[petsc-users] KSP changes for successive solver
Michele Rosso mrosso at uci.edu
Thu Jul 16 16:53:08 CDT 2015
I am performing a series of solves inside a loop. The matrix for each
solve changes but not enough to justify a rebuilt of the PC at each
solve.
Therefore I am using  KSPSetReusePreconditioner to avoid rebuilding
unless necessary. The solver is CG + MG with a custom  PC at the coarse
level.
If KSP is not updated each time, everything works as it is supposed to.
When instead I allow the default PETSc  behavior, i.e. updating PC every
time the matrix changes, the coarse level KSP , initially set to
PREONLY, is changed into GMRES
after the first solve. I am not sure where the problem lies (my PC or
PETSc), so I would like to have your opinion on this.
I attached the ksp_view for the 2 successive solve and the options
stack.
Thanks for your help,
Michel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150716/2da40824/attachment-0001.html>
=============== FIRST SOLVE =============================
Linear solve converged due to CONVERGED_RTOL iterations 15
KSP Object: 8 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using nonzero initial guess
  using UNPRECONDITIONED norm type for convergence test
PC Object: 8 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     8 MPI processes
      type: preonly
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     8 MPI processes
      type: dmdarepart
        DMDARepart: parent comm size reduction factor = 2
        DMDARepart: subcomm_size = 4
      KSP Object:      (mg_coarse_dmdarepart_)       4 MPI processes
        type: preonly
        maximum iterations=10000, initial guess is zero
      PC Object:      (mg_coarse_dmdarepart_)       4 MPI processes
        type: mg
          MG: type is MULTIPLICATIVE, levels=2 cycles=v
          KSP Object:          (mg_coarse_dmdarepart_mg_coarse_)           4 MPI processes
            type: preonly
          PC Object:          (mg_coarse_dmdarepart_mg_coarse_)           4 MPI processes
            type: lu
              LU: out-of-place factorization
              tolerance for zero pivot 2.22045e-14
              matrix ordering: natural
              factor fill ratio given 0, needed 0
                Factored matrix follows:
                  Mat Object:                   4 MPI processes
                    type: mpiaij
                    rows=128, cols=128
                    package used to perform factorization: superlu_dist
                    total: nonzeros=0, allocated nonzeros=0
                    total number of mallocs used during MatSetValues calls =0
                      SuperLU_DIST run parameters:
                        Process grid nprow 2 x npcol 2
                        Equilibrate matrix TRUE
                        Matrix input mode 1
                        Replace tiny pivots TRUE
                        Use iterative refinement FALSE
                        Processors in row 2 col partition 2
                        Row permutation LargeDiag
                        Column permutation METIS_AT_PLUS_A
                        Parallel symbolic factorization FALSE
                        Repeated factorization SamePattern_SameRowPerm
            linear system matrix = precond matrix:
              type: mpiaij
              rows=128, cols=128
              total: nonzeros=736, allocated nonzeros=736
                not using I-node (on process 0) routines
        Down solver (pre-smoother) on level 1 -------------------------------
          KSP Object:          (mg_coarse_dmdarepart_mg_levels_1_)           4 MPI processes
            type: richardson
              Richardson: damping factor=1
            maximum iterations=2
          PC Object:          (mg_coarse_dmdarepart_mg_levels_1_)           4 MPI processes
            type: sor
              SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
              type: mpiaij
              rows=1024, cols=1024
              total: nonzeros=6528, allocated nonzeros=6528
        Up solver (post-smoother) same as down solver (pre-smoother)
          type: mpiaij
      Mat Object:       8 MPI processes
        type: mpiaij
    KSP Object:    (mg_levels_1_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_1_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=8192, cols=8192
        total: nonzeros=54784, allocated nonzeros=54784
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=65536, cols=65536
        total: nonzeros=448512, allocated nonzeros=448512
    type: mpiaij
============================= SECOND SOLVE ================================
Linear solve converged due to CONVERGED_RTOL iterations 8
  type: cg
  type: mg
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      type: dmdarepart
        type: preonly
        type: mg
            type: preonly
            type: lu
                    type: mpiaij
                    rows=128, cols=128
                        Matrix input mode 1
              type: mpiaij
              rows=128, cols=128
            type: richardson
            type: sor
              type: mpiaij
          type: mpiaij
        type: mpiaij
      type: richardson
      type: sor
        type: mpiaij
      type: richardson
      type: sor
        type: mpiaij
    type: mpiaij
#PETSc Option Table entries:
-ksp_converged_reason
-ksp_initial_guess_nonzero yes
-ksp_norm_type unpreconditioned
-ksp_rtol 1e-7
-ksp_type cg
-ksp_view
-max_tsteps 1
-mg_coarse_dmdarepart_ksp_constant_null_space
-mg_coarse_dmdarepart_ksp_type preonly
-mg_coarse_dmdarepart_mg_coarse_ksp_type preonly
-mg_coarse_dmdarepart_mg_coarse_pc_factor_mat_solver_package superlu_dist
-mg_coarse_dmdarepart_mg_coarse_pc_type lu
-mg_coarse_dmdarepart_mg_levels_ksp_type richardson
-mg_coarse_dmdarepart_pc_mg_galerkin
-mg_coarse_dmdarepart_pc_mg_levels 2
-mg_coarse_dmdarepart_pc_type mg
-mg_coarse_ksp_type preonly
-mg_coarse_pc_dmdarepart_factor 2
-mg_coarse_pc_type dmdarepart
-mg_levels_ksp_type richardson
-nout 8
-options_left
-pc_mg_galerkin
-pc_mg_levels 3
-pc_type mg
-ppe_max_niter 0
#End of PETSc Option Table entries
There are 2 unused database options. They are:
Option left: name:-max_tsteps value: 1
Option left: name:-nout value: 8
-ksp_type        cg
-ksp_rtol        1e-7
-options_left
-pc_type mg
-pc_mg_galerkin
-pc_mg_levels 3
# -mg_levels_ksp_max_it 1
# Subcomm
-ksp_view
-options_left
