[petsc-users] Conversion between AIJ & BAIJ
Wed Jan 21 13:44:18 CST 2015
On Wed, Jan 21, 2015 at 1:40 PM, Chung-Kan Huang <ckhuangf at gmail.com> wrote:
> Then A & AB are not longer the same matrix.  They become complete two
> individuals aren't they?
> If I do whatever to AB after AB is created the A is still the same old A
> and not going to be affected by the operations I do to AB.
Yes.
> What I am really looking for is a way to create two interfaces (one as AIJ
> and one as BAIJ) but they both refer to the same matrix.
Why would you ever want this? Why not just using BAIJ?
      Matt
> Thanks,
> Kan
> On Wed, Jan 21, 2015 at 1:20 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jan 21, 2015 at 12:56 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>> wrote:
>>> Hi,
>>> So if I do
>>> Mat A, AB;
>>> MatCreateAIJ(comm,m,n,M,N,d_nz, d_nnz,o_nz, o_nnz, &A);
>>> MatConvert(A, MATBAIJ, MAT_INITAL_MATRIX, &AB);
>>> MatSetBlockSize(AB, bs)
>>> I can create AB as a BAIJ with block size of bs from A which is a AIJ
>>> matrix.
>>> So from this point I can use both A and AB and they will mean the same
>>> matrix. Am I right?
>> Yes
>>> At the end of the program do I only destory one of them or both?
>> Both
>>> Do I need to worry about anything in terms of memory penalty?
>> It is twice the memory. Its another matrix.
>> Did you catch when Jed said you could jsut create the BAIJ up front?
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Kan
>>> On Tue, Jan 20, 2015 at 4:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>   You can do a MatConvert() (requires another copy of the matrix) for
>>>> the parts that benefit from BAIJ.
>>>>   Barry
>>>> > On Jan 20, 2015, at 4:33 PM, Chung-Kan Huang <ckhuangf at gmail.com>
>>>> wrote:
>>>> > Hi,
>>>> > Does PETSc provide means for conversion between AIJ & BAIJ.
>>>> > My matrix is created as AIJ because it makes life easy for most part
>>>> of the applications but some part of applications actually get some
>>>> benefits with BAIJ.  So I wonder if a matrix can exist as two idenfities
>>>> and I can use either format depend on which one is more convenient at run
>>>> time.
>>>> > So in my case the block size is fixed and identical for all blocks.
>>>> > Thanks,
>>>> > Kan
>>> *Cheers*
>> experiments lead.
>> -- Norbert Wiener
> *Cheers*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/ca80ee27/attachment.html>
