[petsc-users] Conversion between AIJ & BAIJ
Chung-Kan Huang ckhuangf at gmail.com
Wed Jan 21 14:55:47 CST 2015
On Wed, Jan 21, 2015 at 2:36 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 21, 2015 at 2:29 PM, Chung-Kan Huang <ckhuangf at gmail.com>
> wrote:
>> On Wed, Jan 21, 2015 at 2:15 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Jan 21, 2015 at 2:07 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>> wrote:
>>>> On Wed, Jan 21, 2015 at 2:01 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Jan 21, 2015 at 1:55 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Jan 21, 2015 at 1:44 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Jan 21, 2015 at 1:40 PM, Chung-Kan Huang <ckhuangf at gmail.com
>>>>>>> > wrote:
>>>>>>>> Then A & AB are not longer the same matrix.  They become complete
>>>>>>>> two individuals aren't they?
>>>>>>>> If I do whatever to AB after AB is created the A is still the same
>>>>>>>> old A and not going to be affected by the operations I do to AB.
>>>>>>> Yes.
>>>>>>>> What I am really looking for is a way to create two interfaces (one
>>>>>>>> as AIJ and one as BAIJ) but they both refer to the same matrix.
>>>>>>> Why would you ever want this? Why not just using BAIJ?
>>>>>> As I mentioned in the beginning.  There are parts of the code gets
>>>>>> benifit when AIJ is used and the other part gets benifit  if BAIJ is used.
>>>>>> For instance,
>>>>>> I'd like to use MatSetValuesBlocked but I also want to use ilu
>>>>>> constructed by AIJ instead of BAIJ (our experience found ilu from BAIJ
>>>>>> behaves funny sometimes.
>>>>> If the blocks truly are dense, then ILU(0) is identical on both.
>>>> Unfortunately the life is not that easy.  The blocks are spares and we
>>>> found ILU(1) works better for our case.
>>>> And besides that is not the only reason I want to have AIJ & BAIJ
>>>> interfaces, we have some code management issue and I am looking for short
>>>> cut to unite them.
>>>> So go back to the original question the short answer is no way?
>>> Yes, it would not make sense.
>>> What problem are you using ILU(1) for?
>> I am using it for flow simulation for reservoir problems.
> Have you considered trying algebraic multigrid?
>> Some issues we found is that
>> 1) for a * x = 0 it doesn't return x = 0
> This is impossible. There must be a bug in the code.
That was found in an old version of PETSc. It has been very carefully
checked.
Right now I have A matrix create as AIJ so I guess I can MatConvert it to
BAIJ after it is assembled and solved it with ILU(1) which will be using
block ilu and see what happens..
Kan
>   Thanks,
>      Matt
>> 2) After compared ILU(1) with BAIJ against with ILU(1) with AIJ I found
>> latter one is better.  I could not find anything wrong with my BAIJ version
>> though.  However, experiences suggested that BAIJ's ILU(1) should be better.
>> Thanks,
>> Kan
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Kan
>>>>>   Matt
>>>>>> Thanks,
>>>>>> Kan
>>>>>>>   Thanks,
>>>>>>>       Matt
>>>>>>>> Thanks,
>>>>>>>> Kan
>>>>>>>> On Wed, Jan 21, 2015 at 1:20 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Wed, Jan 21, 2015 at 12:56 PM, Chung-Kan Huang <
>>>>>>>>> ckhuangf at gmail.com> wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> So if I do
>>>>>>>>>> Mat A, AB;
>>>>>>>>>> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
>>>>>>>>>> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
>>>>>>>>>> MatSetBlockSize(AB, bs)
>>>>>>>>>> I can create AB as a BAIJ with block size of bs from A which is a
>>>>>>>>>> AIJ matrix.
>>>>>>>>>> So from this point I can use both A and AB and they will mean the
>>>>>>>>>> same matrix. Am I right?
>>>>>>>>> Yes
>>>>>>>>>> At the end of the program do I only destory one of them or both?
>>>>>>>>> Both
>>>>>>>>>> Do I need to worry about anything in terms of memory penalty?
>>>>>>>>> It is twice the memory. Its another matrix.
>>>>>>>>> Did you catch when Jed said you could jsut create the BAIJ up
>>>>>>>>> front?
>>>>>>>>>   Thanks,
>>>>>>>>>     Matt
>>>>>>>>>> Thanks,
>>>>>>>>>> Kan
>>>>>>>>>> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>>>   You can do a MatConvert() (requires another copy of the
>>>>>>>>>>> matrix) for the parts that benefit from BAIJ.
>>>>>>>>>>>   Barry
>>>>>>>>>>> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <
>>>>>>>>>>> > Hi,
>>>>>>>>>>> > Does PETSc provide means for conversion between AIJ & BAIJ.
>>>>>>>>>>> > My matrix is created as AIJ because it makes life easy for
>>>>>>>>>>> most part of the applications but some part of applications actually get
>>>>>>>>>>> some benefits with BAIJ.  So I wonder if a matrix can exist as two
>>>>>>>>>>> idenfities and I can use either format depend on which one is more
>>>>>>>>>>> convenient at run time.
>>>>>>>>>>> > So in my case the block size is fixed and identical for all
>>>>>>>>>>> blocks.
>>>>>>>>>>> > Thanks,
>>>>>>>>>>> > Kan
>>>>>>>>>> *Cheers*
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> *Cheers*
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> *Cheers*
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> *Cheers*
>>> experiments lead.
>>> -- Norbert Wiener
>> *Cheers*
> experiments lead.
> -- Norbert Wiener
*Cheers*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/5f381107/attachment.html>
