[petsc-users] Matrix is missing diagonal entry
Wed Jan 21 17:35:26 CST 2015
On Wed, Jan 21, 2015 at 5:06 PM, Orxan Shibliyev <orxan.shibli at gmail.com>
wrote:
> I am solving Ax=b with KSP. I set the matrix (A) so that from first row to
> a certain row (row N) I used negative indices (see below). I got an error
> indicating that the matrix is
What do you mean by this? Matrix rows are always refered to by
non-negative, contiguous integers.
     Matt
> missing diagonal entry at 0 (zero). Does this mean that negative indexing
> is not working so that the row zero points to the actual first row which
> has negative index? Should not the rows with negative indices be ignored?
> In case, I checked the first row without negative index (row N) and its
> diagonal entry is not zero anyway.
> A =
> | negative index   |
> | non-zero value  | --> row N
> | non-zero value  |
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/7ac870ec/attachment.html>
