[petsc-users] Problem with MPI, MatAXPY and SAME_NONZERO_PATTERN
Klaus Kaiser kaiser at igpm.rwth-aachen.de
Fri Mar 27 10:16:48 CDT 2015
Hallo Matthew,
thanks for your fast response. With "no beside the nonzero structure" I
meant, that I do not create a different non-zero structure while I'm
adding values to my matrices.
I also tried MAT_COPY_VALUES and the result was the same.
I do not get a error message but the resulting matrix is wrong. Here I
have a short example. The first 9 rows and first 3 colomn of the
matrices Ah, At and Ah+At on the first processor (of 8):
Ah:
0:                   60.3553                -0.249975 2.77556e-17
1:                         0 60.3553                        0
2:                         0 0                  60.3553
3:                   17.6777 0.374962                 0.124987
4:                         0 17.6777                        0
5:                         0 0                  17.6777
6:                  -7.32233 -0.124987                 0.374962
7:                         0 -7.32233                        0
8:                         0 0                 -7.32233
At:
0:                         0 0                        0
1:                      2500 0                        0
2:              -4.54747e-13 0                        0
3:                         0 0                        0
4:                      1250 0                        0
5:                      1250 0                        0
6:                         0 0                        0
7:                      1250 0                        0
8:                      3750 0                        0
Ah+At
1:                      2500 60.3553                        0
2:              -4.54747e-13 0                  60.3553
4:                         0 17.6777                        0
5:                         0 0                  17.6777
7:                         0 -7.32233                        0
8:                         0 0                 -7.32233
you can see the first 3 rows of the resulting matrix looks exactly like
what I would expect, but the last 6 rows only consists of the values of
Ah. When you would also look on the matrix A and A+Ah+At you would also
see, that values where both matrices have an nonzero entry are not sum
correctly.
Best
Klaus
On 03/27/2015 03:59 PM, Matthew Knepley wrote:
> On Fri, Mar 27, 2015 at 9:48 AM, Klaus Kaiser
> <kaiser at igpm.rwth-aachen.de <mailto:kaiser at igpm.rwth-aachen.de>> wrote:
>     Hallo,
>     I have a strange behavior in my code concerning the function
>     MatAXPY. I create 3 different Matrices
>         ierr = MatCreateBAIJ(PETSC_COMM_WORLD, block_size, local_size,
>     local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&A);
>         ierr = MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>         ierr = MatSetOption(A,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>         ierr = MatSetOption(A,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>     local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&At);
>         ierr = MatSetOption(At,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>         ierr = MatSetOption(At,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>         ierr = MatSetOption(At,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
>     local_size, system_size, system_size, 0, d_nnz, 0, o_nnz,&Ah);
>         ierr = MatSetOption(Ah,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);
>         ierr = MatSetOption(Ah,MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE);
>         ierr = MatSetOption(Ah,MAT_IGNORE_OFF_PROC_ENTRIES,PETSC_TRUE);
> These creations are superfluous since you use MatDuplicate() below.
>     and want to sum these three matrixes with different factors. First
>     I fill the Matrix A with some values, and duplicate the structure
>     of A to the other two matrices:
>         MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);
>         MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);
>         MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&Ah);
>         MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&At);
>         MatAssemblyBegin(Ah,MAT_FINAL_ASSEMBLY);
>         MatAssemblyEnd(Ah,MAT_FINAL_ASSEMBLY);
>         MatAssemblyBegin(At,MAT_FINAL_ASSEMBLY);
>         MatAssemblyEnd(At,MAT_FINAL_ASSEMBLY);
>     After this I fill the matrices At and Ah with some other values,
>     which are not beside the non zero structure (I also tried with
>     just copying the Matrix A). Now after another MatAssembly
> I do not understand "no beside the nonzero structure". Do you mean
> that the nonzero structure is the same?
> Can you first test with MAT_COPY_VALUES?
>     I want to add these Matrices in the form A+c*(Ah+d*At):
>         MatAXPY(Ah,c,At,SAME_NONZERO_PATTERN);
>         MatAXPY(A,d,Ah,SAME_NONZERO_PATTERN);
>     When I run the method with mpi and one core everything works fine.
>     Starting the same method with more cores, the sum of the matrices
>     fails. It seems like some values are added
> Please send the full output of a failure when you use MAT_COPY_VALUES
> on 2 procs.
>   Thanks,
>      Matt
>     correctly and many values are missed. Using
>     DIFFERENT_NONZERO_STRUCTURE leads to the right behavior in the
>     multi-core case, but is very slow. I checked with a viewer if all
>     matrices have the same nonzero structure and this is the case.
>     Does anyone know why this fails, or do I have made any wrong thoughts?
>     I'm corrently working with a petsc version (Petsc Release Version
>     3.3.0, Patch 5, Sat Dec  1 15:10:41 CST 2012), I looked into the
>     changelogs up to the current version and did not find any note
>     about MatAXPY or MatAYPX.
>     Best and Thanks a lot for your help
>     Klaus
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150327/52daa64e/attachment.html>
