[petsc-users] error using GetType in FORTRAN
Mark Adams mfadams at lbl.gov
Fri May 29 12:05:47 CDT 2015
Humm, I cleaned everything, and even cut and pasted your configure line,
same thing.  I am now trying with a fresh petsc clone.
I add these modules:
  module load adios/1.6.0
  module load cray-hdf5-parallel
  module load cmake/2.8.11.2
  module unload darshan
and I do not see this bfort-base.txt file:
10:03 edison03 master ~/petsc_install/petsc$ ll arch-xc30-opt64-intel/share
total 32
-rw-r--r-- 1 madams madams 4755 May 29 09:52 basedefs.txt
-rw-r--r-- 1 madams madams  326 May 29 09:52 blueball.gif
drwxr-x--- 2 madams madams  512 May 29 09:52 doctext
-rw-r--r-- 1 madams madams  326 May 29 09:52 greenball.gif
-rw-r--r-- 1 madams madams 1625 May 29 09:52 html.def
-rw-r--r-- 1 madams madams 1668 May 29 09:52 latex.def
drwxr-x--- 3 madams madams  512 May 29 09:52 man
-rw-r--r-- 1 madams madams   79 May 29 09:52 next.gif
-rw-r--r-- 1 madams madams  287 May 29 09:52 next.xbm
-rw-r--r-- 1 madams madams 1482 May 29 09:52 nroff.def
-rw-r--r-- 1 madams madams   79 May 29 09:52 previous.gif
-rw-r--r-- 1 madams madams  299 May 29 09:52 previous.xbm
-rw-r--r-- 1 madams madams 7353 May 29 09:52 pstoppm.ps
-rw-r--r-- 1 madams madams  326 May 29 09:52 purpleball.gif
-rw-r--r-- 1 madams madams  326 May 29 09:52 redball.gif
-rw-r--r-- 1 madams madams  283 May 29 09:52 refman.def
-rw-r--r-- 1 madams madams 3151 May 29 09:52 refman.sty
-rw-r--r-- 1 madams madams   74 May 29 09:52 up.gif
-rw-r--r-- 1 madams madams  281 May 29 09:52 up.xbm
-rw-r--r-- 1 madams madams  324 May 29 09:52 yellowball.gif
On Fri, May 29, 2015 at 11:23 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> I tried building on edison - and can't reproduce this problem.
> ./configure --COPTFLAGS="-fast -no-ipo" --CXXOPTFLAGS="-fast -no-ipo"
> --FOPTFLAGS="-fast -no-ipo"  --with-ssl=0 --with-cc=cc
> --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0
> --with-debugging=0 --with-fc=ftn  --with-fortranlib-autodetect=0
> --with-shared-libraries=0 --with-x=0 --with-mpiexec=aprun  LIBS=-lstdc++
> --with-64-bit-indices PETSC_DIR=$PWD PETSC_ARCH=arch-xc30-opt64-intel
> --prefix=$HOME/soft/test
> The error message you get is puzzling..
> > Unable to find bfort-base.txt config file in
> /global/homes/m/madams/petsc_install/petsc/arch-xc30-opt64-intel/share*******
> Can you attempt a build from a 'clean' repo?
> rm -rf arch*
> git clean -f -d -x
> ./configure....
> Satish
> On Fri, 29 May 2015, Mark Adams wrote:
> > Barry, It looks like you blew it.
> > On Wed, May 27, 2015 at 4:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >    Apparently all people with access to the PETSc repository (i.e.
> > > everyone in the world with internet access) have caught a rare disease
> that
> > > has caused their fingers to fall off, making them incapable of fixing
> this.
> > >    I have added all the PETSc enums to this file in master and next.
> Make
> > > sure you run make allfortranstubs to regenerate the stubs.
> > >    Barry
> > > > On May 27, 2015, at 2:15 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > FYI, this does not seem to be fixed.
> > > > On Sat, Apr 18, 2015 at 5:49 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > >   Looks like a bunch of these things are missing from
> > > lib/petsc/conf/bfort-petsc.txt  it should be listed under native
> > > >   Barry
> > > > > On Apr 17, 2015, at 4:43 PM, Matthew Knepley <knepley at gmail.com>
> > > wrote:
> > > > > Does bfort have to be told that PCCompositeType is an enum?
> > > > >    Matt "bfort's biggest fan"
> > > > > On Fri, Apr 17, 2015 at 4:37 PM, Mark Adams <mfadams at lbl.gov>
> wrote:
> > > > > It looks like fieldsplitf.c has an extra PetscToPointer.  type is
> > > already a pointer:
> > > > > PETSC_EXTERN void PETSC_STDCALL  pcfieldsplitgettype_(PC
> > > pc,PCCompositeType *type, int *__ierr ){
> > > > > *__ierr = PCFieldSplitGetType(
> > > > >     (PC)PetscToPointer((pc) ),
> > > > >     (PCCompositeType* )PetscToPointer((type) ));
> > > > > On Fri, Apr 17, 2015 at 4:12 PM, Barry Smith <bsmith at mcs.anl.gov>
> > > wrote:
> > > > >    Likely need to run in the debugger to see what generates the
> error.
> > > Perhaps a missing ierr?
> > > > > Barry
> > > > > > On Apr 17, 2015, at 9:10 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > > > I declare
> > > > > >   PCCompositeType::pcctype
> > > > > > But PCFieldSplitGetType does not seem to like it?
> > > > > > Mark
> > > > > > [1]PETSC ERROR: --------------------- Error Message
> > > > > > [1]PETSC ERROR: Invalid pointer
> > > > > > [1]PETSC ERROR: Invalid Pointer to Int: Parameter # 2
> > > > > > [1]PETSC ERROR: See
> > > http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> > > > > > [1]PETSC ERROR: Petsc Development GIT revision:
> > > v3.5.3-2702-g1f714da  GIT Date: 2015-04-16 11:32:06 -0500
> > > > > > [1]PETSC ERROR: ../../XGC1_3/xgc-em on a arch-macosx-gnu-g named
> > > MacBook-Pro.local by markadams Fri Apr 17 10:06:09 2015
> > > > > > [1]PETSC ERROR: Configure options --download-hypre=1
> > > --download-p4est --download-superlu=1 --download-mumps
> --download-scalapack
> > > --download-superlu_dist=1 --download-parmetis=1 --download-metis=1
> > > --download-triangle=1 --with-hdf5-dir=/Users/markadams/Codes/hdf5
> > > --with-x=0 --with-debugging=1 PETSC_ARCH=arch-macosx-gnu-g
> > > > > > [1]PETSC ERROR: #1 PCFieldSplitGetType() line 2046 in
> > > /Users/markadams/Codes/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> > > > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which
> their
> > > experiments lead.
> > > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150529/efa61bae/attachment.html>
