[petsc-users] Eigenvalue problem in batch
venkatesh g venkateshgk.j at gmail.com
Fri Dec 18 02:40:42 CST 2015
Hi Timothee,
Yes I have A_0001.bin ... A_1000.bin and B_0001.bin... B1000.bin. Yes is it
possible to submit at same time ?
Venkatesh
On Fri, Dec 18, 2015 at 1:28 PM, Timothée Nicolas <
timothee.nicolas at gmail.com> wrote:
> Hi,
> Can you be a bit more specific ? You have 1000 different files for A and B
> ? Like, you have A_0001.bin, A_0002.bin, ... A_1000.bin and B_0001.bin,
> B_0002.bin, ... B_1000.bin ?
> In that case it's a bash problem and not a petsc problem, you just need to
> make a loop on an integer i, use something like
> printf -v i2 "%04d" ${i}
> so that i2 is written as 0001, 0002, ... 1000, and not as 1, 2, ... ,
> 1000, concatenate i2 with 'A_' or 'B_' and put that in your launch string.
> I expect it should work, you can put variables as petsc arguments.
> But what do you mean with multiple cores ? You want to do it in parallel
> at the same time ? Then I don't know how to do it.
> Best
> Timothee
> 2015-12-18 16:46 GMT+09:00 venkatesh g <venkateshgk.j at gmail.com>:
>> Hi all,
>> I am using Petsc and Slepc to solve my eigenvalue problem.
>> I have 1000 A and B matrices saved as binary files. So I use in my script
>> *aprun -n 1 -N 1 ./ex7 -f1 A -f2 B -st_type sinvert -eps_target 0.01 *
>> This is for one A and one B. So, how to do it for each A and B in
>> multiple cores ?
>> Pls. let me know.
>> Thank you
>> Venkatesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151218/8d31f90e/attachment.html>
