[petsc-users] Is it still worth switching to PETSc if I can't write a Jacobian for my problem?
Thu Dec 10 15:59:10 CST 2015
On Thu, Dec 10, 2015 at 3:47 PM, Brian Merchant <bhmerchant at gmail.com>
wrote:
> Hi Emil:
> I had a look at odeint's output -- it seems that while Adams is used
> initially, bdf is used most often overall (especially in later timesteps),
> some 80% of the timesteps in total.
> This is likely because I ran the test on the full problem, which includes
> interactions between multiple amoebas -- contact between amoebas turns
> certain parameters on temporarily.
> Matt: is this the getArray method of petsc4py? It converts a PETSc array
> to a NumPy array? How did the PETSc array (let's say from a C program) get
> loaded by petsc4py in the first place -- is there some sort of a "load"
> function? I am sure there are straightforward answers to this question, but
> these are the sorts of things I don't know right now.
The memory is always in one place. The PETSc Vec and NumPy array are just
two ways of looking into it.
  Matt
> Kind regards,
> Brian
> On Thu, Dec 10, 2015 at 12:55 PM, Emil Constantinescu <
> emconsta at mcs.anl.gov> wrote:
>> Brian,
>> Can you take a look at what odeint returns? Specifically, at:
>> ‘mused’         a vector of method indicators for each successful time
>> step: 1: adams (nonstiff), 2: bdf (stiff)
>> I suspect it's using Adams all the way, which means it's doesn't need a
>> Jacobian.
>> Emil
>> On 12/10/15 1:51 PM, Barry Smith wrote:
>>>     Brian,
>>>       I see two distinct issues here
>>> 1) being apply to apply your right hand side efficiently and
>>> 2) what type of ODE integrators, if any, can work well for your problem
>>> with its funky, possibly discontinuous right hand side?
>>> 1)  Looking at the simplicity of your data structure and function
>>> evaluation I think you should just write your right hand side functions in
>>> C. The code would be no more complicated than it is now, from what you
>>> showed me. Even with "just in time" compilation likely you lose at least a
>>> factor of 10 by coding in python, maybe 100? I don't know. It looks to me
>>> like an easy translation of your current routines to C.
>>> 2) This is tricky. You a) cannot compute derivatives? and b) the
>>> function and derivatives may not be smooth?
>>>      If the function was well behaved you could use finite differences
>>> to compute the Jacobian (reasonably efficiently, the cost is just some
>>> number of function evaluations) but with a flaky right hand side function
>>> the finite differences can produce garbage.
>>>      You could use explicit schemes with a small enough timestep to
>>> satisfy any stability condition and forget about using implicit schemes.
>>> Then it becomes crucial to have a very fast right hand side function (since
>>> you will need many time steps). If you are lucky you can use something like
>>> a 4th order RK scheme (but again maybe with a non smooth right hand side
>>> may you can't).
>>>     I am no expert. Perhaps Emil who is far more knowledgable about
>>> these things has questions?
>>>     Barry
>>> On Dec 10, 2015, at 12:52 PM, Brian Merchant <bhmerchant at gmail.com>
>>>> wrote:
>>>> Hi Barry,
>>>> Here's some non-trivial example code:
>>>> https://gist.github.com/bmer/2af429f88b0b696648a8
>>>> I have still made some simplifications by removing some phase
>>>> variables, expanding on variable names in general, and so on.
>>>> The rhs function itself is defined on line 578. The functions referred
>>>> to within it should be all defined above, so you can have a peek at them as
>>>> necessary.
>>>> Starting from line 634 I show how I use the rhs function. In
>>>> particular, note the "disjointed" evaluation of the integral -- I don't
>>>> just evaluate from 0 to t all at one go, but rather evaluate the integral
>>>> in pieces (let's call the time spent between the end of one integral
>>>> evaluation, and the start of the next integral evaluation a "pause"). This
>>>> is so that if there were multiple amoebas, during the "pause", I can take
>>>> into account changes in some of the parameters due to contact between one
>>>> amoeba and another -- poor man's simplification.
>>>> Please let me know if this is what you were looking for. I wouldn't be
>>>> surprised if it wasn't, but instead would be happy to try to rework what
>>>> I've got so it's more in line with what would be meaningful to you.
>>>> Kind regards,
>>>> Brian
>>>> On Wed, Dec 9, 2015 at 2:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>    I prefer the actual code, not the mathematics or the explanation
>>>> On Dec 9, 2015, at 3:42 PM, Brian Merchant <bhmerchant at gmail.com>
>>>>> wrote:
>>>>> Hi Barry,
>>>>> Could send an example of your "rhs" function; not a totally trivial
>>>>>> example
>>>>> Sure thing! Although, did you check out the exam I tried to build up
>>>>> in this stackexchange question, along with a picture:
>>>>> http://scicomp.stackexchange.com/questions/21501/is-it-worth-switching-to-timesteppers-provided-by-petsc-if-i-cant-write-down-a
>>>>> I ask because that's probably the best I can do without using as
>>>>> little math as possible.
>>>>> Otherwise, what I'll do is take a couple of days to carefully look at
>>>>> my work, and write up a non-trivial example of a difficult-to-differentiate
>>>>> RHS, that still is a simplification of the whole mess -- expect a one or
>>>>> two page PDF?
>>>>> Kind regards,
>>>>> Brian
>>>>> On Mon, Dec 7, 2015 at 12:45 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>>     Brian,
>>>>> trivial example
>>>>>     Barry
>>>>> On Dec 7, 2015, at 11:21 AM, Brian Merchant <bhmerchant at gmail.com>
>>>>>> wrote:
>>>>>> Hi all,
>>>>>> I am considering using petsc4py instead of scipy.integrate.odeint
>>>>>> (which is a wrapper for Fortran solvers) for a problem involving the
>>>>>> solution of a system of ODEs. The problem has the potential to be stiff.
>>>>>> Writing down its Jacobian is very hard.
>>>>>> So far, I have been able to produce reasonable speed gains by writing
>>>>>> the RHS functions in "something like C" (using either numba or Cython). I'd
>>>>>> like to get even more performance out, hence my consideration of PETSc.
>>>>>> Due to the large number of equations involved, it is already tedious
>>>>>> to think about writing down a Jacobian. Even worse though, is that some of
>>>>>> the functions governing a particular interaction do not have neat
>>>>>> analytical forms (let alone whether or not their derivatives have neat
>>>>>> analytical forms), so we might have a mess of piecewise functions needed to
>>>>>> approximate them if we were to go about still trying to produce a
>>>>>> Jacobian...
>>>>>> All the toy examples I see of PETSc time stepping problems have
>>>>>> Jacobians defined, so I wonder if I would even get a speed gain going from
>>>>>> switching to it, if perhaps one of the reasons why I have a high
>>>>>> computational cost is due to not being able to provide a Jacobian function?
>>>>>> I described the sort of problem I am working with in more detail in
>>>>>> this scicomp.stackexchange question, which is where most of this question
>>>>>> is copied from, except it also comes with a toy version of the problem I am
>>>>>> dealing with:
>>>>>> All your advice would be most helpful :)
>>>>>> Kind regards,Brian
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151210/47486209/attachment-0001.html>
