[petsc-users] Code sometimes work, sometimes hang when increase cpu usage
TAY wee-beng zonexo at gmail.com
Thu Dec 24 10:14:41 CST 2015
I have this strange error. I converted my CFD code from a z directon
only partition to the yz direction partition. The code works fine but
when I increase the cpu no, strange things happen when solving the
Poisson eqn.
I increase cpu no from 24 to 40.
Sometimes it works, sometimes it doesn't. When it doesn't, it just hangs
there with no output, or it gives the error below:
Using MPI_Barrier during debug shows that it hangs at
call KSPSolve(ksp,b_rhs,xx,ierr).
I use hypre BoomerAMG and GAMG (-poisson_pc_gamg_agg_nsmooths 1
-poisson_pc_type gamg)
Why is this so random? Also how do I debug this type of problem.
[32]PETSC ERROR:
[32]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[32]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[32]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[32]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
OS X to find memory corruption errors
[32]PETSC ERROR: likely location of problem given in stack below
[32]PETSC ERROR: ---------------------  Stack Frames
[32]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,
[32]PETSC ERROR:       INSTEAD the line number of the start of the function
[32]PETSC ERROR:       is given.
[32]PETSC ERROR: [32] HYPRE_SetupXXX line 174
/home/wtay/Codes/petsc-3.6.2/src/ksp/pc/impls/hypre/hypre.c
[32]PETSC ERROR: [32] PCSetUp_HYPRE line 122
[32]PETSC ERROR: [32] PCSetUp line 945
/home/wtay/Codes/petsc-3.6.2/src/ksp/pc/interface/precon.c
[32]PETSC ERROR: [32] KSPSetUp line 247
/home/wtay/Codes/petsc-3.6.2/src/ksp/ksp/interface/itfunc.c
[32]PETSC ERROR: [32] KSPSolve line 510
[32]PETSC ERROR: --------------------- Error Message
[32]PETSC ERROR: Signal received
[32]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[32]PETSC ERROR: Petsc Release Version 3.6.2, Oct, 02, 2015
[32]PETSC ERROR: ./a.out on a petsc-3.6.2_shared_gnu_debug named n12-40
by wtay Thu Dec 24 17:01:51 2015
[32]PETSC ERROR: Configure options --with-mpi-dir=/opt/ud/openmpi-1.8.8/
--download-fblaslapack=1 --with-debugging=1 --download-hypre=1
--prefix=/home/wtay/Lib/petsc-3.6.2_shared_gnu_debug
--known-mpi-shared=1 --with-shared-libraries --with-fortran-interfaces=1
[32]PETSC ERROR: #1 User provided function() line 0 in  unknown file
MPI_ABORT was invoked on rank 32 in communicator MPI_COMM_WORLD
with errorcode 59.
Thank you.
Yours sincerely,
TAY wee-beng
