[petsc-users] SLEPc Eigenvalue problem - Zero Pivot
Jose E. Roman jroman at dsic.upv.es
Thu May 14 12:24:47 CDT 2015
El 14/05/2015, a las 19:13, venkatesh g escribió:
> Hi,
> 1. I am not calling EPSSetFromOptions in source code. I am using the ex7.c given in the SLEPc webpage.
> 2. A-matrix is not singular. Only B is singular.
> 3. I will try with MUMPS.
> 4. Matrix sizes are same as in Matlab. If B is not singular it is giving same result as Matlab, but if B is singular it gives the zero pivot issue which Matlab doesnt give.
> So is there a way ?
The ex7.c example calls EPSSetFromOptions(). If it is not called, then command-line options are ignored.
It is strange that you get zero pivots when factoring A-sigma*B for different values of sigma. Try with MUMPS.
Jose
