[petsc-users] Setting/creating Mats for SNES use
Dave May dave.mayhem23 at gmail.com
Mon Nov 2 15:21:22 CST 2015
Damn - Jed scooped me :D
On 2 November 2015 at 22:19, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 2 November 2015 at 21:49, Justin Chang <jychang48 at gmail.com> wrote:
>> So when would I use one over the other?
>> - If I wanted to solve a problem using a direct solver or an iterative
>> solver without a preconditioner, I would use A = J?
> Yes.
>> - The documentation for SNESSetJacobian() says that AMat and PMat are
>> usually the same, but if I used something like GAMG would I need to create
>> two different objects/Mats?
> I would say "maybe".
> If the Jacobian (here A) was defined via a matrix-free finite difference
> approximation, but you wish to use a non-trivial preconditioner, you might
> wish to assemble J. J might be the Picard linearized operator (for example).
> Another use case where A != J might arise is if you define A with a high
> order spatial discretization (probably matrix free) and you use a low order
> discretization to define the preconditioner which will ultimately be passed
> to GAMG.
>> Thanks,
>> Justin
>> On Mon, Nov 2, 2015 at 1:39 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Justin Chang <jychang48 at gmail.com> writes:
>>> > Hi all,
>>> > In my DMPlex program, I have these lines:
>>> > Mat A,J;
>>> > ierr = DMSetMatType(dm, MATAIJ); CHKERRQ(ierr);
>>> > ierr = DMCreateMatrix(dm, &J); CHKERRQ(ierr);
>>> > A = J;
>>> > ierr = DMSNESSetFunctionLocal(dm, ...); CHKERRQ(ierr);
>>> > ierr = DMSNESSetJacobianLocal(dm, ...); CHKERRQ(ierr);
>>> > ierr = SNESSetJacobian(snes, A, J, NULL, NULL); CHKERRQ(ierr);
>>> > ierr = SNESSetFromOptions(snes); CHKERRQ(ierr);
>>> > ierr = SNESSolve(snes, NULL, x); CHKERRQ(ierr);
>>> > ierr = MatDestroy(&J); CHKERRQ(ierr);
>>> > For the line "A = J;",
>>> This means you have two handles referring to the same object.
>>> > what exactly is the difference, if any, between that and "ierr =
>>> > MatDuplicate(...)"
>>> This creates a new object.
>>> > or "ierr = MatCopy(...)"?
>>> The second argument needs to be a valid Mat to call this function.
>>> > Do these different options somehow affect memory usage/performance?
>>> Yes.
>>> > Say I am solving a standard poisson equation using either GAMG and/or
>>> > HYPRE.
>>> > Thanks,
>>> > Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151102/e58dc2d1/attachment.html>
