[petsc-users] DMView and DMLoad
Ataollah Mesgarnejad amesga1 at tigers.lsu.edu
Mon Mar 9 11:28:51 CDT 2015
Dear all,
I'm trying to save and load distributed DMPlex in HDF5 format with DMView
and DMLoad. The problem is even though there are no errors while loading
the DM when I look at the DM loaded from file is not equal to the DM that
was saved. Also, when loading the DM if DMSetType is called before the
DMLoad, DMLoad produces errors (like line 316
<https://bitbucket.org/petsc/petsc/src/236f5a4d227fe9d0affddb8701edb9509ad39525/src/snes/examples/tutorials/ex12.c?at=master#cl-316>
in src/snes/examples/tutorials/ex12.c ).
I'm including a small code to replicate the problem here plus an input mesh
file.
Best,
Ata
 * @file
 * Created by Ataollah Mesgarnejad on 3/6/15.
 * This is a test to read and write a distributed DM.
static char help[] = "An example of the usage of PetscSF to scatter data
back and forth between a \
a serial DM and its parallel counterpart.\n";
#include <petscdmplex.h>
#include <petscsnes.h>
#include <petscsf.h>
#include <exodusII.h>
#include <petsc-private/dmimpl.h>     /*I      "petscdm.h"     I*/
#include <petscviewerhdf5.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
    PetscErrorCode      ierr;
    DM                  dm, distDM,distDMold;
    char                ifilename[PETSC_MAX_PATH_LEN];
    PetscBool           flg;
    int                 CPU_word_size = 0,IO_word_size = 0,exoid;
    float               version;
    PetscInt            numproc,rank;
    PetscViewer         stdoutViewer,DMPlexHDF5View;
    PetscReal           *VArray;
    PetscInt            dim;
    PetscInt            numFields = 2;
    PetscInt            numComp[2] = {1,1};
    PetscInt            numDof[6] = {1, 0, 0,
        0, 0, 1}; /*{Vertex, Edge, Cell} */
    PetscInt            bcFields[1] = {0}, numBC=0;
    //PetscInt          *remoteOffsets;
    char**              namelist;
    PetscInt            off;
    IS                  bcPoints[1] = {NULL};
    IS                  *ISlist;
    PetscSection        seqSection, distSection;
    Vec                 distV, V;
    PetscSF             pointSF;//,pointSFold;
    PetscInt            pStart, pEnd, dof;
    PetscBool           load_files = PETSC_FALSE, save_files = PETSC_FALSE;
    MPI_Comm            comm;
    ierr = PetscInitialize(&argc, &argv, (char*)0, help);CHKERRQ(ierr);
    ierr = PetscViewerASCIIGetStdout(PETSC_COMM_SELF,&stdoutViewer);CHKERRQ
(ierr);
    comm = PETSC_COMM_WORLD;
    // PetscErrorCode DMCreateSubDM(DM dm, PetscInt numFields, PetscInt
fields[], IS *is, DM *subdm)
    ierr = PetscOptionsBegin(PETSC_COMM_WORLD,"","PetscSF Test Options",
"none");CHKERRQ(ierr);
    ierr = PetscOptionsBool("-save_files","save the distributed vector in
HDF5 format","",PETSC_FALSE,&save_files,NULL);CHKERRQ(ierr);
    ierr = PetscOptionsBool("-load_files","Load the distributed vector in
HDF5 format","",PETSC_FALSE,&load_files,NULL);CHKERRQ(ierr);
    ierr = PetscOptionsEnd();
    ierr = PetscOptionsGetString(PETSC_NULL,"-i",ifilename,sizeof
ifilename,&flg);CHKERRQ(ierr);
    ierr = MPI_Comm_size(PETSC_COMM_WORLD,&numproc);
    ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
    if (!rank)
        exoid = ex_open(ifilename,EX_READ
,&CPU_word_size,&IO_word_size,&version);
        if (exoid <= 0)
SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"ex_open(\"%s\",...)
did not return a valid file ID",ifilename);
    else
        exoid = -1;                 /* Not used */
    ierr = DMPlexCreateExodus(PETSC_COMM_WORLD,exoid,PETSC_FALSE,&dm);
                                            CHKERRQ(ierr);
    ierr = PetscObjectSetName((PetscObject) dm,"sequential-DM");
    ierr = DMGetDimension(dm, &dim);
                                            CHKERRQ(ierr);
    if (numproc < 2 ) distDM = dm;
    else ierr = DMPlexDistribute(dm, 0, &pointSF, &distDM);
                                            CHKERRQ(ierr);
    ierr = PetscObjectSetName((PetscObject) distDM,"Distributed-DM");
    ierr = DMPlexCreateSection(dm,      dim, numFields, numComp, numDof,
                               numBC, bcFields, bcPoints,PETSC_NULL,
&seqSection);                                      CHKERRQ(ierr);
    ierr = DMPlexCreateSection(distDM,  dim, numFields, numComp, numDof,
&distSection);                                     CHKERRQ(ierr);
    ierr = DMSetDefaultSection(dm, seqSection);
                                            CHKERRQ(ierr);
    ierr = DMSetDefaultSection(distDM, distSection);
                                            CHKERRQ(ierr);
    ierr = DMCreateGlobalVector(dm, &V);
                                            CHKERRQ(ierr);
    ierr = VecCreate(comm, &distV);
                                            CHKERRQ(ierr);
    ierr = PetscObjectSetName((PetscObject) distV,"Distributed-V");
    ierr = VecGetArray(V, &VArray);
                                            CHKERRQ(ierr);
    // fill vertex data
    ierr = DMPlexGetDepthStratum(dm, 0, &pStart, &pEnd);
                                            CHKERRQ(ierr);
    for (int p = pStart; p < pEnd; p++)
        ierr = PetscSectionGetDof(seqSection, p, &dof);
                                            CHKERRQ(ierr);
        ierr = PetscSectionGetOffset(seqSection, p, &off);
                                            CHKERRQ(ierr);
        for (int d = 0; d < dof; d++)
            VArray[off + d] = p;
    // fill cell data
    ierr = DMPlexGetDepthStratum(dm, 1, &pStart, &pEnd);
                                            CHKERRQ(ierr);
                                            CHKERRQ(ierr);
                                            CHKERRQ(ierr);
            VArray[off + d] = -p-1;
    ierr = VecRestoreArray(V, &VArray); CHKERRQ(ierr);
    ierr = DMCreateFieldIS(dm, &numFields, &namelist, &ISlist);
                                            CHKERRQ(ierr);
    ierr = DMPlexDistributeField(dm, pointSF, seqSection, V, distSection,
distV);                                       CHKERRQ(ierr);
#if defined(PETSC_HAVE_HDF5)
    if (save_files)
        // distribute fields
        ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Distrubuted DM\n");
                                            CHKERRQ(ierr);
        ierr = DMView(distDM, PETSC_VIEWER_STDOUT_WORLD);
                                            CHKERRQ(ierr);
        PetscSynchronizedFlush(PETSC_COMM_WORLD, PETSC_STDOUT);
        // Save distributed data
        ierr = PetscViewerHDF5Open(PetscObjectComm((PetscObject) distDM),
"distDM.h5", FILE_MODE_WRITE, &DMPlexHDF5View);CHKERRQ(ierr);
        ierr = PetscPrintf(PETSC_COMM_WORLD,"Writing dist DM ...\n");
        ierr = DMView(distDM, DMPlexHDF5View);
                                            CHKERRQ(ierr);
        PetscViewerDestroy(&DMPlexHDF5View);
    else if (load_files)
        ierr = PetscPrintf(PETSC_COMM_WORLD,"Loading dist vectors ...\n");
                                            CHKERRQ(ierr);
        ierr = PetscViewerHDF5Open(PETSC_COMM_SELF,"distDM.h5",
FILE_MODE_READ, &DMPlexHDF5View);                       CHKERRQ(ierr);
        ierr = DMCreate(comm,&distDMold);
                                            CHKERRQ(ierr);
        ierr = DMLoad(distDMold,DMPlexHDF5View);
                                            CHKERRQ(ierr);
        ierr = DMSetType(distDMold, DMPLEX);
                                            CHKERRQ(ierr);
        /*ierr = DMPlexCreateSection(distDMold,  dim, numFields, numComp,
numDof,
&distSectionold);                              CHKERRQ(ierr);
        ierr = DMSetDefaultSection(distDMold, distSectionold);CHKERRQ(ierr);
        ierr = DMGetPointSF(distDMold,&pointSFold);
                                            CHKERRQ(ierr);*/
        ierr = PetscPrintf(PETSC_COMM_WORLD, "==== Read DM\n");
                                            CHKERRQ(ierr);
        ierr = DMView(distDMold, PETSC_VIEWER_STDOUT_WORLD);
                                            CHKERRQ(ierr);
                                            CHKERRQ(ierr);
        DMPlexEqual(distDM, distDMold, &flg);
        if (flg)
            PetscPrintf(PETSC_COMM_WORLD,"\n DMs equal\n");
        else
            PetscPrintf(PETSC_COMM_WORLD,"\n DMs are not equal\n\n");
#endif
    ierr = VecDestroy(&V); CHKERRQ(ierr);
    ierr = VecDestroy(&distV); CHKERRQ(ierr);
    //ierr = VecDestroy(&seqV); CHKERRQ(ierr);
    ierr = DMDestroy(&dm);CHKERRQ(ierr);
    ierr = DMDestroy(&distDM);CHKERRQ(ierr);
    ierr = PetscFinalize();
    return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150309/c499a5dc/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150309/c499a5dc/attachment-0001.cpp>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150309/c499a5dc/attachment-0001.obj>
