[petsc-users] Code sometimes work, sometimes hang when increase cpu usage
TAY wee-beng zonexo at gmail.com
Fri Dec 25 05:41:24 CST 2015
Sorry, there seems to be some problems with my valgrind. I have repeated
it again, with the optimized and debug version
Thank you.
Yours sincerely,
TAY wee-beng
On 25/12/2015 12:42 PM, Barry Smith wrote:
>> On Dec 24, 2015, at 10:37 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi,
>> I tried valgrind in MPI but it aborts very early, with the error msg regarding PETSc initialize.
>    It shouldn't "abort" it should print some error message and continue. Please send all the output when running with valgrind.
>     It is possible you are solving large enough problem that require configure --with-64-bit-indices . Does that resolve the problem?
>    Barry
>> I retry again, using a lower resolution.
>> GAMG  works, but BoomerAMG and hypre doesn't. Increasing cpu too high (80) also cause it to hang. 60 works fine.
>> My grid size is 98x169x169
>> But when I increase the resolution, GAMG can't work again.
>> I tried to increase the cpu no but it still doesn't work.
>> Previously, using single z direction partition, it work using GAMG and hypre. So what could be the problem?
>> Thank you.
>> Yours sincerely,
>> TAY wee-beng
>> On 25/12/2015 12:33 AM, Matthew Knepley wrote:
>>> It sounds like you have memory corruption in a different part of the code. Run in valgrind.
>>>    Matt
>>> On Thu, Dec 24, 2015 at 10:14 AM, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> I have this strange error. I converted my CFD code from a z directon only partition to the yz direction partition. The code works fine but when I increase the cpu no, strange things happen when solving the Poisson eqn.
>>> I increase cpu no from 24 to 40.
>>> Sometimes it works, sometimes it doesn't. When it doesn't, it just hangs there with no output, or it gives the error below:
>>> Using MPI_Barrier during debug shows that it hangs at
>>> call KSPSolve(ksp,b_rhs,xx,ierr).
>>> I use hypre BoomerAMG and GAMG (-poisson_pc_gamg_agg_nsmooths 1 -poisson_pc_type gamg)
>>> Why is this so random? Also how do I debug this type of problem.
>>> [32]PETSC ERROR: ------------------------------------------------------------------------
>>> [32]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>> [32]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>> [32]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>> [32]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>> [32]PETSC ERROR: likely location of problem given in stack below
>>> [32]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>> [32]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>> [32]PETSC ERROR:       INSTEAD the line number of the start of the function
>>> [32]PETSC ERROR:       is given.
>>> [32]PETSC ERROR: [32] HYPRE_SetupXXX line 174 /home/wtay/Codes/petsc-3.6.2/src/ksp/pc/impls/hypre/hypre.c
>>> [32]PETSC ERROR: [32] PCSetUp_HYPRE line 122 /home/wtay/Codes/petsc-3.6.2/src/ksp/pc/impls/hypre/hypre.c
>>> [32]PETSC ERROR: [32] PCSetUp line 945 /home/wtay/Codes/petsc-3.6.2/src/ksp/pc/interface/precon.c
>>> [32]PETSC ERROR: [32] KSPSetUp line 247 /home/wtay/Codes/petsc-3.6.2/src/ksp/ksp/interface/itfunc.c
>>> [32]PETSC ERROR: [32] KSPSolve line 510 /home/wtay/Codes/petsc-3.6.2/src/ksp/ksp/interface/itfunc.c
>>> [32]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>> [32]PETSC ERROR: Signal received
>>> [32]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>> [32]PETSC ERROR: Petsc Release Version 3.6.2, Oct, 02, 2015
>>> [32]PETSC ERROR: ./a.out on a petsc-3.6.2_shared_gnu_debug named n12-40 by wtay Thu Dec 24 17:01:51 2015
>>> [32]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/ --download-fblaslapack=1 --with-debugging=1 --download-hypre=1 --prefix=/home/wtay/Lib/petsc-3.6.2_shared_gnu_debug --known-mpi-shared=1 --with-shared-libraries --with-fortran-interfaces=1
>>> [32]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>> MPI_ABORT was invoked on rank 32 in communicator MPI_COMM_WORLD
>>> with errorcode 59.
>>> Thank you.
>>> Yours sincerely,
>>> TAY wee-beng
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
[wtay at n12-04:4]$ !1005
-bash: !1005: event not found
[wtay at n12-04:4]$ ~/Lib/valgrind-3.11.0/bin/valgrind --leak-check=yes ./a.out
==26133== Memcheck, a memory error detector
==26133== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==26133== Using Valgrind-3.11.0 and LibVEX; rerun with -h for copyright info
==26133== Command: ./a.out
==26133==
* hwloc has encountered what looks like an error from the operating system.
* L3 (cpuset 0x000003f0) intersects with NUMANode (P#0 cpuset 0x0000003f) without inclusion!
* Error occurred in topology.c line 942
* The following FAQ entry in a recent hwloc documentation may help:
*   What should I do when hwloc reports "operating system" warnings?
* Otherwise please report this error message to the hwloc user's mailing list,
* along with the output+tarball generated by the hwloc-gather-topology script.
   0.0000000000000000       0.59999999999999998        17.500000000000000        120.00000000000000        0.0000000000000000        1.0000000000000000        1.0000000000000000       0.40000000000000002                0     -400000
 0
 AB,AA,BB   -2.4770000226562843        2.4110000195214525        2.4770000226562843        2.3460000164341182
 size_x,size_y,size_z           76         130         136
 myid,jsta,jend,ksta,kend,ijk_sta,ijk_end           0           1         130           1         136           1     1343680
==26133== Warning: set address range perms: large range [0x4c96e040, 0x9693d704) (undefined)
==26133== Warning: set address range perms: large range [0x9693e040, 0xbb925ec4) (undefined)
 body_cg_ini  0.85000099999999779        9.9999999982738459E-007   6.9577187502060447
        3104  surfaces with wrong vertex ordering
 Warning - length difference between element and cell
 max_element_length,min_element_length,min_delta
   7.8475401769960568E-002   3.3499956100000006E-002   5.0000000000000003E-002
 maximum ngh_surfaces and ngh_vertics are           77          35
 minimum ngh_surfaces and ngh_vertics are           24          10
 min IIB_cell_no        1104
 max IIB_cell_no        1104
 final initial IIB_cell_no       55200
 min I_cell_no         677
 max I_cell_no         677
 final initial I_cell_no       33850
 size(IIB_cell_u),size(I_cell_u),size(IIB_equal_cell_u),size(I_equal_cell_u)       55200       33850       55200       33850
 IIB_I_cell_no_uvw_total1        1104        1096        1080         677         659         637
    1      0.02000000      0.29477817      0.35064783      1.20310939 -0.12558960E+03 -0.11164008E+02  0.13429373E+07
==26133== Warning: set address range perms: large range [0x10dfa8040, 0x157f77714) (undefined)
==26133== Warning: set address range perms: large range [0x157f78040, 0x17cf5fed4) (undefined)
    2      0.01334598      0.39731658      0.43604838      1.36260008 -0.14490188E+03 -0.76621036E+01  0.13428419E+07
==26133== Conditional jump or move depends on uninitialised value(s)
==26133==    at 0x7DB89CE: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB1B3E: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7BEA99: MAIN__ (ibm3d_high_Re.F90:4122)
==26133==    by 0x408F2E: main (ibm3d_high_Re.F90:3)
==26133==
==26133==    at 0x7DB6D27: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB7CCD: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB8F6D: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    at 0x7DB7D83: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    by 0x7BEAAA: MAIN__ (ibm3d_high_Re.F90:4122)
==26133==
==26133==
==26133==    by 0x7BEABB: MAIN__ (ibm3d_high_Re.F90:4122)
==26133==
==26133==
==26133==    by 0x7DBB1A4: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DBBC8E: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DAFEE6: _gfortran_transfer_array (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7B97CA: MAIN__ (ibm3d_high_Re.F90:4445)
==26133==
==26133==
==26133==
==26133==    by 0x4C3F8E: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/4/a.out)
==26133==    by 0x7B9800: MAIN__ (ibm3d_high_Re.F90:4447)
==26133==
==26133==    at 0x7DB89D7: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    at 0x92DED97: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92DD7E0: vfprintf (in /usr/lib64/libc-2.17.so)
==26133==    by 0x9307078: vsnprintf (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92E3CB1: snprintf (in /usr/lib64/libc-2.17.so)
==26133==    by 0x7DB86DF: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    at 0x92DEEBF: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D8B72: __mpn_extract_double (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92DF441: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D8B77: __mpn_extract_double (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DF9B1: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFA08: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFA35: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFA40: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFA6F: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFA7E: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFE6C: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFBD4: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFCB5: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFE41: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFE23: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    by 0x7DB6DC9: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB870D: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    at 0x7DB710F: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    at 0x7DB6F57: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    at 0x7DB6F3B: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    by 0x7DB6F9B: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133==    by 0x4C4061: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/4/a.out)
==26133==
==26133==
==26133==    at 0x92DEFDB: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFC73: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133== Use of uninitialised value of size 8
==26133==    at 0x92E0479: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7918: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92E047D: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D791B: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E04B3: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E04D8: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E063F: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7B67: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92E0512: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7B6E: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7F60: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92D7B80: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7FC2: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7B91: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7BDD: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7BE5: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7BEC: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7203: __mpn_add_n (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92D7BFF: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7BC7: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7BD7: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0543: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E056A: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0577: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E058C: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E05AB: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E05C3: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E05DF: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E05E5: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0785: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D79D5: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92E0619: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D79FC: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A26: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A79: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A88: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7ABA: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E04F8: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7EC4: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92E06A7: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7EDA: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7EDF: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7EE1: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7F95: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7F9D: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7FC0: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==
==26133==    at 0x92D7F67: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==
==26133==
==26133==    at 0x92D72B8: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==    by 0xFFEFFC54F: ???
==26133==
==26133==    at 0x92D72BB: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D72CE: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D72F8: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7301: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7365: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==    by 0xFFEFFC63F: ???
==26133==    by 0x92D7BC6: __mpn_mul (in /usr/lib64/libc-2.17.so)
==26133==    by 0x50DBEF2: PetscMemzero (petscsys.h:2008)
==26133==    by 0x13FFFFFF: ??? (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_osc_sm.so)
==26133==    by 0x908512F: ??? (in /usr/lib64/libpthread-2.17.so)
==26133==
==26133==    at 0x92D7329: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7330: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7370: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==
==26133==
==26133==    at 0x92E0603: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D79D7: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7AAA: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7F82: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7F8A: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D78CF: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92E0BC1: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D78D1: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D799A: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D79AA: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==
==26133== More than 100 errors detected.  Subsequent errors
==26133== will still be recorded, but in less detail than before.
==26133==    at 0x92D7977: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0BCE: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7EE6: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7F05: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7F77: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D79FE: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A0B: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A0D: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A9A: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A9E: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7A84: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E06B0: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0667: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0671: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0676: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E067C: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E0803: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    by 0x92E081E: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==    at 0x92E082C: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92E083B: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    by 0x92E0BA4: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==
==26133==    at 0x92DFA4A: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFA63: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92DFA69: __printf_fp (in /usr/lib64/libc-2.17.so)
==26133==
==26133== Syscall param write(buf) points to uninitialised byte(s)
==26133==    at 0x90841FD: ??? (in /usr/lib64/libpthread-2.17.so)
==26133==    by 0x7DB51C7: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB54BC: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB5597: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DBC03E: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB0DDE: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB39B8: _gfortran_st_write_done (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x4C413B: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/4/a.out)
==26133==  Address 0xcca3d50 is 432 bytes inside a block of size 8,192 alloc'd
==26133==    at 0x4C29C3D: malloc (vg_replace_malloc.c:299)
==26133==    by 0x7CE8914: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB516D: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB5B1C: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DAC6EF: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DACFCB: _gfortran_st_open (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x4C3929: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/4/a.out)
==26133==
==26133==    at 0x92D72D3: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==    by 0x4C41E6: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/4/a.out)
==26133==
==26133==    at 0x92D72E2: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D72EB: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133==    at 0x92D7351: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==26133==
==26133== Warning: set address range perms: large range [0x157f78028, 0x17cf5feec) (noaccess)
==26133== Warning: set address range perms: large range [0x10dfa8028, 0x157f7772c) (noaccess)
==26133== Warning: set address range perms: large range [0x9693e028, 0xbb925edc) (noaccess)
==26133== Warning: set address range perms: large range [0x4c96e028, 0x9693d71c) (noaccess)
==26133==
==26133== HEAP SUMMARY:
==26133==     in use at exit: 728,297 bytes in 9,515 blocks
==26133==   total heap usage: 673,080 allocs, 663,565 frees, 7,638,652,437 bytes allocated
==26133==
==26133== 1 bytes in 1 blocks are definitely lost in loss record 1 of 124
==26133==    by 0xE3DFA90: ???
==26133==    by 0x9929736: opal_db_base_store (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x8BD02B2: ompi_modex_send_string (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==    by 0x8BCC74A: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==    by 0x8BEC2BA: PMPI_Init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==    by 0x8536594: mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi_mpifh.so.2.5.2)
==26133==    by 0x4FB6CF1: petscinitialize_ (zstart.c:295)
==26133==    by 0x7A7582: MAIN__ (ibm3d_high_Re.F90:47)
==26133==
==26133== 7 bytes in 1 blocks are definitely lost in loss record 2 of 124
==26133==    by 0x9318529: strdup (in /usr/lib64/libc-2.17.so)
==26133==    by 0xE3DF9D5: ???
==26133==    by 0xD7BF47D: ???
==26133==    by 0x96692D7: orte_init (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==26133==    by 0x8BCC6BC: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==
==26133== 24 bytes in 1 blocks are definitely lost in loss record 11 of 124
==26133==    by 0x8BD0189: ompi_modex_send (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==    by 0x122E2527: ???
==26133==    by 0x8C07C52: mca_btl_base_select (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==    by 0x1121E870: ???
==26133==    by 0x8C0741D: mca_bml_base_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==    by 0x12B9E9FE: ???
==26133==    by 0x8C17D08: mca_pml_base_select (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==    by 0x8BCC9BE: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==
==26133== 376 (232 direct, 144 indirect) bytes in 1 blocks are definitely lost in loss record 107 of 124
==26133==    by 0x1121D984: ???
==26133==    by 0x12B9D648: ???
==26133==    by 0x8BCCD7D: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==
==26133== 536 (24 direct, 512 indirect) bytes in 1 blocks are definitely lost in loss record 111 of 124
==26133==    by 0x7DBBECA: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7DB46B9: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x7CE5E87: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==    by 0x400F4E2: _dl_init (in /usr/lib64/ld-2.17.so)
==26133==    by 0x4001459: ??? (in /usr/lib64/ld-2.17.so)
==26133==
==26133== 536 (24 direct, 512 indirect) bytes in 1 blocks are definitely lost in loss record 112 of 124
==26133==    by 0x7DB4791: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==26133==
==26133== 1,021 bytes in 21 blocks are definitely lost in loss record 116 of 124
==26133==    by 0x9306E07: vasprintf (in /usr/lib64/libc-2.17.so)
==26133==    by 0x92E3DD6: asprintf (in /usr/lib64/libc-2.17.so)
==26133==    by 0x9929F77: dlopen_foreachfile (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x990DAFC: mca_base_component_find (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x9917362: mca_base_framework_components_register (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x99177EB: mca_base_framework_register (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x9917841: mca_base_framework_open (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x98F7B48: opal_init (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x96691A4: orte_init (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==26133==
==26133== 4,224 (1,152 direct, 3,072 indirect) bytes in 48 blocks are definitely lost in loss record 119 of 124
==26133==    by 0x994078A: opal_hwloc191_hwloc_bitmap_alloc (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x9952649: look_sysfscpu (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x9954569: hwloc_look_linuxfs (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x99693BA: opal_hwloc191_hwloc_topology_load (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x993CA9D: opal_hwloc_base_get_topology (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==26133==    by 0x8BCCABC: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==26133==
==26133== 5,004 bytes in 93 blocks are definitely lost in loss record 120 of 124
==26133==    at 0x4C2BB8A: realloc (vg_replace_malloc.c:785)
==26133==    by 0x9306DDA: vasprintf (in /usr/lib64/libc-2.17.so)
==26133==
==26133== LEAK SUMMARY:
==26133==    definitely lost: 7,489 bytes in 168 blocks
==26133==    indirectly lost: 4,240 bytes in 53 blocks
==26133==      possibly lost: 0 bytes in 0 blocks
==26133==    still reachable: 716,568 bytes in 9,294 blocks
==26133==         suppressed: 0 bytes in 0 blocks
==26133== Reachable blocks (those to which a pointer was found) are not shown.
==26133== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==26133==
==26133== For counts of detected and suppressed errors, rerun with: -v
==26133== Use --track-origins=yes to see where uninitialised values come from
==26133== ERROR SUMMARY: 240758 errors from 157 contexts (suppressed: 2 from 2)
[wtay at n12-04:4]$
[wtay at hpc12:1]$ ~/Lib/valgrind-3.11.0/bin/valgrind --leak-check=yes ./a.out
==20772== Memcheck, a memory error detector
==20772== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==20772== Using Valgrind-3.11.0 and LibVEX; rerun with -h for copyright info
==20772== Command: ./a.out
==20772==
 0
==20772== Warning: set address range perms: large range [0x4ddee040, 0x97dbd704) (undefined)
==20772== Warning: set address range perms: large range [0x97dbe040, 0xbcda5ec4) (undefined)
^C==20772==
==20772== Process terminating with default action of signal 2 (SIGINT)
==20772==    at 0x937DB7D: ??? (in /usr/lib64/libc-2.17.so)
==20772==    by 0x9936905: poll_dispatch (poll.c:165)
==20772==    by 0x992E723: opal_libevent2021_event_base_loop (event.c:1633)
==20772==    by 0x968B24D: orte_progress_thread_engine (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==20772==    by 0x907DDF4: start_thread (in /usr/lib64/libpthread-2.17.so)
==20772==    by 0x93881AC: clone (in /usr/lib64/libc-2.17.so)
==20772==
==20772== HEAP SUMMARY:
==20772==     in use at exit: 2,771,247,738 bytes in 17,476 blocks
==20772==   total heap usage: 35,685 allocs, 18,209 frees, 3,723,954,797 bytes allocated
==20772==
^C^C^C^C^C^C^C^C^C^C==20772== 336 bytes in 1 blocks are possibly lost in loss record 6,282 of 7,216
==20772==    at 0x4C2B9B4: calloc (vg_replace_malloc.c:711)
==20772==    by 0x4011E84: _dl_allocate_tls (in /usr/lib64/ld-2.17.so)
==20772==    by 0x907E990: pthread_create@@GLIBC_2.2.5 (in /usr/lib64/libpthread-2.17.so)
==20772==    by 0x98FB7D5: opal_thread_start (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==20772==    by 0x968B719: orte_ess_base_app_setup (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==20772==    by 0xD7BF378: rte_init (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_ess_singleton.so)
==20772==    by 0x96692D7: orte_init (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==20772==    by 0x8BCC6BC: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==20772==    by 0x8BEC2BA: PMPI_Init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==20772==    by 0x8536594: mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi_mpifh.so.2.5.2)
==20772==    by 0x4FB6CF1: petscinitialize_ (zstart.c:295)
==20772==    by 0x8A5CBF: MAIN__ (ibm3d_high_Re.F90:47)
==20772==
==20772== 1,021 bytes in 21 blocks are definitely lost in loss record 6,395 of 7,216
==20772==    at 0x4C29C3D: malloc (vg_replace_malloc.c:299)
==20772==    by 0x9306E07: vasprintf (in /usr/lib64/libc-2.17.so)
==20772==    by 0x92E3DD6: asprintf (in /usr/lib64/libc-2.17.so)
==20772==    by 0x9929F77: dlopen_foreachfile (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==20772==    by 0x990DAFC: mca_base_component_find (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==20772==    by 0x9917362: mca_base_framework_components_register (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==20772==    by 0x99177EB: mca_base_framework_register (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==20772==    by 0x9917841: mca_base_framework_open (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==20772==    by 0x98F7B48: opal_init (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==20772==    by 0x96691A4: orte_init (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==20772==
==20772== 5,004 bytes in 93 blocks are definitely lost in loss record 7,112 of 7,216
==20772==    at 0x4C2BB8A: realloc (vg_replace_malloc.c:785)
==20772==    by 0x9306DDA: vasprintf (in /usr/lib64/libc-2.17.so)
==20772==
==20772== LEAK SUMMARY:
==20772==    definitely lost: 6,025 bytes in 114 blocks
==20772==    indirectly lost: 0 bytes in 0 blocks
==20772==      possibly lost: 336 bytes in 1 blocks
==20772==    still reachable: 2,771,241,377 bytes in 17,361 blocks
==20772==         suppressed: 0 bytes in 0 blocks
==20772== Reachable blocks (those to which a pointer was found) are not shown.
==20772== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==20772==
==20772== For counts of detected and suppressed errors, rerun with: -v
==20772== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 2 from 2)
Killed
[wtay at hpc12:1]$ qsub -I -X -l nodes=1:ppn=32:typef
qsub: waiting for job 7354.hpc12.hpc to start
qsub: job 7354.hpc12.hpc ready
Welcome
- For support contact beheer-o-linux-ict at tudelft.nl
- Documentation at /opt/ud/LOCAL/doc/LOCALdoc.txt
System state:
 11:50:53 up 56 days, 21:37,  0 users,  load average: 0.00, 0.01, 0.19
Filesystem                      Size  Used Avail Use% Mounted on
hpc12:/export/disk1/home1/wtay   30T   28T  2.5T  92% /home/wtay
WARNING: Total disk usage > 90%
[wtay at n12-72:~]$ cd Results/1
[wtay at n12-72:1]$ LD_PRELOAD=/home/wtay/Lib/valgrind-3.11.0/lib/valgrind/libmpiwrap-amd64-linux.so
[wtay at n12-72:1]$ ~/Lib/valgrind-3.11.0/bin/valgrind --leak-check=yes ./a.out
==41023== Memcheck, a memory error detector
==41023== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==41023== Using Valgrind-3.11.0 and LibVEX; rerun with -h for copyright info
==41023== Command: ./a.out
==41023==
==41023== Syscall param write(buf) points to uninitialised byte(s)
==41023==    at 0x90841FD: ??? (in /usr/lib64/libpthread-2.17.so)
==41023==    by 0x1142C51A: mca_btl_openib_add_procs (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_btl_openib.so)
==41023==    by 0x1121D484: mca_bml_r2_add_procs (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_bml_r2.so)
==41023==    by 0x12B9D648: mca_pml_ob1_add_procs (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_pml_ob1.so)
==41023==    by 0x8BCCD7D: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x8BEC2BA: PMPI_Init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x8536594: mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi_mpifh.so.2.5.2)
==41023==    by 0x4FB6CF1: petscinitialize_ (zstart.c:295)
==41023==    by 0x8A5CBF: MAIN__ (ibm3d_high_Re.F90:47)
==41023==    by 0x8E9916: main (ibm3d_high_Re.F90:3)
==41023==  Address 0xffeffea48 is on thread 1's stack
==41023==  in frame #1, created by mca_btl_openib_add_procs (???:)
==41023==
 0
==41023== Warning: set address range perms: large range [0x4ddee040, 0x97dbd704) (undefined)
==41023== Warning: set address range perms: large range [0x97dbe040, 0xbcda5ec4) (undefined)
 min I_cell_no         677
 max I_cell_no         677
==41023== Warning: set address range perms: large range [0x10f828040, 0x1597f7714) (undefined)
==41023== Warning: set address range perms: large range [0x1597f8040, 0x17e7dfed4) (undefined)
==41023== Conditional jump or move depends on uninitialised value(s)
==41023==    at 0x7DB89CE: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB1B3E: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x8E54A4: MAIN__ (ibm3d_high_Re.F90:4106)
==41023==
==41023==    at 0x7DB89D7: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x92DED97: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92DD7E0: vfprintf (in /usr/lib64/libc-2.17.so)
==41023==    by 0x9307078: vsnprintf (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92E3CB1: snprintf (in /usr/lib64/libc-2.17.so)
==41023==    by 0x7DB86DF: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x92DEEBF: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D8B72: __mpn_extract_double (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92DF441: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D8B77: __mpn_extract_double (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DEFDB: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFC73: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023== Use of uninitialised value of size 8
==41023==    at 0x92E0479: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7918: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92E047D: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D791B: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E04B3: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E04D8: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E063F: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7B67: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92E0512: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7B6E: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7F60: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92D7B80: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7FC2: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7B91: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7BDD: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7BE5: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7BEC: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7203: __mpn_add_n (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92D7BFF: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7BC7: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7BD7: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E0543: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E056A: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E0577: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E058C: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E05AB: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E05C3: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E05DF: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E05E5: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E0785: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D79D5: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92E0619: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D79FC: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A26: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A79: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A88: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7ABA: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E04F8: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7EC4: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92E06A7: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7EDA: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7EDF: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7EE1: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7F95: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7F9D: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7FC0: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==
==41023==    at 0x92D7F67: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==
==41023==
==41023==    at 0x92D72B8: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==    by 0xFFEFFC38F: ???
==41023==
==41023==    at 0x92D72BB: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D72CE: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D72F8: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7301: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7365: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==    by 0xFFEFFC47F: ???
==41023==    by 0x92D7BC6: __mpn_mul (in /usr/lib64/libc-2.17.so)
==41023==    by 0x908512F: ??? (in /usr/lib64/libpthread-2.17.so)
==41023==    by 0x50DBEF2: PetscMemzero (petscsys.h:2008)
==41023==
==41023==    at 0x92D7329: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7330: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7370: __mpn_addmul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==
==41023==
==41023==    at 0x92E0603: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D78CF: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92E0BC1: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D78D1: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D799A: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D79AA: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7977: __mpn_lshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E0BCE: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7EE6: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7F05: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7F77: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D79FE: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A0B: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A0D: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A9A: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A9E: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A84: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFA4A: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFA63: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFA69: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFA6F: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFBD4: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFCB5: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x7DB6D27: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB6DC9: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB870D: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB710F: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    by 0x7DB6F9B: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    by 0x8E54C3: MAIN__ (ibm3d_high_Re.F90:4106)
==41023==
==41023==
==41023==
==41023==    by 0x8E54E2: MAIN__ (ibm3d_high_Re.F90:4106)
==41023==
==41023==
==41023==    at 0x92D79D7: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7AAA: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7F82: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7F8A: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E0803: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    by 0x92E081E: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==
==41023== More than 100 errors detected.  Subsequent errors
==41023== will still be recorded, but in less detail than before.
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==    at 0x92E082C: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92E083B: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    by 0x92E0BA4: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==    by 0x7DBB1A4: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DBBC8E: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DAFEE6: _gfortran_transfer_array (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x8E866D: MAIN__ (ibm3d_high_Re.F90:4445)
==41023==
==41023==
==41023==    at 0x7DB8AC3: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB8AD1: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x92D7F4F: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==    by 0x7DB9DC8: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x92D7A28: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A39: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D7A4D: __mpn_rshift (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DEAD9: hack_digit.13549 (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92DF8D7: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    by 0x92DEAE0: hack_digit.13549 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==
==41023==
==41023==
==41023==
==41023==    at 0x92D7EE8: __mpn_mul_1 (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    by 0x92DF9AA: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DF9B1: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFA08: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    by 0x92DFA25: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFA35: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFA40: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFE6C: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFE9E: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFEBE: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFEE5: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFEFC: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFE41: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DFE23: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    by 0x7DB9DFB: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB6EE2: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB6F57: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB6F3B: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x92DB7E0: vfprintf (in /usr/lib64/libc-2.17.so)
==41023==    by 0x7DB75CC: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x92D928B: _itoa_word (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92DBCA0: vfprintf (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92D9295: _itoa_word (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DBCE8: vfprintf (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DB8AB: vfprintf (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x92DB92E: vfprintf (in /usr/lib64/libc-2.17.so)
==41023==
==41023==    at 0x7DB8ADF: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB8AE8: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB8B7B: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    at 0x7DB8BCD: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==    by 0x7DB8C3B: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==
==41023==
==41023==    by 0x7DB8C72: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023==
==41023==
==41023==    at 0x92DFA7E: __printf_fp (in /usr/lib64/libc-2.17.so)
==41023==    by 0x4EE643: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/1/a.out)
==41023==    by 0x8E86B6: MAIN__ (ibm3d_high_Re.F90:4447)
==41023==
==41023==
==41023==
==41023==    by 0x7DB51C7: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB54BC: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB5597: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DBC03E: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB0DDE: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB39B8: _gfortran_st_write_done (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x4EE652: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/1/a.out)
==41023==  Address 0xcba09b0 is 432 bytes inside a block of size 8,192 alloc'd
==41023==    at 0x4C29C3D: malloc (vg_replace_malloc.c:299)
==41023==    by 0x7CE8914: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB516D: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB5B1C: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DAC6EF: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DACFCB: _gfortran_st_open (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x4EDEF9: __body_MOD_write_body_tecplot_pressure (in /home/wtay/Results/1/a.out)
==41023==
==41023== Warning: set address range perms: large range [0x1597f8028, 0x17e7dfeec) (noaccess)
==41023== Warning: set address range perms: large range [0x10f828028, 0x1597f772c) (noaccess)
==41023== Warning: set address range perms: large range [0x97dbe028, 0xbcda5edc) (noaccess)
==41023== Warning: set address range perms: large range [0x4ddee028, 0x97dbd71c) (noaccess)
==41023==    by 0x1144030B: udcm_module_finalize (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_btl_openib.so)
==41023==    by 0x11429EAB: mca_btl_openib_finalize (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_btl_openib.so)
==41023==    by 0x8C0764F: mca_btl_base_close (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x9917974: mca_base_framework_close (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x8BCD7BD: ompi_mpi_finalize (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x4F9DF45: PetscFinalize (pinit.c:1367)
==41023==    by 0x4FB752A: petscfinalize_ (zstart.c:458)
==41023==    by 0x41A618: __global_data_MOD_de_ini_var (global.F90:2991)
==41023==    by 0x8E98C4: MAIN__ (ibm3d_high_Re.F90:4545)
==41023==  Address 0xffeffb6f4 is on thread 1's stack
==41023==  in frame #1, created by udcm_module_finalize (???:)
==41023==
==41023==    by 0x1142DE2F: device_destruct (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_btl_openib.so)
==41023==    by 0x11429F98: mca_btl_openib_finalize (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_btl_openib.so)
==41023==  Address 0xffeffb768 is on thread 1's stack
==41023==  in frame #1, created by device_destruct (???:)
==41023==
==41023==    by 0x1142DB71: btl_openib_component_close (in /opt/ud/openmpi-1.8.8/lib/openmpi/mca_btl_openib.so)
==41023==    by 0x990E9F8: mca_base_component_close (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x990EA71: mca_base_components_close (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x8C07694: mca_btl_base_close (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==  Address 0xffeffb754 is on thread 1's stack
==41023==  in frame #1, created by btl_openib_component_close (???:)
==41023==
==41023==
==41023== HEAP SUMMARY:
==41023==     in use at exit: 753,369 bytes in 9,581 blocks
==41023==   total heap usage: 672,580 allocs, 662,999 frees, 7,639,468,235 bytes allocated
==41023==
==41023== 1 bytes in 1 blocks are definitely lost in loss record 1 of 171
==41023==    by 0xE3DFA90: ???
==41023==    by 0x9929736: opal_db_base_store (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x8BD02B2: ompi_modex_send_string (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x8BCC74A: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==
==41023== 7 bytes in 1 blocks are definitely lost in loss record 2 of 171
==41023==    by 0x9318529: strdup (in /usr/lib64/libc-2.17.so)
==41023==    by 0xE3DF9D5: ???
==41023==    by 0xD7BF47D: ???
==41023==    by 0x96692D7: orte_init (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==41023==    by 0x8BCC6BC: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==
==41023== 8 bytes in 1 blocks are definitely lost in loss record 4 of 171
==41023==    by 0x1142F9AA: ???
==41023==    by 0x8C07C52: mca_btl_base_select (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x1121E870: ???
==41023==    by 0x8C0741D: mca_bml_base_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x12B9E9FE: ???
==41023==    by 0x8C17D08: mca_pml_base_select (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x8BCC9BE: ompi_mpi_init (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==
==41023== 8 bytes in 1 blocks are definitely lost in loss record 5 of 171
==41023==    by 0x4C2BB0B: realloc (vg_replace_malloc.c:785)
==41023==    by 0x98F6177: opal_pointer_array_add (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x1142BEA5: ???
==41023==    by 0x1121D484: ???
==41023==    by 0x12B9D648: ???
==41023==
==41023== 16 bytes in 1 blocks are definitely lost in loss record 9 of 171
==41023==    by 0x1142E3DA: ???
==41023==
==41023== 16 bytes in 1 blocks are definitely lost in loss record 10 of 171
==41023==    by 0x1142E45F: ???
==41023==
==41023== 16 bytes in 1 blocks are definitely lost in loss record 11 of 171
==41023==    by 0x1142E4DD: ???
==41023==
==41023== 16 bytes in 1 blocks are definitely lost in loss record 12 of 171
==41023==    by 0x1142BECD: ???
==41023==
==41023== 24 bytes in 1 blocks are definitely lost in loss record 19 of 171
==41023==    by 0x8BD0189: ompi_modex_send (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x122E2527: ???
==41023==
==41023== 27 bytes in 1 blocks are definitely lost in loss record 21 of 171
==41023==    by 0x9306E07: vasprintf (in /usr/lib64/libc-2.17.so)
==41023==    by 0x92E3DD6: asprintf (in /usr/lib64/libc-2.17.so)
==41023==    by 0x114302B6: ???
==41023==
==41023== 38 bytes in 1 blocks are definitely lost in loss record 77 of 171
==41023==    by 0x1142D9DE: ???
==41023==    by 0x1142FB03: ???
==41023==
==41023== 64 bytes in 4 blocks are definitely lost in loss record 114 of 171
==41023==    by 0x1142C0C4: ???
==41023==
==41023== 64 bytes in 4 blocks are definitely lost in loss record 115 of 171
==41023==    by 0x1142C008: ???
==41023==
==41023== 128 (112 direct, 16 indirect) bytes in 1 blocks are definitely lost in loss record 131 of 171
==41023==    by 0x1142882E: ???
==41023==    by 0x1142ECE7: ???
==41023==
==41023== 160 bytes in 1 blocks are definitely lost in loss record 136 of 171
==41023==    by 0x1142F718: ???
==41023==
==41023== 169 bytes in 8 blocks are definitely lost in loss record 137 of 171
==41023==    by 0x1143B258: ???
==41023==    by 0x1143B53A: ???
==41023==    by 0x1143B987: ???
==41023==    by 0x1142E258: ???
==41023==
==41023== 192 (112 direct, 80 indirect) bytes in 1 blocks are definitely lost in loss record 140 of 171
==41023==    by 0x1142BE2D: ???
==41023==
==41023== 211 (184 direct, 27 indirect) bytes in 1 blocks are definitely lost in loss record 141 of 171
==41023==    by 0x10C1362C: ???
==41023==    by 0x8C0EDC1: mca_mpool_base_module_create (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x114302FA: ???
==41023==
==41023== 448 (232 direct, 216 indirect) bytes in 1 blocks are definitely lost in loss record 148 of 171
==41023==    by 0x1121D984: ???
==41023==
==41023== 536 (24 direct, 512 indirect) bytes in 1 blocks are definitely lost in loss record 151 of 171
==41023==    by 0x7DBBECA: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7DB46B9: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x7CE5E87: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==    by 0x400F4E2: _dl_init (in /usr/lib64/ld-2.17.so)
==41023==    by 0x4001459: ??? (in /usr/lib64/ld-2.17.so)
==41023==
==41023== 536 (24 direct, 512 indirect) bytes in 1 blocks are definitely lost in loss record 152 of 171
==41023==    by 0x7DB4791: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==41023==
==41023== 1,021 bytes in 21 blocks are definitely lost in loss record 159 of 171
==41023==    by 0x9929F77: dlopen_foreachfile (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x990DAFC: mca_base_component_find (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x9917362: mca_base_framework_components_register (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x99177EB: mca_base_framework_register (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x9917841: mca_base_framework_open (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x98F7B48: opal_init (in /opt/ud/openmpi-1.8.8/lib/libopen-pal.so.6.2.2)
==41023==    by 0x96691A4: orte_init (in /opt/ud/openmpi-1.8.8/lib/libopen-rte.so.7.0.6)
==41023==
==41023== 1,472 bytes in 1 blocks are definitely lost in loss record 161 of 171
==41023==    by 0x8BB1EA0: ompi_free_list_grow (in /opt/ud/openmpi-1.8.8/lib/libmpi.so.1.6.3)
==41023==    by 0x1142E532: ???
==41023==
==41023== 2,304 bytes in 1 blocks are definitely lost in loss record 163 of 171
==41023==    by 0x1142E44D: ???
==41023==
==41023== 2,304 bytes in 1 blocks are definitely lost in loss record 164 of 171
==41023==    by 0x1142E4CB: ???
==41023==
==41023== 5,004 bytes in 93 blocks are definitely lost in loss record 166 of 171
==41023==    at 0x4C2BB8A: realloc (vg_replace_malloc.c:785)
==41023==    by 0x9306DDA: vasprintf (in /usr/lib64/libc-2.17.so)
==41023==
==41023== LEAK SUMMARY:
==41023==    definitely lost: 13,427 bytes in 151 blocks
==41023==    indirectly lost: 1,363 bytes in 8 blocks
==41023==      possibly lost: 0 bytes in 0 blocks
==41023==    still reachable: 738,579 bytes in 9,422 blocks
==41023==         suppressed: 0 bytes in 0 blocks
==41023== Reachable blocks (those to which a pointer was found) are not shown.
==41023== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==41023==
==41023== For counts of detected and suppressed errors, rerun with: -v
==41023== Use --track-origins=yes to see where uninitialised values come from
==41023== ERROR SUMMARY: 89912 errors from 203 contexts (suppressed: 2 from 2)
[wtay at n12-72:1]$
