[petsc-users] Big discrepancy between machines
Timothée Nicolas timothee.nicolas at gmail.com
Thu Dec 17 07:47:12 CST 2015
It works very smoothly for the SNES :-), but KSPGetSolution keeps returning
a zero vector... KSPGetResidualNorm gives me the norm alright, but I would
like to actually see the vectors. Is KSPGetSolution the wrong routine ?
Thx
Timothée
2015-12-17 19:19 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
> On 17 December 2015 at 11:00, Timothée Nicolas <timothee.nicolas at gmail.com
> > wrote:
>> Hi,
>> So, valgrind is OK (at least on the local machine. Actually on the
>> cluster helios, it produces strange results even for the simplest petsc
>> program PetscInitialize followed by PetscFinalize, I will try to figure
>> this out with their technical team), and I have also tried with exactly the
>> same versions (3.6.0) and it does not change the behavior.
>> So now I would like to now how to have a grip on what comes in and out of
>> the SNES and the KSP internal to the SNES. That is, I would like to inspect
>> manually the vector which enters the SNES in the first place (should be
>> zero I believe), what is being fed to the KSP, and the vector which comes
>> out of it, etc. if possible at each iteration of the SNES. I want to
>> actually *see* these vectors, and compute there norm by hand. The
>> trouble is, it is really hard to understand why the newton residuals are
>> not reduced since the KSP converges so nicely. This does not make any sense
>> to me, so I want to know what happens to the vectors. But on the SNES list
>> of routines, I did not find the tools that would allow me to do that (and
>> messing around with the C code is too hard for me, it would take me weeks).
>> Does someone have a hint ?
> The only sane way to do this is to write a custom monitor for your SNES
> object.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESMonitorSet.html
> Inside your monitor, you have access the SNES, and everything it defines,
> e.g. the current solution, non-linear residual, KSP etc. See these pages
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESGetSolution.html
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESGetFunction.html
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESGetKSP.html
> Then you can pull apart the residual and compute specific norms (or plot
> the residual).
> Hopefully you can access everything you need to perform your analysis.
> Cheers,
>   Dave
>> Thx
>> Timothee
>> 2015-12-15 14:20 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>> On Mon, Dec 14, 2015 at 11:06 PM, Timothée Nicolas <
>>> timothee.nicolas at gmail.com> wrote:
>>>> There is a diference in valgrind indeed between the two. It seems to be
>>>> clean on my desktop Mac OS X but not on the cluster. I'll try to see what's
>>>> causing this. I still don't understand well what's causing memory leaks in
>>>> the case where all PETSc objects are freed correctly (as can pbe checked
>>>> with -log_summary).
>>>> Also, I have tried running either
>>>> valgrind ./my_code -option1 -option2...
>>>> or
>>>> valgrind mpiexec -n 1 ./my_code -option1 -option2...
>>> Note here you would need --trace-children=yes for valgrind.
>>>   Matt
>>>> It seems the second is the correct way to proceed right ? This gives
>>>> very different behaviour for valgrind.
>>>> Timothee
>>>> 2015-12-14 17:38 GMT+09:00 Timothée Nicolas <timothee.nicolas at gmail.com
>>>>> OK, I'll try that, thx
>>>>> 2015-12-14 17:38 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
>>>>>> You have the configure line, so it should be relatively straight
>>>>>> forward to configure / build petsc in your home directory.
>>>>>> On 14 December 2015 at 09:34, Timothée Nicolas <
>>>>>>> OK, The problem is that I don't think I can change this easily as
>>>>>>> far as the cluster is concerned. I obtain access to petsc by loading the
>>>>>>> petsc module, and even if I have a few choices, I don't see any debug
>>>>>>> builds...
>>>>>>> 2015-12-14 17:26 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
>>>>>>>> On Monday, 14 December 2015, Timothée Nicolas <
>>>>>>>>> Hum, OK. I use FORTRAN by the way. Is your comment still valid ?
>>>>>>>> No. Fortran compilers init variables to zero.
>>>>>>>> In this case, I would run a debug build on your OSX machine through
>>>>>>>> valgrind and make sure it is clean.
>>>>>>>> Other obvious thing to check what happens if use exactly the same
>>>>>>>> petsc builds on both machines. I see 3.6.1 and 3.6.0 are being used.
>>>>>>>> For all this type of checking, I would definitely use debug builds
>>>>>>>> on both machines. Your cluster build is using the highest level of
>>>>>>>> optimization...
>>>>>>>>> I'll check anyway, but I thought I had been careful about this
>>>>>>>>> sort of things.
>>>>>>>>> Also, I thought the problem on Mac OS X may have been due to the
>>>>>>>>> fact I used the version with debugging on, so I rerun configure with
>>>>>>>>> --with-debugging=no, which did not change anything.
>>>>>>>>> Thx
>>>>>>>>> Timothee
>>>>>>>>> 2015-12-14 17:04 GMT+09:00 Dave May <dave.mayhem23 at gmail.com>:
>>>>>>>>>> One suggestion is you have some uninitialized variables in your
>>>>>>>>>> pcshell. Despite your arch being called "debug", your configure options
>>>>>>>>>> indicate you have turned debugging off.
>>>>>>>>>> C standard doesn't prescribe how uninit variables should be
>>>>>>>>>> treated - the behavior is labelled as undefined. As a result, different
>>>>>>>>>> compilers on different archs with the same optimization flags can and will
>>>>>>>>>> treat uninit variables differently. I find OSX c compilers tend to set them
>>>>>>>>>> to zero.
>>>>>>>>>> I suggest compiling a debug build on both machines and trying
>>>>>>>>>> your test again. Also, consider running the debug builds through valgrind.
>>>>>>>>>> Thanks,
>>>>>>>>>>   Dave
>>>>>>>>>>> Hi,
>>>>>>>>>>> I have noticed I have a VERY big difference in behaviour between
>>>>>>>>>>> two machines in my problem, solved with SNES. I can't explain it, because I
>>>>>>>>>>> have tested my operators which give the same result. I also checked that
>>>>>>>>>>> the vectors fed to the SNES are the same. The problem happens only with my
>>>>>>>>>>> shell preconditioner. When I don't use it, and simply solve using -snes_mf,
>>>>>>>>>>> I don't see anymore than the usual 3-4 changing digits at the end of the
>>>>>>>>>>> residuals. However, when I use my pcshell, the results are completely
>>>>>>>>>>> different between the two machines.
>>>>>>>>>>> I have attached output_SuperComputer.txt and
>>>>>>>>>>> output_DesktopComputer.txt, which correspond to the output from the exact
>>>>>>>>>>> same code and options (and of course same input data file !). More precisely
>>>>>>>>>>> output_SuperComputer.txt : output on a supercomputer called
>>>>>>>>>>> Helios, sorry I don't know the exact specs.
>>>>>>>>>>> In this case, the SNES norms are reduced successively:
>>>>>>>>>>> 0 SNES Function norm 4.867111712420e-03
>>>>>>>>>>> 1 SNES Function norm 5.632325929998e-08
>>>>>>>>>>> 2 SNES Function norm 7.427800084502e-15
>>>>>>>>>>> output_DesktopComputer.txt : output on a Mac OS X Yosemite 3.4
>>>>>>>>>>> GHz Intel Core i5 16GB 1600 MHz DDr3. (the same happens on an other laptop
>>>>>>>>>>> with Mac OS X Mavericks).
>>>>>>>>>>> In this case, I obtain the following for the SNES norms,
>>>>>>>>>>> while in the other, I obtain
>>>>>>>>>>> 0 SNES Function norm 4.867111713544e-03
>>>>>>>>>>> 1 SNES Function norm 1.560094052222e-03
>>>>>>>>>>> 2 SNES Function norm 1.552118650943e-03
>>>>>>>>>>> 3 SNES Function norm 1.552106297094e-03
>>>>>>>>>>> 4 SNES Function norm 1.552106277949e-03
>>>>>>>>>>> which I can't explain, because otherwise the KSP residual (with
>>>>>>>>>>> the same operator, which I checked) behave well.
>>>>>>>>>>> As you can see, the first time the preconditioner is applied
>>>>>>>>>>> (DB_, DP_, Drho_ and PS_ solves), the two outputs coincide (except for the
>>>>>>>>>>> few last digits, up to 9 actually, which is more than I would expect), and
>>>>>>>>>>> everything starts to diverge at the first print of the main KSP (the one
>>>>>>>>>>> stemming from the SNES) residual norms.
>>>>>>>>>>> Do you have an idea what may cause such a strange behaviour ?
>>>>>>>>>>> Best
>>>>>>>>>>> Timothee
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151217/52a63e2f/attachment-0001.html>
