[petsc-users] KSP changes for successive solver
Michele Rosso mrosso at uci.edu
Thu Jul 16 20:35:55 CDT 2015
Barry,
thank you. I think in few days I will run a larger test and I will send
the log to have better insight.
Thank you for now.
Michele
On Thu, 2015-07-16 at 19:48 -0500, Barry Smith wrote:
> > On Jul 16, 2015, at 7:18 PM, Michele Rosso <mrosso at uci.edu> wrote:
> > Barry,
> > thank you very much for the detailed answer.  I tried what you suggested and it works.
> > So far I tried on a small system but the final goal is to use it for very large runs.  How does  PCGAMG compares to PCMG  as far as performances and scalability are concerned?
>    Algebraic multigrid has much larger setup times than geometric multigrid, but since it is is running on a much smaller problem with geometric multigrid on top of it that is much less of an issue.
> > Also, could you help me to tune the GAMG part ( my current setup is in the attached ksp_view.txt file )?
>   The defaults are probably fine.
> > I also tried to use superlu_dist for the LU decomposition on mg_coarse_mg_sub_
> > -mg_coarse_mg_coarse_sub_pc_type lu
> > -mg_coarse_mg_coarse_sub_pc_factor_mat_solver_package superlu_dist
>   Yeah, gamg tries to put all the rows of the matrix on one process and leave the other processes empty, I suspect superlu_dist doesn't like empty matrices. Just use -mg_coarse_mg_coarse_sub_pc_type lu it is PETSc's native sequential sparse solver and will run faster than superlu_dist anyways except for really large coarse problems which you don't want anyway.
>   How many iterations is the multigrid using?
>   Instead of using -mg_coarse_pc_type some of the PETSc guys are fans of -mg_coarse_pc_type  chebyshev which may decrease the iterations slightly.
>   You can run with -log_summary and send the output, this shows where the time is being spent.
>   Barry
> > but I got an error:
> > ****** Error in MC64A/AD. INFO(1) = -2
> > symbfact() error returns 0
> > Thank you,
> > Michele
> > On Thu, 2015-07-16 at 18:07 -0500, Barry Smith wrote:
> >> > On Jul 16, 2015, at 5:42 PM, Michele Rosso <mrosso at uci.edu> wrote:
> >> > Barry,
> >> > thanks for your reply. So if I want it fixed, I will have to use the master branch, correct?
> >>   Yes, or edit mg.c and remove the offending lines of code (easy enough).
> >> > On a side note, what I am trying to achieve is to be able to use how many levels of MG I want, despite the limitation imposed by the local number of grid nodes.
> >>    I assume you are talking about with DMDA? There is no generic limitation for PETSc's multigrid, it is only with the way the DMDA code figures out the interpolation that causes a restriction.
> >> > So far I am using a borrowed code that implements a PC that creates a sub communicator and perform MG on it.
> >> > While reading the documentation I found out that PCMGSetLevels takes in an optional array of communicators. How does this work?
> >>    It doesn't work. It was an idea that never got pursued.
> >> > Can I can simply define my matrix and rhs on the fine grid as I would do normally ( I do not use kspsetoperators and kspsetrhs ) and KSP would take care of it by using the correct communicator for each level?
> >>    No.
> >>    You can use the PCMG geometric multigrid with DMDA for as many levels as it works and then use PCGAMG as the coarse grid solver. PCGAMG automatically uses fewer processes for the coarse level matrices and vectors. You could do this all from the command line without writing code.
> >>    For example if your code uses a DMDA and calls KSPSetDM() use for example -da_refine 3 -pc_type mg -pc_mg_galerkin -mg_coarse_pc_type gamg  -ksp_view
> >>   Barry
> >> > Thanks,
> >> > Michele
> >> > On Thu, 2015-07-16 at 17:30 -0500, Barry Smith wrote:
> >> >>    Michel,
> >> >>     This is a very annoying feature that has been fixed in master
> >> >> http://www.mcs.anl.gov/petsc/developers/index.html
> >> >>   I would like to have changed it in maint but Jed would have a shit-fit :-) since it changes behavior.
> >> >>   Barry
> >> >> > On Jul 16, 2015, at 4:53 PM, Michele Rosso <mrosso at uci.edu> wrote:
> >> >> > Hi,
> >> >> > I am performing a series of solves inside a loop. The matrix for each solve changes but not enough to justify a rebuilt of the PC at each solve.
> >> >> > Therefore I am using  KSPSetReusePreconditioner to avoid rebuilding unless necessary. The solver is CG + MG with a custom  PC at the coarse level.
> >> >> > If KSP is not updated each time, everything works as it is supposed to.
> >> >> > When instead I allow the default PETSc  behavior, i.e. updating PC every time the matrix changes, the coarse level KSP , initially set to PREONLY, is changed into GMRES
> >> >> > after the first solve. I am not sure where the problem lies (my PC or PETSc), so I would like to have your opinion on this.
> >> >> > I attached the ksp_view for the 2 successive solve and the options stack.
> >> >> > Thanks for your help,
> >> >> > Michel
> >> >> > <ksp_view.txt><petsc_options.txt>
> > <ksp_view.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150716/46b556c9/attachment.html>
