[petsc-users] An advice on a linear system solution
Jed Brown jed at jedbrown.org
Mon Jan 12 11:05:33 CST 2015
Umut Tabak <u.tabak at tudelft.nl> writes:
> Thx for the swift reply, well, you mean directly or iteratively? I
> looked a bit more but I am not sure if that is possible iteratively or
> not, I guess it is not since the character of the blocks on the diagonal
> are not well suited to iterative solution techniques. Maybe I should
> look into field split documentation once more.
The first step to using fieldsplit is developing a good solver for (one
of) the diagonal blocks.  If you don't have that yet, consult the
literature and run experiments.  Good luck.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150112/5ceab16d/attachment.pgp>
