[petsc-users] Error with debug
Jed Brown jed at jedbrown.org
Mon Mar 9 10:55:13 CDT 2015
Saurabh Chawdhary <saurabh.chawdhary at gmail.com> writes:
> Hi,
> I used to work with petsc and running everything fine thus far. But then I
> decided to run it with a debugger. To this end I re-installed petsc
> --with-debugging=1. I can compile the code with this new petsc installation
> but when I run it I get Segmentation fault error. Same code compiled with
> the old without debug option runs perfectly fine.
> Is something wrong with my new installation?
Run in a debugger and send the stack trace.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150309/c51f52e6/attachment.pgp>
