[petsc-users] Understanding MatCreate bsize parameter
Florian Lindner mailinglists at xgm.de
Thu Mar 26 08:16:47 CDT 2015
Hello,
I'm using petsc with petsc4py.
A matrix is created like that
    MPIrank = MPI.COMM_WORLD.Get_rank()
    MPIsize = MPI.COMM_WORLD.Get_size()
    print("MPI Rank = ", MPIrank)
    print("MPI Size = ", MPIsize)
    parts = partitions()
    print("Dimension= ", nSupport + dimension, "bsize = ", len(parts[MPIrank]))
    MPI.COMM_WORLD.Barrier() # Just to keep the output together
    A = PETSc.Mat(); A.createDense( (nSupport + dimension, nSupport + dimension), bsize = len(parts[MPIrank]) ) # <-- crash here
Output for mpirun -n 2 is like that and it works:
MPI Rank =  0
MPI Size =  2
Dimension=  10 bsize =  5
MPI Rank =  1
MPI Size =  2
But for mpirun -n 3 it crashes:
MPI Rank =  2
MPI Size =  3
Dimension=  10 bsize =  3
MPI Rank =  1
MPI Size =  3
Dimension=  10 bsize =  4
MPI Rank =  0
MPI Size =  3
Error is ValueError: global size 10 not divisible by block size 3.
I tried to dig a bit into the source. Mat_Create uses Mat_Dense to unpack the size and bsize parameters. When there just a scalar n, not a tuple t given as parameter it assumes t = (n, n). (Right?). That should be fine.
When I omit bsize, and mpirun -n 3, A.owner_range returns
(4, 7)
(0, 4)
(7, 10)
Which essentially is the same partioning that I manually set (I need to set partioning manually). Also the sum of bsizes equals the dimension. What is the problem here?
Florian
