[petsc-users] SLEPc - Generalized symmetric eigenproblem using ARPACK
Jose E. Roman jroman at dsic.upv.es
Wed Mar 25 16:00:55 CDT 2015
El 25/03/2015, a las 21:47, Harshad Sahasrabudhe escribió:
> With MUMPS you should not get spurious eigenvalues.
> I get only a few spurious eigenvalues when using MUMPS with ARPACK, but the eigenvectors are definitely wrong.
> Did you try the krylovschur solver?
> Yes, Krylov-Schur gives me correct results.
> How do you know the eigenvalues are wrong?
> I'm testing my implementation of Schrodinger equation solver with a 3D harmonic oscillator potential. I'm getting correct results using FEAST and krylovschur solvers.
> Are you setting problem type to GHEP?
> Yes
Did you try the arpack-ng version? Seems that some people have taken over maintainance.
Anyway, why do you insist in using ARPACK when SLEPc's Krylov-Schur work? ARPACK will not give you any further advantage.
Jose
