or poorly.
>>                        Barry
>>                         On Nov 2, 2015, at 3:17 AM, TAY
>>                         Hi,
>>                         I have attached the 2 files.
>>                         Thank you
>>                         Yours sincerely,
>>                         TAY wee-beng
>>                         On 2/11/2015 2:55 PM, Barry Smith wrote:
>>                                Run (158/2)x(266/2)x(150/2) grid on 8
>>                             processes  and then (158)x(266)x(150) on
>>                             64 processors  and send the two
>>                             -log_summary results
>>                                Barry
>>                                 On Nov 2, 2015, at 12:19 AM, TAY
>>                                 Hi,
>>                                 I have attached the new results.
>>                                 Thank you
>>                                 Yours sincerely,
>>                                 TAY wee-beng
>>                                 On 2/11/2015 12:27 PM, Barry Smith wrote:
>>                                        Run without the
>>                                     -momentum_ksp_view
>>                                     -poisson_ksp_view and send the
>>                                     new results
>>                                        You can see from the log
>>                                     summary that the PCSetUp is
>>                                     taking a much smaller percentage
>>                                     of the time meaning that it is
>>                                     reusing the preconditioner and
>>                                     not rebuilding it each time.
>>                                     Barry
>>                                        Something makes no sense with
>>                                     the output: it gives
>>                                     KSPSolve             199 1.0
>>                                     2.3298e+03 1.0 5.20e+09 1.8
>>                                     3.8e+04 9.9e+05 5.0e+02 90100
>>                                     66100 24  90100 66100 24   165
>>                                     90% of the time is in the solve
>>                                     but there is no significant
>>                                     amount of time in other events of
>>                                     the code which is just not
>>                                     possible. I hope it is due to
>>                                     your IO.
>>                                         On Nov 1, 2015, at 10:02 PM,
>>                                         TAY wee-beng<zonexo at gmail.com
>>                                         Hi,
>>                                         I have attached the new run
>>                                         with 100 time steps for 48
>>                                         and 96 cores.
>>                                         Only the Poisson eqn 's RHS
>>                                         changes, the LHS doesn't. So
>>                                         if I want to reuse the
>>                                         preconditioner, what must I
>>                                         do? Or what must I not do?
>>                                         Why does the number of
>>                                         processes increase so much?
>>                                         Is there something wrong with
>>                                         my coding? Seems to be so too
>>                                         for my new run.
>>                                         Thank you
>>                                         Yours sincerely,
>>                                         TAY wee-beng
>>                                         On 2/11/2015 9:49 AM, Barry
>>                                         Smith wrote:
>>                                                If you are doing many
>>                                             time steps with the same
>>                                             linear solver then you
>>                                             MUST do your weak scaling
>>                                             studies with MANY time
>>                                             steps since the setup
>>                                             time of AMG only takes
>>                                             place in the first
>>                                             stimestep. So run both 48
>>                                             and 96 processes with the
>>                                             same large number of time
>>                                             steps.
>>                                                Barry
>>                                                 On Nov 1, 2015, at
>>                                                 7:35 PM, TAY
>>                                                 wrote:
>>                                                 Hi,
>>                                                 Sorry I forgot and
>>                                                 use the old a.out. I
>>                                                 log for 48cores
>>                                                 (log48), together
>>                                                 with the 96cores log
>>                                                 (log96).
>>                                                 Why does the number
>>                                                 of processes increase
>>                                                 so much? Is there
>>                                                 my coding?
>>                                                 's RHS changes, the
>>                                                 LHS doesn't. So if I
>>                                                 want to reuse the
>>                                                 must I do? Or what
>>                                                 must I not do?
>>                                                 Lastly, I only
>>                                                 simulated 2 time
>>                                                 steps previously. Now
>>                                                 I run for 10
>>                                                 timesteps (log48_10).
>>                                                 Is it building the
>>                                                 preconditioner at
>>                                                 every timestep?
>>                                                 Also, what about
>>                                                 momentum eqn? Is it
>>                                                 working well?
>>                                                 I will try the gamg
>>                                                 later too.
>>                                                 Thank you
>>                                                 Yours sincerely,
>>                                                 TAY wee-beng
>>                                                 On 2/11/2015 12:30
>>                                                        You used gmres
>>                                                     with 48 processes
>>                                                     but richardson
>>                                                     with 96. You need
>>                                                     to be careful and
>>                                                     make sure you
>>                                                     don't change the
>>                                                     solvers when you
>>                                                     change the number
>>                                                     of processors
>>                                                     since you can get
>>                                                     very different
>>                                                     inconsistent results
>>                                                         Anyways all
>>                                                     the time is being
>>                                                     spent in the
>>                                                     BoomerAMG
>>                                                     algebraic
>>                                                     multigrid setup
>>                                                     and it is is
>>                                                     scaling badly.
>>                                                     When you double
>>                                                     the problem size
>>                                                     and number of
>>                                                     processes it went
>>                                                     from 3.2445e+01
>>                                                     to 4.3599e+02
>>                                                     seconds.
>>                                                     PCSetUp   3 1.0
>>                                                     3.2445e+01 1.0
>>                                                     9.58e+06 2.0
>>                                                     0.0e+00 0.0e+00
>>                                                     4.0e+00 62  8  0
>>                                                     0 4  62  8  0  0
>>                                                     5 11
>>                                                     PCSetUp   3 1.0
>>                                                     4.3599e+02 1.0
>>                                                     9.58e+06 2.0
>>                                                     0.0e+00 0.0e+00
>>                                                     4.0e+00 85 18  0
>>                                                     0 6  85 18  0  0
>>                                                     6  2
>>                                                        Now is the
>>                                                     Poisson problem
>>                                                     changing at each
>>                                                     timestep or can
>>                                                     you use the same
>>                                                     preconditioner
>>                                                     built with
>>                                                     BoomerAMG for all
>>                                                     the time steps?
>>                                                     Algebraic
>>                                                     multigrid has a
>>                                                     large set up time
>>                                                     that you often
>>                                                     doesn't matter if
>>                                                     you have many
>>                                                     time steps but if
>>                                                     you have to
>>                                                     rebuild it each
>>                                                     timestep it is
>>                                                     too large?
>>                                                        You might also
>>                                                     try -pc_type gamg
>>                                                     and see how
>>                                                     PETSc's algebraic
>>                                                     multigrid scales
>>                                                     for your
>>                                                     problem/machine.
>>                                                        Barry
>>                                                         On Nov 1,
>>                                                         2015, at 7:30
>>                                                         AM, TAY
>>                                                         wrote:
>>                                                         On 1/11/2015
>>                                                         10:00 AM,
>>                                                         Barry Smith
>>                                                         wrote:
>>        On
>>        Oct
>>        31,
>>        2015,
>>        at
>>        8:43
>>        PM,
>>        TAY
>>        wrote:
>>        On
>>        1/11/2015
>>        12:47
>>        AM,
>>        Matthew
>>        Knepley
>>        wrote:
>>        On Sat,
>>        Oct
>>        31,
>>        2015
>>        at 11:34
>>        AM,
>>        TAY
>>        wrote:
>>        Hi,
>>        I
>>        understand
>>        that
>>        as mentioned
>>        in the
>>        faq,
>>        due
>>        to the
>>        limitations
>>        in memory,
>>        the
>>        scaling
>>        is not
>>        linear.
>>        So,
>>        I
>>        am trying
>>        to write
>>        a
>>        proposal
>>        to use
>>        a
>>        supercomputer.
>>        Its
>>        specs
>>        are:
>>        Compute
>>        nodes:
>>        82,944
>>        nodes
>>        (SPARC64
>>        VIIIfx;
>>        16GB
>>        of memory
>>        per
>>        node)
>>        8
>>        cores
>>        processor
>>        Interconnect:
>>        Tofu
>>        (6-dimensional
>>        mesh/torus)
>>        Interconnect
>>        Each
>>        cabinet
>>        contains
>>        96 computing
>>        nodes,
>>        One
>>        of the
>>        requirement
>>        is to
>>        give
>>        the
>>        performance
>>        of my
>>        current
>>        code
>>        with
>>        my current
>>        set
>>        of data,
>>        and
>>        there
>>        is a
>>        formula
>>        to calculate
>>        the
>>        estimated
>>        parallel
>>        efficiency
>>        when
>>        using
>>        the
>>        new
>>        large
>>        set
>>        of data
>>        There
>>        are
>>        2
>>        ways
>>        to give
>>        performance:
>>        1. Strong
>>        scaling,
>>        which
>>        is defined
>>        as how
>>        the
>>        elapsed
>>        time
>>        varies
>>        with
>>        the
>>        number
>>        of processors
>>        for
>>        a
>>        fixed
>>        problem.
>>        2. Weak
>>        scaling,
>>        which
>>        is defined
>>        as how
>>        the
>>        elapsed
>>        time
>>        varies
>>        with
>>        the
>>        number
>>        of processors
>>        for a
>>        fixed
>>        problem
>>        size
>>        per
>>        processor.
>>        I
>>        ran
>>        my cases
>>        with
>>        48 and
>>        96 cores
>>        with
>>        my current
>>        cluster,
>>        giving
>>        140
>>        and
>>        90 mins
>>        respectively.
>>        This
>>        is classified
>>        as strong
>>        scaling.
>>        Cluster
>>        specs:
>>        CPU:
>>        AMD
>>        6234
>>        2.4GHz
>>        8
>>        cores
>>        processor
>>        (CPU)
>>        6
>>        CPU
>>        node
>>        So 48
>>        Cores
>>        / CPU
>>        Not
>>        sure
>>        abt
>>        the
>>        memory
>>        node
>>        The
>>        parallel
>>        efficiency
>>        ‘En’
>>        for
>>        a
>>        given
>>        degree
>>        of parallelism
>>        ‘n’
>>        indicates
>>        how
>>        much
>>        the
>>        program
>>        is
>>        efficiently
>>        accelerated
>>        by parallel
>>        processing.
>>        ‘En’
>>        is given
>>        by the
>>        following
>>        formulae.
>>        Although
>>        their
>>        derivation
>>        processes
>>        are
>>        different
>>        depending
>>        on strong
>>        and
>>        weak
>>        scaling,
>>        derived
>>        formulae
>>        are
>>        the
>>        same.
>>        From
>>        the
>>        estimated
>>        time,
>>        my parallel
>>        efficiency
>>        using
>>        Amdahl's
>>        law
>>        on the
>>        current
>>        old
>>        cluster
>>        was
>>        52.7%.
>>        So is
>>        my results
>>        acceptable?
>>        For
>>        the
>>        large
>>        data
>>        set,
>>        if using
>>        2205
>>        nodes
>>        (2205X8cores),
>>        my expected
>>        parallel
>>        efficiency
>>        is only
>>        0.5%.
>>        The
>>        proposal
>>        recommends
>>        value
>>        of >
>>        50%.
>>        The
>>        problem
>>        with
>>        this
>>        analysis
>>        is that
>>        the
>>        estimated
>>        serial
>>        fraction
>>        from
>>        Amdahl's
>>        Law
>>        changes
>>        as a
>>        function
>>        of problem
>>        size,
>>        so you
>>        cannot
>>        take
>>        the
>>        strong
>>        scaling
>>        from
>>        one
>>        problem
>>        and
>>        apply
>>        it to
>>        another
>>        without
>>        a
>>        model
>>        of this
>>        dependence.
>>        Weak
>>        scaling
>>        does
>>        model
>>        changes
>>        with
>>        problem
>>        size,
>>        so I
>>        would
>>        measure
>>        weak
>>        scaling
>>        on your
>>        current
>>        cluster,
>>        and
>>        extrapolate
>>        to the
>>        big
>>        machine.
>>        I
>>        realize
>>        that
>>        this
>>        does
>>        not
>>        make
>>        sense
>>        for
>>        many
>>        scientific
>>        applications,
>>        but
>>        neither
>>        does
>>        requiring
>>        a
>>        certain
>>        parallel
>>        efficiency.
>>        Ok I
>>        check
>>        the
>>        results
>>        for
>>        my
>>        weak
>>        scaling
>>        it is
>>        even
>>        worse
>>        for
>>        the
>>        expected
>>        parallel
>>        efficiency.
>>        From
>>        the
>>        formula
>>        used,
>>        it's
>>        obvious
>>        it's
>>        doing
>>        some
>>        sort
>>        of
>>        exponential
>>        extrapolation
>>        decrease.
>>        So
>>        unless I
>>        can
>>        achieve
>>        a
>>        near
>>        > 90%
>>        speed
>>        up
>>        when
>>        I
>>        double the
>>        cores
>>        and
>>        problem
>>        size
>>        for
>>        my
>>        current
>>        48/96
>>        cores
>>        setup,  extrapolating
>>        from
>>        about
>>        96
>>        nodes
>>        to
>>        10,000 nodes
>>        will
>>        give
>>        a
>>        much
>>        lower
>>        expected
>>        parallel
>>        efficiency
>>        for
>>        the
>>        new case.
>>        However,
>>        it's
>>        mentioned
>>        in
>>        the
>>        FAQ
>>        that
>>        due
>>        to
>>        memory requirement,
>>        it's
>>        impossible
>>        to
>>        get
>>        >90%
>>        speed
>>        when
>>        I
>>        double the
>>        cores
>>        and
>>        problem
>>        size
>>        (ie
>>        linear increase
>>        in
>>        performance),
>>        which
>>        means
>>        that
>>        I
>>        can't
>>        get
>>        >90%
>>        speed
>>        up
>>        when
>>        I
>>        double the
>>        cores
>>        and
>>        problem
>>        size
>>        for
>>        my
>>        current
>>        48/96
>>        cores
>>        setup. Is
>>        that so?
>>        What
>>                                                             is the
>>                                                             output of
>>                                                             -ksp_view
>>                                                             -log_summary
>>                                                             on the
>>                                                             problem
>>                                                             and then
>>                                                             on the
>>                                                             problem
>>                                                             doubled
>>                                                             in size
>>                                                             and
>>                                                             number of
>>                                                             processors?
>>        Barry
>>                                                         Hi,
>>                                                         I have
>>                                                         attached the
>>                                                         output
>>                                                         48 cores: log48
>>                                                         96 cores: log96
>>                                                         There are 2
>>                                                         solvers - The
>>                                                         momentum
>>                                                         linear eqn
>>                                                         uses bcgs,
>>                                                         while the
>>                                                         Poisson eqn
>>                                                         uses hypre
>>                                                         BoomerAMG.
>>                                                         Problem size
>>                                                         doubled from
>>                                                         158x266x150
>>                                                         to 158x266x300.
>>        So is
>>        it
>>        fair
>>        to
>>        say
>>        that
>>        the
>>        main
>>        problem
>>        does
>>        not
>>        lie
>>        in my
>>        programming
>>        skills,
>>        but
>>        rather the
>>        way
>>        the
>>        linear equations
>>        are
>>        solved?
>>        Thanks.
>>        Thanks,
>>        Matt
>>        Is it
>>        possible
>>        for
>>        this
>>        type
>>        of scaling
>>        in PETSc
>>        (>50%),
>>        when
>>        using
>>        17640
>>        (2205X8)
>>        cores?
>>        Btw,
>>        I
>>        do not
>>        have
>>        access
>>        to the
>>        system.
>>        Sent
>>        using
>>        CloudMagic
>>        Email
>>        What
>>        most
>>        experimenters
>>        take
>>        for
>>        granted
>>        before
>>        they
>>        begin
>>        their
>>        experiments
>>        is infinitely
>>        more
>>        interesting
>>        than
>>        any
>>        results
>>        to which
>>        their
>>        experiments
>>        lead.
>>        -- Norbert
>>        Wiener
>>                                                         <log48.txt><log96.txt>
>>                                                 <log48_10.txt><log48.txt><log96.txt>
>>                                         <log96_100.txt><log48_100.txt>
>>                                 <log96_100_2.txt><log48_100_2.txt>
>>                         <log64_100.txt><log8_100.txt>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151103/ec680c23/attachment-0001.html>
