[petsc-users] TimeStepper norm problems. EMIL Please read this
Lisandro Dalcin dalcinl at gmail.com
Mon Mar 23 04:44:42 CDT 2015
On 21 March 2015 at 17:32, Emil Constantinescu <emconsta at mcs.anl.gov> wrote:
> When -ts_theta_adapt is used, then it detects the instability as an error
> and reduces the step by a lot! wlte=1.24e+03 which means that the reduction
> should be severe but the controller tries 0.1*dt and that seems to pass but
> it "jig-saws" (take a look at the next attempted step), which means that it
> is likely unstable.
I think -ts_theta_adapt is seriously broken, I cannot make sense of
the way the error estimator is computed.
I have an alternative implementation of adaptivity in PetIGA in custom
Generalized-Alpha implementation. The adaptivity is not based on
embed-RK like for TSCN, but in storing a solution vector from the
previous step then estimate the LTE with backward differences. BTW,
this idea can be generalized to any second-order method at the cost of
tracking an extra solution vector and a bunch of Vec operations.
Emil, if you want to try my code to give it a try, it is very easy to
integrate, you just need to copy a file to your sources
(https://bitbucket.org/dalcinl/petiga/src/tip/src/tsalpha1.c) and add
a TSRegister() call after PetscInitialize(). Then you pass in the
command line -ts_type alpha1 -ts_alpha_adapt. You can also pass
-ts_alpha_radius 0.5 to add some high-frequency dissipation (the
default is 1.0, then the method is roughly equivalent to the midpoint
rule).
PS: I would like to put all this in PETSc, but before that, I need
help from you guys to make sure this method really makes sense. The
fact that this has worked very well for me in some problems is not
enough.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Numerical Porous Media Center (NumPor)
King Abdullah University of Science and Technology (KAUST)
http://numpor.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
