[petsc-users] Out of memory and parallel issues
TAY wee-beng zonexo at gmail.com
Thu Jan 1 02:15:44 CST 2015
On 1/1/2015 2:06 PM, Matthew Knepley wrote:
> On Wed, Dec 31, 2014 at 11:20 PM, TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
>     Hi,
>     I used to run my CFD code with 96 procs, with a grid size of 231 x
>     461 x 368.
>     I used MPI and partition my grid in the z direction. Hence with 96
>     procs (8 nodes, each 12 procs), each procs has a size of 231 x 461
>     x 3 or 231 x 461 x 4.
>     It worked fine.
>     Now I modified the code and added some more routines which
>     increases the fixed memory requirement per procs. However, the
>     grid size is still the same. But the code aborts while solving the
>     Poisson eqn, saying:
>     Out of memory trying to allocate XXX bytes
>     I'm using PETSc with HYPRE boomeramg to solve the linear Poisson
>     eqn. I am guessing that now the amt of memory per procs is less
>     because I added some routines which uses some memory. The result
>     is less memory available for the solving of the Poisson eqn.
> I would try GAMG instead of Hypre. It tends to be memory light
> compared to it.
>   -pc_type gamg
>   Thanks,
>      Matt
Hi Matt,
To use gamg, must I use use DMDA to partition the grid?
Also, does MPI partitioning in only the z direction affect parallel
performance? Since the MPI partition grid is almost like 2D plane with
3-4 cell thickness.
Lastly, using 10x10 = 100 procs seems to work for now, although there's
a wastage of 20 procs since each node has 12 procs.
Thanks!
>     I'm now changing to KSPBCGS but it seems to take forever. When I
>     abort it, the error msg is:
>     Out of memory. This could be due to allocating
>     [10]PETSC ERROR: too large an object or bleeding by not properly
>     [10]PETSC ERROR: destroying unneeded objects.
>     [10]PETSC ERROR: Memory allocated 0 Memory used by process
>     4028370944 <tel:4028370944>
>     [10]PETSC ERROR: Try running with -malloc_dump or -malloc_log for
>     info.
>     I can't use more procs because some procs will have a size of 231
>     x 461 x 2 (or even 1). This will give error since I need to
>     reference the nearby values along the z direction.
>     So what options do I have? I'm thinking of these at the moment:
>     1. Remove as much fixed overhead memory per procs as possible so
>     that there's enough memory for each procs.
>     2. Re-partition my grid in both x,y direction or x,y,z direction
>     so I will not encounter extremely skew grid dimensions per procs.
>     Btw, does having extremely skew grid dimensions affect the
>     performance in solving the linear eqn?
>     Are there other feasible options
>     Thank you.
>     Yours sincerely,
>     TAY wee-beng
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150101/fac85059/attachment.html>
