[petsc-users] Distributing data along with DMPlex
Tue Dec 22 08:51:20 CST 2015
On Tue, Dec 22, 2015 at 7:17 AM, Alejandro D Otero <aotero at fi.uba.ar> wrote:
> Thanks for your answer.
> In principle, this is what I want, although I know that this doesn't
> scale. At this point I am reading the mesh in only one proc so I have all
> the properties there, that is why after that I need to distribute the mesh
> along with the data.
> Is there a better solution within this scheme (only one proc reads mesh
> data)?
Most physical problems that I deal with decouple properties from the mesh.
This seems reasonable since the mesh is
just a crutch to solve the continuum problem. So, for example, in PyLith (
https://geodynamics.org/cig/software/pylith/),
we read in/generate a mesh in serial, manipulate it to add faults etc.,
mark the volumes/boundaries, distribute it, and
then in parallel for each local marked section we queries a spatial
database to get the properties and boundary data.
By summer, we will have parallel read for the initial mesh.
    Matt
> Regards,
> Alejandro
> On Tue, Dec 22, 2015 at 1:11 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Dec 17, 2015 at 1:27 PM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> So you would use something like DMPlexDistributeField()
>>> <http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMPlexDistributeField.html> in
>>> that case. You have your original/global DM, PetscSection, and Vec of
>>> values. Then using the PetscSF that was created during DMPlexDistribute,
>>> you map the global stuff into the local stuff.
>> Justin is correct. However, I will note that this strategy is not
>> scalable. Usually the data is much larger than the mesh,
>> so this runs out of memory much sooner. Are you sure that this is what
>> you want?
>>   Thanks,
>>      Matt
>>> On Thu, Dec 17, 2015 at 11:21 AM, Alejandro D Otero <aotero at fi.uba.ar>
>>> wrote:
>>>> Thanks,
>>>> The problem then is that after DMPlexDistribute the DMPlex 'points' are
>>>> renumbered. So if the values are related to each point in the original
>>>> numbering how do I set the values after the distribution. I know the
>>>> property stored in the vector related to the entities with the numbering of
>>>> the original mesh which I use to create the first DMPlex.
>>>> Ideally for me, I would like to set the values in the vector before
>>>> DMPlexDistribute and get the vector components renumbered and redistributed
>>>> accordingly in a global vector. And then, get the local vector.
>>>> Hope it could be more clear now.
>>>> Regards,
>>>> Alejandro
>>>> On Wed, Dec 16, 2015 at 7:01 PM, Justin Chang <jychang48 at gmail.com>
>>>> wrote:
>>>>> I think you would follow this order:
>>>>> 1*) create a DMPlex (depth, chart, etc) on rank 0. Other ranks have an
>>>>> empty DM
>>>>> 2) DMPlexDistribute()
>>>>> 3*) Create the PetscSection
>>>>> 4) DMCreateGlobalVector()
>>>>> 5) DMCreateLocalVector()
>>>>> Now you have a global vector and a local vector for your distributed
>>>>> DMPlex. The mapping/ghosting/etc of dofs is already taken care of.
>>>>> * if you're using standard Galerkin FE then in SNES examples 12 and 62
>>>>> (and maybe others?) the first step is handled through the mesh generation
>>>>> functions and step 3 is handled through step 4
>>>>> Thanks,
>>>>> Justin
>>>>> On Wednesday, December 16, 2015, Alejandro D Otero <aotero at fi.uba.ar>
>>>>> wrote:
>>>>>> Hi, I need some help understanding how to distribute data together
>>>>>> with a dmplex representing a FE mesh.
>>>>>> At the beginning I define the structure of the dmplex assigning
>>>>>> certain number of DoF to cells, edges and vertexes, in one process (the
>>>>>> dmplex in the rest is empty)
>>>>>> I create a petscsecton and I create an associated global vector with
>>>>>> the quantities I want to store.
>>>>>> Then I distribute the dmplex over all the processes.
>>>>>> * Although this does not perform well it is just a starting point. I
>>>>>> know it has to be improved.
>>>>>> I would like to have the global vector distributed accordingly so
>>>>>> that each process has access to the corresponding local part with its DoF
>>>>>> (possibly adding some ghost values corresponding to the shared DoF not
>>>>>> taken care by it).
>>>>>> Is there any 'correct' way to do that in PETSc?
>>>>>> Thanks in advance,
>>>>>> Alejandro
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151222/66e5ef6d/attachment-0001.html>
