[petsc-users] possible to save direct solver factorization for later use
Jed Brown jed at jedbrown.org
Wed Dec 9 20:17:11 CST 2015
Randall Mackie <rlmackie862 at gmail.com> writes:
> Is it possible to save a direct solver factorization (like Mumps) for use in later parts of a code?
> In general, I’m thinking of a scenario like this:
> mat A - do lots of solves using Mumps
> mat B - do lots of solves using Mumps
> 	do other stuff
> If possible, I’d rather only do the numerical factorizations once, and then reuse as required.
Use different KSPs for each solve.
> Do KSPView and KSPLoad to/from binary files save this information?
No, and saving factors to a file likely wouldn't even be useful unless
factorization takes on the order of an hour or more.  If they are too
big to fit in DRAM simultaneously (and you can't just use more nodes),
your best bet is to have some local memory and let the OS swap them out
(it'll automatically do the right thing in this instance).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151209/b827d9f3/attachment.pgp>
