[petsc-users] Conversion between AIJ & BAIJ
Wed Jan 21 14:01:05 CST 2015
On Wed, Jan 21, 2015 at 1:55 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> On Wed, Jan 21, 2015 at 1:44 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jan 21, 2015 at 1:40 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>> wrote:
>>> Then A & AB are not longer the same matrix.  They become complete two
>>> individuals aren't they?
>>> If I do whatever to AB after AB is created the A is still the same old A
>>> and not going to be affected by the operations I do to AB.
>> Yes.
>>> What I am really looking for is a way to create two interfaces (one as
>>> AIJ and one as BAIJ) but they both refer to the same matrix.
>> Why would you ever want this? Why not just using BAIJ?
> As I mentioned in the beginning.  There are parts of the code gets benifit
> when AIJ is used and the other part gets benifit  if BAIJ is used.
> For instance,
> I'd like to use MatSetValuesBlocked but I also want to use ilu constructed
> by AIJ instead of BAIJ (our experience found ilu from BAIJ behaves funny
> sometimes.
If the blocks truly are dense, then ILU(0) is identical on both.
  Matt
> Thanks,
> Kan
>>   Thanks,
>>       Matt
>>> Thanks,
>>> Kan
>>> On Wed, Jan 21, 2015 at 1:20 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Jan 21, 2015 at 12:56 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> So if I do
>>>>> Mat A, AB;
>>>>> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
>>>>> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
>>>>> MatSetBlockSize(AB, bs)
>>>>> I can create AB as a BAIJ with block size of bs from A which is a AIJ
>>>>> matrix.
>>>>> So from this point I can use both A and AB and they will mean the same
>>>>> matrix. Am I right?
>>>> Yes
>>>>> At the end of the program do I only destory one of them or both?
>>>> Both
>>>>> Do I need to worry about anything in terms of memory penalty?
>>>> It is twice the memory. Its another matrix.
>>>> Did you catch when Jed said you could jsut create the BAIJ up front?
>>>>   Thanks,
>>>>     Matt
>>>>> Thanks,
>>>>> Kan
>>>>> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>>>   You can do a MatConvert() (requires another copy of the matrix) for
>>>>>> the parts that benefit from BAIJ.
>>>>>>   Barry
>>>>>> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>>>>> wrote:
>>>>>> > Hi,
>>>>>> > Does PETSc provide means for conversion between AIJ & BAIJ.
>>>>>> > My matrix is created as AIJ because it makes life easy for most
>>>>>> part of the applications but some part of applications actually get some
>>>>>> benefits with BAIJ.  So I wonder if a matrix can exist as two idenfities
>>>>>> and I can use either format depend on which one is more convenient at run
>>>>>> time.
>>>>>> > So in my case the block size is fixed and identical for all blocks.
>>>>>> > Thanks,
>>>>>> > Kan
>>>>> *Cheers*
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> *Cheers*
>> experiments lead.
>> -- Norbert Wiener
> *Cheers*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/d0917147/attachment-0001.html>
