[petsc-users] ISLoad
Fande Kong fdkong.jd at gmail.com
Wed Jul 22 23:07:48 CDT 2015
Hi all,
How can we load a IS binary file. I have a IS binary file, I got errors
when I tried to load it:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: This should be implemented
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.6-130-g2e90825  GIT
Date: 2015-07-13 18:57:36 -0500
[0]PETSC ERROR: ./ex9 on a arch-darwin-cxx-debug named
reshut2-69-67-dhcp.int.colorado.edu by livia Wed Jul 22 22:02:50 2015
[0]PETSC ERROR: Configure options --with-clanguage=cxx
--with-shared-libraries=1 --download-fblaslapack=1
--with-mpi-dir=/Users/livia/math/mpich-3.1_install --download-parmetis=1
--download-metis=1 --with-64-bit-indices=1 --download-netcdf=1
--download-exodusii=1 --download-hdf5=1 --with-debugging=yes
--with-c2html=0 --download-hypre=1 --download-superlu_dist=1
PETSC_DIR=/Users/livia/math/petsc-mat PETSC_ARCH=arch-darwin-cxx-debug
[0]PETSC ERROR: #1 ISLoad_Default() line 131 in
/Users/livia/math/petsc-mat/src/vec/is/utils/isio.c
[0]PETSC ERROR: #2 ISLoad() line 804 in
/Users/livia/math/petsc-mat/src/vec/is/is/interface/index.c
[0]PETSC ERROR: #3 main() line 75 in
/Users/livia/math/petsc-mat/src/ksp/pc/examples/tests/ex9.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -af ./test64/A_1
[0]PETSC ERROR: -bf ./test64/B_1
[0]PETSC ERROR: -bsf ./test64/IS_1
[0]PETSC ERROR: -isload_block_size 1
[0]PETSC ERROR: -matload_block_size 1
[0]PETSC ERROR: -rf ./test64/RHS_1
[0]PETSC ERROR: -vecload_block_size 1
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
[cli_0]: aborting job:
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 1181 RUNNING AT reshut2-69-67-dhcp.int.colorado.edu
=   EXIT CODE: 56
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Configure and make logs are attached. It looks like we did not implement
ISLoad_binary yet. Or I got wrong information?
Fande Kong,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150722/1a4f859f/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150722/1a4f859f/attachment.zip>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150722/1a4f859f/attachment-0001.zip>
