[petsc-users] Jacobian check is sensitive to the choice of differencing parameter
Khai Pham khaipham at utexas.edu
Sun Jul 19 09:45:18 CDT 2015
Dear Petsc-Users,
The SNES only converges for a small problem. I did the jacobian check. The
result is sensitive to the choice of differencing parameter.
With the option "-snes_type test":
"Norm of matrix ratio 4.11569e-09 difference 7.64426e-07 (user-defined
state)
Norm of matrix ratio 2.05846e-08 difference 3.89655e-06 (constant state
-1.0)
Norm of matrix ratio 5.77446e-09 difference 1.09307e-06 (constant state
1.0)"
with the option "-snes_type test -mat_fd_type ds" :
"Norm of matrix ratio 1.05213e-07 difference 1.95418e-05 (user-defined
state)
Norm of matrix ratio 2.51463e-07 difference 4.76004e-05 (constant state
-1.0)
Norm of matrix ratio 2.81081e-08 difference 5.32071e-06 (constant state
1.0)".
Could you give me any hint where should I check for the error?
Khai
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150719/6586a455/attachment.html>
