[petsc-users] Unequal sparse matrix row distribution for MPI MatMult
Steena M stm8086 at yahoo.com
Sun Mar 29 21:56:30 CDT 2015
Hi Barry,
I am trying to partition a 20 row and 20 col sparse matrix between two procs such that proc 0 has 15 rows and 20 cols and proc 1 has 5 rows and 20 cols. The code snippet:
	CHKERRQ(MatCreate(PETSC_COMM_WORLD,&A)); // at runtime: -matload_block_size 1
	if (rank ==0)
		CHKERRQ( MatSetSizes(A, 15, 20, 20, 20) ); //rank 0 gets 75% of the rows
		CHKERRQ( MatSetType(A, MATMPIBAIJ) );
		CHKERRQ( MatLoad(A,fd) );
	else
		CHKERRQ( MatSetSizes(A, 5, 20, 20, 20) ); //rank 1 gets 25% of the rows
This throws the following error (probably from psplit.c):
[1]PETSC ERROR: --------------------- Error Message ------------------------------------
[1]PETSC ERROR: Nonconforming object sizes!
[1]PETSC ERROR: Sum of local lengths 40 does not equal global length 20, my local length 20
  likely a call to VecSetSizes() or MatSetSizes() is wrong.
See http://www.mcs.anl.gov/petsc/documentation/faq.html#split!
This error printout doesn't quite make sense to me. I'm trying to specify a total matrix size of 20x20... I haven't yet figured out where the '40' comes from in the error message.
Any thoughts on what might be going wrong?
Thanks in advance,
Steena
On Sun, 3/22/15, Barry Smith <bsmith at mcs.anl.gov> wrote:
 Subject: Re: [petsc-users] Unequal sparse matrix row distribution for MPI MatMult
 To: "Steena M" <stm8086 at yahoo.com>
 Cc: petsc-users at mcs.anl.gov
 Date: Sunday, March 22, 2015, 3:58 PM
 Steena,
    I am
 a little unsure of your question.
    1) you can create a MPIBAIJ
 matrix with any distribution of block rows per process you
 want, just set the local row size for each process to be
 what you like.  Use MatCreateVecs() to get correspondingly
 laid out vectors.
    or 2) if you have a MPIBAIJ
 matrix with "equal" row layout and you want a new
 one with uneven row layout you can simply use
 MatGetSubMatrix() to create that new matrix.
   Barry
 Unless you have another reason to have the
 matrix with an equal number row layout I would just generate
 the matrix with the layout you want.
 > On Mar 22, 2015, at 5:50 PM, Steena M
 wrote:
 > Hello,
 > I need to distribute
 a sparse matrix such that each proc owns an unequal number
 of blocked rows before I proceed with MPI MatMult. My
 initial thoughts on doing this:
 > 1) Use  MatGetSubMatrices() on the test
 MATMPIBAIJ matrix to produce a new matrix where each proc
 has an unequal number of rows.
 > 2) Provide scatter context for vector X
 (for MatMult )using IS iscol from MatGetSubMatrices() while
 creating the vector X.
 > 3) Call MatMult()
 > Will MatMult_MPIBAIJ continue to scatter
 this matrix and vector such that each proc will own an equal
 number of matrix rows and corresponding diagonal vector
 elements? Should I write my own MPIMatMult function to
 retain my redistribution of the matrix and vector?
 > Thanks in
 advance,
 > Steena
