[petsc-users] Use MatConvert
Chung-Kan Huang ckhuangf at gmail.com
Tue Mar 17 11:40:01 CDT 2015
I wonder what I did wrong when using MATConvert...
  MatCreate(* comm_, &J_);
  PetscInt * d_nnz = NULL;
  PetscInt * o_nnz = NULL;
  PetscMalloc(local_size * sizeof(PetscInt), & d_nnz);
  PetscMalloc(local_size * sizeof(PetscInt), & o_nnz);
  for (int i = 0; i < local_size; i++) {
    d_nnz[i] = d_nnz_v[i];
    o_nnz[i] = o_nnz_v[i];
  MatSetSizes(J_,
          local_size,
          local_size,
          PETSC_DECIDE,
          PETSC_DECIDE);
  MatSetBlockSize(J_, M_SIZE); // So MatSetValuesBlocked can be used
  MatSetType(J_, MATAIJ);
  if (comm_->Get_size() > 1) {
    // MPI
    MatMPIAIJSetPreallocation(J_,
                  max_d_nz,
                  d_nnz,
                  max_o_nz,
                  o_nnz);
  } else {
    // Seq
    MatSeqAIJSetPreallocation(J_,
                  PETSC_DEFAULT,
                  d_nnz);
  PetscFree(d_nnz);
  PetscFree(o_nnz);
  // Column oriented
  MatSetOption(J_, MAT_ROW_ORIENTED, PETSC_FALSE);
  // Test code to check if J_ has right structure
  preAssembeJ();
[image: Inline image 1]
  MatAssemblyBegin(J_, MAT_FINAL_ASSEMBLY);
  MatAssemblyEnd(J_, MAT_FINAL_ASSEMBLY);
 MatConvert(J_, MATBAIJ, MAT_REUSE_MATRIX, & J_);
  MatZeroEntries(J_);
  preAssembeJ();
[image: Inline image 2]
Kan
*Cheers*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150317/445bb81d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150317/445bb81d/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150317/445bb81d/attachment-0001.png>
