[petsc-users] PETSc 3.5.2 on Mac OS X Yosemite, configuring gives C preprocessor error
Mon Jan 19 10:31:10 CST 2015
> On Jan 19, 2015, at 1:52 AM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> On 18/01/15 09:48 PM, Barry Smith wrote:
>>   We need configure.log
>>    You do not need --download-blaslapack Apple always has them
> As of OS X 10.9 the BLAS Apple provided was known to have bugs. I only noticed any issue (If I remember correctly, "make test" failed) when configuring in single precision.
   Oh yeah. This is fixed in the commit https://bitbucket.org/petsc/petsc/commits/49b12944db1ca4c5c9e2e375d4aaed26e21ebbe9
  Barry
> However, this might be a reason to have petsc download BLAS/Lapack despite the libraries being available in Apple's framework.
>>    Suggest just running without passing the compiler names also.
>>   Barry
>>> On Jan 18, 2015, at 2:45 PM, Justin Dong <jdong217 at gmail.com> wrote:
>>> Hi all,
>>> I just updated to OS X Yosemite. I have the latest XCode and also reinstalled command line developer tools.
>>> When I try to install PETSc, I get the following error:
>>> ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack --download-mpich --with-debugging=0
>>>              Configuring PETSc to compile on your system
>>> TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:568)                        *******************************************************************************
>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
>>> Cannot find a C preprocessor
>>> Can someone explain to me what's going on here?
>>> Thanks,
>>> Justin
