[petsc-users] Scaling with number of cores
TAY wee-beng zonexo at gmail.com
Tue Nov 3 06:58:23 CST 2015
On 3/11/2015 8:52 PM, Matthew Knepley wrote:
> On Tue, Nov 3, 2015 at 6:49 AM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I tried and have attached the log.
>     Ya, my Poisson eqn has Neumann boundary condition. Do I need to
>     specify some null space stuff?  Like KSPSetNullSpace or
>     MatNullSpaceCreate?
> Yes, you need to attach the constant null space to the matrix.
>   Thanks,
>      Matt
Ok so can you point me to a suitable example so that I know which one to
use specifically?
Thanks.
>     Thank you
>     Yours sincerely,
>     TAY wee-beng
>     On 3/11/2015 12:45 PM, Barry Smith wrote:
>             On Nov 2, 2015, at 10:37 PM, TAY wee-beng<zonexo at gmail.com
>             Hi,
>             I tried :
>             1. -poisson_pc_gamg_agg_nsmooths 1 -poisson_pc_type gamg
>             2. -poisson_pc_type gamg
>             Run with -poisson_ksp_monitor_true_residual
>         -poisson_ksp_monitor_converged_reason
>         Does your poisson have Neumann boundary conditions? Do you
>         have any zeros on the diagonal for the matrix (you shouldn't).
>            There may be something wrong with your poisson
>         discretization that was also messing up hypre
>             Both options give:
>                 1      0.00150000      0.00000000 0.00000000
>             1.00000000             NaN  NaN             NaN
>             M Diverged but why?, time =            2
>             reason =           -9
>             How can I check what's wrong?
>             Thank you
>             Yours sincerely,
>             TAY wee-beng
>             On 3/11/2015 3:18 AM, Barry Smith wrote:
>                     hypre is just not scaling well here. I do not know
>                 why. Since hypre is a block box for us there is no way
>                 to determine why the poor scaling.
>                     If you make the same two runs with -pc_type gamg
>                 there will be a lot more information in the log
>                 summary about in what routines it is scaling well or
>                 poorly.
>                    Barry
>                     On Nov 2, 2015, at 3:17 AM, TAY
>                     Hi,
>                     I have attached the 2 files.
>                     Thank you
>                     Yours sincerely,
>                     TAY wee-beng
>                     On 2/11/2015 2:55 PM, Barry Smith wrote:
>                            Run (158/2)x(266/2)x(150/2) grid on 8
>                         processes  and then (158)x(266)x(150) on 64
>                         processors  and send the two -log_summary results
>                            Barry
>                             On Nov 2, 2015, at 12:19 AM, TAY
>                             Hi,
>                             I have attached the new results.
>                             Thank you
>                             Yours sincerely,
>                             TAY wee-beng
>                             On 2/11/2015 12:27 PM, Barry Smith wrote:
>                                    Run without the -momentum_ksp_view
>                                 -poisson_ksp_view and send the new results
>                                    You can see from the log summary
>                                 that the PCSetUp is taking a much
>                                 smaller percentage of the time meaning
>                                 that it is reusing the preconditioner
>                                 and not rebuilding it each time.
>                                 Barry
>                                    Something makes no sense with the
>                                 output: it gives
>                                 KSPSolve             199 1.0
>                                 2.3298e+03 1.0 5.20e+09 1.8 3.8e+04
>                                 9.9e+05 5.0e+02 90100 66100 24  90100
>                                 66100 24   165
>                                 90% of the time is in the solve but
>                                 there is no significant amount of time
>                                 in other events of the code which is
>                                 just not possible. I hope it is due to
>                                 your IO.
>                                     On Nov 1, 2015, at 10:02 PM, TAY
>                                     Hi,
>                                     I have attached the new run with
>                                     100 time steps for 48 and 96 cores.
>                                     Only the Poisson eqn 's RHS
>                                     changes, the LHS doesn't. So if I
>                                     want to reuse the preconditioner,
>                                     what must I do? Or what must I not do?
>                                     Why does the number of processes
>                                     increase so much? Is there
>                                     something wrong with my coding?
>                                     Seems to be so too for my new run.
>                                     Thank you
>                                     Yours sincerely,
>                                     TAY wee-beng
>                                     On 2/11/2015 9:49 AM, Barry Smith
>                                     wrote:
>                                            If you are doing many time
>                                         steps with the same linear
>                                         solver then you MUST do your
>                                         weak scaling studies with MANY
>                                         time steps since the setup
>                                         time of AMG only takes place
>                                         in the first stimestep. So run
>                                         both 48 and 96 processes with
>                                         the same large number of time
>                                         steps.
>                                            Barry
>                                             On Nov 1, 2015, at 7:35
>                                             PM, TAY
>                                             wrote:
>                                             Hi,
>                                             Sorry I forgot and use the
>                                             old a.out. I have attached
>                                             the new log for 48cores
>                                             (log48), together with the
>                                             96cores log (log96).
>                                             processes increase so
>                                             much? Is there something
>                                             RHS changes, the LHS
>                                             doesn't. So if I want to
>                                             must I not do?
>                                             Lastly, I only simulated 2
>                                             time steps previously. Now
>                                             I run for 10 timesteps
>                                             (log48_10). Is it building
>                                             the preconditioner at
>                                             every timestep?
>                                             Also, what about momentum
>                                             eqn? Is it working well?
>                                             I will try the gamg later too.
>                                             Thank you
>                                             Yours sincerely,
>                                             TAY wee-beng
>                                             On 2/11/2015 12:30 AM,
>                                             Barry Smith wrote:
>                                                    You used gmres with
>                                                 48 processes but
>                                                 richardson with 96.
>                                                 You need to be careful
>                                                 and make sure you
>                                                 don't change the
>                                                 solvers when you
>                                                 change the number of
>                                                 processors since you
>                                                 can get very different
>                                                 inconsistent results
>                                                     Anyways all the
>                                                 time is being spent in
>                                                 the BoomerAMG
>                                                 algebraic multigrid
>                                                 setup and it is is
>                                                 scaling badly. When
>                                                 you double the problem
>                                                 size and number of
>                                                 processes it went from
>                                                 3.2445e+01 to
>                                                 4.3599e+02 seconds.
>                                                 PCSetUp
>                                                 3 1.0 3.2445e+01 1.0
>                                                 9.58e+06 2.0 0.0e+00
>                                                 0.0e+00 4.0e+00 62  8
>                                                 0  0  4  62  8  0  0
>                                                 5    11
>                                                 PCSetUp
>                                                 3 1.0 4.3599e+02 1.0
>                                                 0.0e+00 4.0e+00 85 18
>                                                 0  0  6  85 18  0  0
>                                                 6     2
>                                                    Now is the Poisson
>                                                 problem changing at
>                                                 each timestep or can
>                                                 you use the same
>                                                 preconditioner built
>                                                 with BoomerAMG for all
>                                                 the time steps?
>                                                 Algebraic multigrid
>                                                 has a large set up
>                                                 time that you often
>                                                 doesn't matter if you
>                                                 have many time steps
>                                                 but if you have to
>                                                 rebuild it each
>                                                 timestep it is too large?
>                                                    You might also try
>                                                 -pc_type gamg and see
>                                                 how PETSc's algebraic
>                                                 multigrid scales for
>                                                 your problem/machine.
>                                                    Barry
>                                                     On Nov 1, 2015, at
>                                                     7:30 AM, TAY
>                                                     wrote:
>                                                     On 1/11/2015 10:00
>                                                             On Oct 31,
>                                                             2015, at
>                                                             8:43 PM,
>                                                             TAY
>                                                             wrote:
>                                                             On
>                                                             1/11/2015
>                                                             12:47 AM,
>                                                             Matthew
>                                                             Knepley wrote:
>        On
>        Sat,
>        Oct
>        31,
>        2015
>        at
>        11:34
>        AM,
>        TAY
>        wrote:
>        Hi,
>        I
>        understand
>        that
>        as
>        mentioned
>        in the
>        faq,
>        due to
>        the
>        limitations
>        in
>        memory, the
>        scaling is
>        not
>        linear. So,
>        I am
>        trying
>        to
>        write
>        a
>        proposal
>        to use
>        a
>        supercomputer.
>        Its
>        specs are:
>        Compute nodes:
>        82,944
>        nodes
>        (SPARC64
>        VIIIfx; 16GB
>        of
>        memory
>        per node)
>        8
>        cores
>        processor
>        Interconnect:
>        Tofu
>        (6-dimensional
>        mesh/torus)
>        Interconnect
>        Each
>        cabinet contains
>        96
>        computing
>        nodes,
>        One of
>        the
>        requirement
>        is to
>        give
>        the
>        performance
>        of my
>        current code
>        with
>        my
>        current set
>        of
>        data,
>        and
>        there
>        is a
>        formula to
>        calculate
>        the
>        estimated
>        parallel
>        efficiency
>        when
>        using
>        the
>        new
>        large
>        set of
>        data
>        There
>        are 2
>        ways
>        to
>        give
>        performance:
>        1.
>        Strong
>        scaling,
>        which
>        is
>        defined as
>        how
>        the
>        elapsed time
>        varies
>        with
>        the
>        number
>        of
>        processors
>        for a
>        fixed
>        problem.
>        2.
>        Weak
>        scaling,
>        which
>        is
>        defined as
>        how
>        the
>        elapsed time
>        varies
>        with
>        the
>        number
>        of
>        processors
>        for a
>        fixed
>        problem size
>        per
>        processor.
>        I ran
>        my
>        cases
>        with
>        48 and
>        96
>        cores
>        with
>        my
>        current cluster,
>        giving
>        140
>        and 90
>        mins
>        respectively.
>        This
>        is
>        classified
>        as
>        strong
>        scaling.
>        Cluster specs:
>        CPU:
>        AMD
>        6234
>        2.4GHz
>        8
>        cores
>        processor
>        (CPU)
>        6 CPU
>        / node
>        So 48
>        Cores
>        / CPU
>        Not
>        sure
>        abt
>        the
>        memory
>        / node
>        The
>        parallel
>        efficiency
>        ‘En’
>        for a
>        given
>        degree
>        of
>        parallelism
>        ‘n’
>        indicates
>        how
>        much
>        the
>        program is
>        efficiently
>        accelerated
>        by
>        parallel
>        processing.
>        ‘En’
>        is
>        given
>        by the
>        following
>        formulae.
>        Although
>        their
>        derivation
>        processes
>        are
>        different
>        depending
>        on
>        strong
>        and
>        weak
>        scaling,
>        derived formulae
>        are the
>        same.
>        From
>        the
>        estimated
>        time,
>        my
>        parallel
>        efficiency
>        using
>        Amdahl's
>        law on
>        the
>        current old
>        cluster was
>        52.7%.
>        So is
>        my
>        results acceptable?
>        For
>        the
>        large
>        data
>        set,
>        if
>        using
>        2205
>        nodes
>        (2205X8cores),
>        my
>        expected
>        parallel
>        efficiency
>        is
>        only
>        0.5%.
>        The
>        proposal
>        recommends
>        value
>        of > 50%.
>        The
>        problem with
>        this
>        analysis
>        is
>        that
>        the
>        estimated
>        serial
>        fraction
>        from
>        Amdahl's
>        Law
>        changes as
>        a function
>        of
>        problem size,
>        so you
>        cannot
>        take
>        the
>        strong
>        scaling from
>        one
>        problem and
>        apply
>        it to
>        another without
>        a
>        model
>        of
>        this
>        dependence.
>        Weak
>        scaling does
>        model
>        changes with
>        problem size,
>        so I
>        would
>        measure weak
>        scaling on
>        your
>        current
>        cluster,
>        and
>        extrapolate
>        to the
>        big
>        machine.
>        I
>        realize that
>        this
>        does
>        not
>        make
>        sense
>        for
>        many
>        scientific
>        applications,
>        but
>        neither does
>        requiring
>        a
>        certain parallel
>        efficiency.
>                                                             Ok I check
>                                                             the
>                                                             results
>                                                             for my
>                                                             weak
>                                                             scaling it
>                                                             is even
>                                                             worse for
>                                                             the
>                                                             expected
>                                                             parallel
>                                                             efficiency. From
>                                                             the
>                                                             formula
>                                                             used, it's
>                                                             obvious
>                                                             it's doing
>                                                             some sort
>                                                             of
>                                                             exponential extrapolation
>                                                             decrease.
>                                                             So unless
>                                                             I can
>                                                             achieve a
>                                                             near > 90%
>                                                             speed up
>                                                             when I
>                                                             double the
>                                                             cores and
>                                                             problem
>                                                             size for
>                                                             my current
>                                                             48/96
>                                                             cores
>                                                             setup,
>                                                              extrapolating
>                                                             from about
>                                                             96 nodes
>                                                             to 10,000
>                                                             nodes will
>                                                             give a
>                                                             much lower
>                                                             expected
>                                                             parallel
>                                                             efficiency
>                                                             for the
>                                                             new case.
>                                                             However,
>                                                             it's
>                                                             mentioned
>                                                             in the FAQ
>                                                             that due
>                                                             to memory
>                                                             requirement,
>                                                             it's
>                                                             impossible
>                                                             to get
>                                                             >90% speed
>                                                             when I
>                                                             double the
>                                                             cores and
>                                                             problem
>                                                             size (ie
>                                                             linear
>                                                             increase
>                                                             in
>                                                             performance),
>                                                             which
>                                                             means that
>                                                             I can't
>                                                             get >90%
>                                                             speed up
>                                                             when I
>                                                             double the
>                                                             cores and
>                                                             problem
>                                                             size for
>                                                             my current
>                                                             48/96
>                                                             cores
>                                                             setup. Is
>                                                             that so?
>                                                            What is the
>                                                         output of
>                                                         -ksp_view
>                                                         -log_summary
>                                                         on the problem
>                                                         and then on
>                                                         the problem
>                                                         doubled in
>                                                         size and
>                                                         number of
>                                                         processors?
>                                                            Barry
>                                                     Hi,
>                                                     I have attached
>                                                     the output
>                                                     48 cores: log48
>                                                     96 cores: log96
>                                                     There are 2
>                                                     solvers - The
>                                                     momentum linear
>                                                     eqn uses bcgs,
>                                                     while the Poisson
>                                                     eqn uses hypre
>                                                     BoomerAMG.
>                                                     Problem size
>                                                     doubled from
>                                                     158x266x150 to
>                                                     158x266x300.
>                                                             So is it
>                                                             fair to
>                                                             say that
>                                                             the main
>                                                             problem
>                                                             does not
>                                                             lie in my
>                                                             programming skills,
>                                                             but rather
>                                                             the way
>                                                             the linear
>                                                             equations
>                                                             are solved?
>                                                             Thanks.
>        Thanks,
>        Matt
>        Is it
>        possible
>        for
>        this
>        type
>        of
>        scaling in
>        PETSc
>        (>50%), when
>        using
>        17640
>        (2205X8)
>        cores?
>        Btw, I
>        do not
>        have
>        access
>        to the
>        system.
>        Sent
>        using
>        CloudMagic
>        Email
>        What
>        most
>        experimenters
>        take
>        for
>        granted before
>        they
>        begin
>        their
>        experiments
>        is
>        infinitely
>        more
>        interesting
>        than
>        any
>        results to
>        which
>        their
>        experiments
>        lead.
>        Norbert Wiener
>                                                     <log48.txt><log96.txt>
>                                             <log48_10.txt><log48.txt><log96.txt>
>                                     <log96_100.txt><log48_100.txt>
>                             <log96_100_2.txt><log48_100_2.txt>
>                     <log64_100.txt><log8_100.txt>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151103/fafa25af/attachment-0001.html>
